Old 11-04-2009, 03:18 AM   #51
Shaffer4
Strange Cousin From The West..
Re: Ashtray slide out LCD screen
depending on the height, you could probably do the 6.95" screen if you could build a mechanism that allowed the screen to fit inside the opening sideways and then pivot properly in order to straighten out.
Shaffer4 is offline   Reply With Quote
Old 11-04-2009, 04:05 AM   #52
Andy4639
Old member
Andy4639's Avatar
That's more like it. All the ones I have looked at tonight are built into the dual din models. You have to cut the dash for them to fit. What search terms are you using to find them seperate.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-04-2009, 11:41 AM   #53
k2rm
k2rm's Avatar
Here is the rest of the assembly.
(1st Picture) I cut a L-bracket from a hardware store to fit to the LCD bracket that came with the screen, and allow for the attachment of the second post endclamp with a 1/4-20 nut. I drilled holes in the L-bracket to match the holes in the LCD bracket and used 3/8" barrel bolts to attach it. The L-bracket was painted flat black. This second post endclamp acts as the hinge and the spring thumbscrew sets the tension so that the screen can be tilted at any angle without it flopping down.
(2nd Picture) The ashtray door is removed from the ashtray by drilling out the two rivets. To attach the ashtray door, place the door over the top of the bracket. The brace will not be at the right angle, so it needs to be slightly bent to lie flush with the L-bracket. I placed industrial strenght 3M double stick tape on the top of the LCD bracket and attached the door. The double stick tape holds the door inplace for the next step and adds additional cusion and support since we can't drill through the door.
(3rd Picture) The ashtray door is secured to the L-bracket by drilling two holes through the door brace and L-bracket and screwing them together.
(4th picture) Attach the rail car and hinge assembly to the LCD bracket assembly.
k2rm is offline   Reply With Quote
Old 11-04-2009, 11:48 AM   #54
k2rm
k2rm's Avatar
Here are the rest of the pictures when installing the assembly into the truck.
Old 11-04-2009, 12:20 PM   #55
k2rm
k2rm's Avatar
Just to be clear, the Carportal system is required to make the LCD screen work:
http://www.dealercostcaraudio.com/kos-v500.aspx
The cost for the screen and carportal is likely to be around 600, unless you go with crutchfield and pay a 200 premium.
Cheaper alternatives could be using the mount for an IPod touch, Garmin GPS with MP3 capability, or other media players that fit the dimensions of the opening.
Old 11-04-2009, 12:32 PM   #56
PowerPro
Ok, so If i'm looking at this right, this is not just a pull it out and flip it up set-up. You have to tighten some screws after you pull it up and flip it up to keep it in place, which is fine, I personally would like to be able to pull it out and flip it up and have it stay, but that's personal preference.
On to the actual question - is there anything preventing the screen from getting scraped or being bumped around while in the stored position or is it sufficiently held above the bottom part of the ash-tray slot to where it's not an issue?
Excellent work and ingenuity... excellent.
1970 C20 LWB Fleetside with a 472 Caddy engine! TH400
Restoration in progress
07 Yamaha 650 V-Star Custom
83 Honda V-45 Magna
PowerPro is offline   Reply With Quote
Old 11-04-2009, 01:29 PM   #57
watahyahknow
watahyahknow's Avatar
that should be eazy to do with 4 small rubber wedges directly behind the ashtraylid stuck to the screen part so it wedges itself tight intoo the hole , the only thing touching the edges of the dash then would be the rubber
the pillar that slides out seems solid enough to hold the rearend up
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-04-2009, 01:30 PM   #58
k2rm
k2rm's Avatar
The spring thumbscrews allow for the hinge to not be tightened each time. They keep a constant tension on the posts and so all you have to do is tilt the screen up or down and it stays in place. I probably need to tightent the thumbscrews once a week.
Once it is in the stored position, it doesn't move due to the leverage of the ashtray door on the rubber bumpers. I was pleasantly surprised that this worked out as well as it did. It does take care to make sure the screen is properly aligned when sliding in to make sure the assembly doesn't scrape either the top or bottom of the dash hole. Not a big deal though.
Also, look at the last picture I posted. That shows the clearance of the screen when stored.
Old 11-29-2009, 10:07 PM   #59
frostie_122
VERY COOL!!!! i have a 7" with the v1000 and build a floating console but that takes the cake!!!
http://soundsfast.net/index.php?m=47&s=429&id=41
frostie_122 is offline   Reply With Quote
Old 11-29-2009, 10:22 PM   #60
71swb4x4
71swb4x4's Avatar
Very cool and thanks for sharing!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-29-2009, 10:34 PM   #61
lclippard
lclippard's Avatar
friggin sweet! im prolly still gonna cut my dash but this is very neat.
69 burb/01 yukon chassis
65 Comet Caliente 289 4 Door Sedan
99 Millenia S (supercharged) 4 Door Sedan
02 Yamaha R6
69 swb c10 http://67-72chevytrucks.com/vboard/s...36#post3799136
building with a buddy:
85 C10 http://67-72chevytrucks.com/vboard/s...94#post3708194
lclippard is offline   Reply With Quote
Old 11-29-2009, 10:36 PM   #62
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
sweet!!! Is there gonna be a V2 that you dont manually have to pull up?
John
1999 Toyota Tacoma 4x4
Old 11-29-2009, 10:36 PM   #63
Rokcrln
Rokcrln's Avatar
Great idea, Might need to do this on my 72 Tahoe.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-30-2009, 01:55 AM   #64
CheyenneShop
CheyenneShop's Avatar
I love it, and it doesn't block the center A/C vent (it's an Arizona thing)!
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 12-01-2009, 02:50 AM   #65
Mondo
Mondo's Avatar
Very nice... and thanks for taking the time to give us all the details
Mondo is offline   Reply With Quote
Old 01-21-2010, 01:26 PM   #66
entourageguy
Yellow truck club
entourageguy's Avatar
Great post full of information.
well done.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 01-21-2010, 02:17 PM   #67
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Thumbs up Re: Ashtray slide out LCD screen
This is one for the board archives /
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 01-21-2010, 03:17 PM   #68
k2rm
k2rm's Avatar
Thanks for the compliments. Has anyone else tried it yet? I am curious about other ideas people may come up with.
Old 01-21-2010, 03:43 PM   #69
Cook's '71
Cook's '71's Avatar
That is sweet!
Matt
1969 Chevy C-10 SWB
Cook's '71 is offline   Reply With Quote
Old 01-21-2010, 07:07 PM   #70
Se7en Deuce
Se7en Deuce's Avatar
man great job!!!
love the idea and look foward to doing that myself in the near future
Se7en Deuce is offline   Reply With Quote
Old 03-11-2010, 12:46 AM   #71
tommyd241
tommyd241's Avatar
That is dope!
tommyd241 is offline   Reply With Quote
Old 03-11-2010, 09:02 AM   #72
mike14_07
mike14_07's Avatar
thats a great idea
mike14_07 is offline   Reply With Quote
Old 03-11-2010, 10:10 AM   #73
hoodup
hoodup's Avatar
Very well done! and clever.
hoodup is offline   Reply With Quote
Old 08-22-2010, 07:38 PM   #74
srea76
srea76's Avatar
total cost?
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
Old 08-23-2010, 03:16 PM   #75
k2rm
k2rm's Avatar
$7 to 800 for mounting, car portal and LCD screen. Nav and bluetooth adapters are another $350.
