Old 09-02-2010, 09:41 AM   #51
low_84_inchaska
low_84_inchaska's Avatar
Re: project shorty 84
does anyone know which fuel filter would be good to run with the walbro 255 to have enough flow so not to burn out the high flow pump?
my build http://67-72chevytrucks.com/vboard/s...d.php?t=367330
84 short-wide 2wd. 99 5.3 vortec, built 4l60E, schoenfelds, bubb tune, cyber grey metallic
10 camaro ss/rs, 6spd manual, leather, loaded, cyber grey metallic
low_84_inchaska is offline   Reply With Quote
Old 09-03-2010, 10:40 AM   #52
low_84_inchaska
anyone?
Old 01-25-2011, 10:11 AM   #53
low_84_inchaska
Old 01-25-2011, 10:14 AM   #54
low_84_inchaska
been awhile since i worked on it, and i am cranking it back up this week. i got the spring fever now and maybe the -21degree weather is past!!!
this week planned, install harness, install headers, install radiator, efans, and dccontrols fan controller.
next week, build crossmember to replace 2x4 holding up tail shaft lol...and put motor into final resting spot and tighten down..(i have the dirty dingo motosports adjustable mounts)
looking on getting a a bench seat anyone have any hookups or ideas?
need info on bolt sizes for all engine brackets and accessories ie starter, powersteering, alternator.
thanks!!!
Old 01-25-2011, 12:59 PM   #55
spudz
spudz's Avatar
man I missed this project. LOOKS REAL GOOD!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 01-25-2011, 03:16 PM   #56
low_84_inchaska
my crossmember plans....i am open too input!
Old 01-25-2011, 03:59 PM   #57
silvereagle07
silvereagle07's Avatar
Coming along nicely!
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 01-28-2011, 04:05 AM   #58
nbpro
nice looking project
nbpro is offline   Reply With Quote
Old 01-28-2011, 09:18 AM   #59
low_84_inchaska
what do you think of my crossmember plans?
Old 01-28-2011, 02:59 PM   #60
Pulse_GTO
Will you have to modify the headers to get them to fit?
Pulse_GTO is offline   Reply With Quote
Old 01-31-2011, 08:22 PM   #61
DROPPED15
HALF ASSER
DROPPED15's Avatar
Were did u get the headers and r they for the truck and the swap
DROPPED15 is offline   Reply With Quote
Old 02-17-2011, 11:01 AM   #62
low_84_inchaska
i got them from schoenfeld..they are called ls truck headers.
Old 02-18-2011, 03:55 PM   #63
low_84_inchaska
i just ordered up some linkages from summit for the truck. these part numbers might be useful to you guys cause this is what works according to my research.
throttle cable- lokar TC1000-LS1, or TC1000-LS1U, or XTC1000-LS1, the difference in the three being the finish, stainless, black, or black stainless.
column shift linkage kit for 4l60e- lokar ACA-1800
i ordered both from summit the cable kit was 49bucks and the linkage was 54bucks.
Old 02-18-2011, 04:14 PM   #64
low_84_inchaska
EAR-165006ERL ALUM TUBE ADPT -6 MALE AN TO 3 Here is part numbers for everything i have ordered and installed in my truck so far,,i hope this helps out for you guys doing a 5.3 swap.
EAR-165056ERL ALUM TUBE ADPT -6 MALE AN TO 5/8 - this was for adapting the factory fuel line supply from tank.
EAR-165006ERL ALUM TUBE ADPT -6 MALE AN TO 3/8- adapter from hose to return line factory
EAR-184004ERL ASSEMBLY LUBE- for putting on the twist-tite fittings to the hose
RUS-640850 EFI TO 6 AN FITTING-basically a quick snap on gm fitting that adapts to the an fitting.
RUS-640860 FUEL RAIL TO -6AN- fuel rail fitting same as above different size cause you have 3/8 and 5/8.
RUS-650130 6 MALE FUEL FILTER -fuel filter
RUS-670480 METRIC ADAPTER -6 TO 10MMX1.0-fittings off of fuel pump dont forget fuel safe thread sealant.
SUM-220701 TWIST-TITE -6 END STRAIGHT-fuel and oil cooler fittings
SUM-220711 TWIST-TITE -6 END 90 DEGREE- fuel and oil cooler fittings
SUM-220785-B -6 TWIST-TITE HOSE 20 BLACK-hose for fuel delivery and return...also used this as cooler line.
S UM-220647 -06X1/4 NPT-JIC ALUMINUM -cooler fittings off transmission.
LOK-ACA-1800 ADJUSTABLE COLUMN ARM KIT-colum shift linkage.
L OK-TC-1000LS1 THROTTLE CABLE-throttle cable for the vortec intake
Shoenfeld LS Truck headers
ppg ncp-250 primer
rage gold filler
ECU was programmed by jesse bubb
i got new bosch spark plugs and wires
84 short-wide 2wd. 99 5.3 vortec, built 4l60E, schoenfelds.
to do list-finish wiring, cooler lines, paint, interior
Old 02-19-2011, 10:20 PM   #65
signgod2
signgod2's Avatar
if you don't mine me asking , how much $ for the fat matt sound deaden. and how much did you have get to cover the floor pan? thanks cool truck too.
signgod2 is offline   Reply With Quote
Old 02-20-2011, 03:47 AM   #66
americanmuscle
good to see you went with summit line instead of fuel injection line. I got fuel injection hose from a local parts store when I ran my fuel lines for my s10 and it cost me as much as good braded line.
nice swap so far. you doing anything to the engine as far as internals go? a cheap and proven upgrade is a simple ls6 cam and springs. though I went with a slightly larger one in mine and I love it!
I hope you got the right tranny, making an older 4l60e fit is a huge PITA. not worth the time or effort imo, converter spacing and getting it to line up right was horrid. i eventually ripped out my built 60e and put in a stock one of the right year and stock style(but higher stall) converter and it works great now.
you will like currents work, I got thier harness for my s10 and it was perfect, I'll be using them for my future projects too.
Project "Abby"
84 swb 6.0 swap and rebuild.
http://67-72chevytrucks.com/vboard/s...d.php?t=395121
americanmuscle is offline   Reply With Quote
Old 02-20-2011, 01:35 PM   #67
low_84_inchaska
i got the fatmat off of ebay..i think 50sq...i will have to check on that.
i have the newer 4l60e so fitment wasnt an issue, i got pretty far on the install yesterday. i am having issues finding someone to build me a power steering pump though!! no one has the connectors with the orings on them, i need a 90 on one side and a straight on the other, both the larger connector.
i am also pondering on moving my battery to the other side of the compartment cause everything electronic is on the drivers side now.
and.....last but not least,,if the battery gets moved i can get a cold air intake for a 99 silverado and run it too the passenger side.
Old 02-21-2011, 03:29 PM   #68
low_84_inchaska
i was informed that the aca-1800 for my shift linkage for my 4l60e will not work...what do you guys use for the column shifter linkage then?
Old 04-04-2011, 08:26 AM   #69
low_84_inchaska
well,,,the truck is alive!! when i first started it up it was running rough...on 4 cyl...lol..after checking everything i found that i have varnish in my injectors and now have 7 out of 8 going and when i pulled #8 i tapped a ton of varnish out of it....does anyone know of a good way of cleaning out the fuel system?? the motor sat for 2 years.
thanks,
jason
Old 04-07-2011, 08:41 AM   #70
low_84_inchaska
cleaned out the injectors with seafoam, replaced the russel quick connect fuel fitting...she is running great now, very responsive. Also tested the transmission to make sure it goes into all gears with the lokar kit..and it does.
Old 04-07-2011, 08:42 AM   #71
low_84_inchaska
here is a early photo of the motor before it was dressed. kinda ratty but we were still in assembly wiring phase.
Old 04-07-2011, 11:56 AM   #72
fpjr0
fpjr0's Avatar
looks good man.. I wish I had pics of my swap oh well...
ONCE YOU GO LS, YOU NEVER WANT LESS!!
fpjr0 is offline   Reply With Quote
Old 04-12-2011, 11:17 AM   #73
low_84_inchaska
took it down the street the other day.....all i have to say is....HOLY ****!!!!
hello smoke show.
Old 04-21-2011, 06:01 PM   #74
harnalien
TruckincrazY
harnalien's Avatar
Awesome man! I take it the Schoenfelds's worked ok for you? I broke down and bought a set today. Keeping my fingers crossed that they don't give me any problems.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 04-26-2011, 10:29 AM   #75
low_84_inchaska
alien- the schoenfelds work great...little tight on the drivers side a arm but i have the dingo mounts so i just slid the motor back and the issue was solved.
you will love them did you get the uncoated or coated ones? i got the uncoated and did the eastwood titanium high temp header coating on them.
