Old 04-03-2010, 02:26 PM   #51
SCOTI
SCOTI's Avatar
Re: Structures 65 Chevy C10
Originally Posted by structures View Post
Got some of the brake parts in tonight. First things first... paint.
Do you have more info on your brake 'upgrade'?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-04-2010, 01:36 PM   #52
structures
structures's Avatar
Guys thanks for the comments
Scoti the brake upgrade came from Early Classic. It's nothing that they manufacture, it appeared to me to just be a collection of parts they purchase and ship out from various vendors to match the rear brakes made available in the early 70s (73-87???). Since I went with the 5 lug conversion axles my drums match those of the 73-87 12 bolt rear end.
Installing that pivot lug at the top was a real pain in the rear. I wish I would've just cleaned up my existing backing plate and upgraded the shoes and drum. I think that would be possible.
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 04-04-2010, 11:01 PM   #53
Captainfab
60-66 Nut
That brake conversion is likely nothing other than replacement parts for the 2 1/2" wide rear brakes that GM went to in around 1975-76. Those parts can be found either in a wrecking yard or at your local auto parts supplier. Nonetheless yours looks very nice.
Old 06-29-2010, 01:28 PM   #54
structures
structures's Avatar
It's been a while since I updated my build. I haven't got a whole lot done, b/c I've been plagued by home improvements. So lately I installed the Engine, worked a little on the steering and picked up the Cab from my parents and brought it to the house to start some body work. Before I get on the cab though I want to get the transmission in.
Picture of the steering arm and tie rods
I blasted the steering arm and then painted it along with the new moog steering parts.
Last night I got a wild hair and went out to my parents and had my dad help load up the cab on my trailer.
By the time I got home the only strap that was still holding was the middle strap. The cross straps were mostly loose! I was driving slow, but I really should have stopped down the road and checked em.
Robert
1965 Chevy C10
Old 06-29-2010, 01:36 PM   #55
scotts62
One day...
scotts62's Avatar
Very nice build you have going on, keep up the good work! Defiantly subscribed to this one
Scott
93 crew cab build
Project 62
Old 06-29-2010, 05:27 PM   #56
joe231
joe231's Avatar
CHEVY ONLY
Old 06-29-2010, 08:24 PM   #57
Strodder
Daring to be Different
Strodder's Avatar
[/url]
I jackknifed my trailer that way and dented in my quarter panel.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 07-01-2010, 03:18 PM   #58
structures
structures's Avatar
Originally Posted by joe231 View Post
Thanks guys, Strodder sorry to hear about your truck. My old man was watching so luckily it worked out.
Got the cab unloaded and in the garage. Right now it's on blocks, but I did get a chance to clean the junk out of it. Guess I'll get a DA after it and see what's left. Wish I could dip it and e coat it, but that's probably over the top.
The hoist and some 3 inch channel worked fine.
Looking at the FWD RH Floor panel might need some patching.
Robert
1965 Chevy C10
Old 07-01-2010, 11:36 PM   #59
Captainfab
60-66 Nut
If you want to get that cab all cleaned up, abrasive blasting is the only way to go IMHO. That way you see exactly where the rust areas are. Then you just spray it with some epoxy primer and start your panel replacement and body work.
Old 07-25-2010, 08:47 PM   #60
structures
structures's Avatar
Alright I've had a few jobs going back and forth over the last couple of weeks.
I grabbed the auto trans cross member out of my donor truck and had it out for blast and powder coat.
I got it back and got it installed which allowed me to put in the tranny.
What I did where the transmission tail mounts to the cross member is slot the holes FWD to allow the mount to slide back. Then I drilled a 1/2" DIA hole in the center of the cross member. This hole was FWD of the two original holes from the power glide.
I also have been working on the cab. My dad set a bale of hay on the back of the roof back in the day which left a nice dip above the window. So what I have done so far is take another roof off of the donor truck, it was actually in much better condition than my truck. I set the roof in and I think I may either try to bend the old roof up or if I can't get that to work. I can section a piece from the donor.
The dented roof
The donor roof
Roof off
Here I just set the donor roof on
This is a better look of the dent with the donor roof on.
Robert
1965 Chevy C10
Old 07-26-2010, 08:38 AM   #61
structures
structures's Avatar
I have also been working on the power steering gear box. I installed the steering link and all the other steering parts then installed a power steering gear box using CaptainFab's kit. It turned out well, except the first time around it was mounted a little far back and LH inner tie rod was just grazing the frame. So I scooted it back about 3/4 inch and all was well.
Here is the original manual gear box.
This was the first set of holes I drilled, but that was just a little too AFT.
So I actually ended up using the original lower aft hole of the manual box mount and it worked perfect.
Now it has been stitch welded and painted.
I blasted the gear box...
...painted...
...and installed it.
Robert
1965 Chevy C10
Old 07-26-2010, 10:02 AM   #62
structures
structures's Avatar
After dinner last night I decided to do some pushing on the cab roof dent. Well with some force from the palm of my hand and using the rear window opening to counter I was able to cleanly pry the roof back into position. Once it actually started to move, it freely went back into position.
Robert
1965 Chevy C10
Old 07-30-2010, 05:52 AM   #63
67chevy1series
67chevy1series's Avatar
well that looks awsome you un dented it sweet job
67chevy1series is offline   Reply With Quote
Old 07-30-2010, 12:29 PM   #64
65Custom
Sweet!!!! Always a great thing when it takes back it's original shape.
Looking good!!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 07-30-2010, 08:30 PM   #65
tommys66
awsome work! motor looks sweet!
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 07-30-2010, 09:31 PM   #66
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Very nice progress!!
Alan's Classic is offline   Reply With Quote
Old 08-03-2010, 02:25 PM   #67
mcbassin
Still Learning
mcbassin's Avatar
Very nice Project! I will be following your LS install. BTW, how hard was it to repin your harness and make all the mods?
mcbassin is offline   Reply With Quote
Old 08-03-2010, 03:09 PM   #68
structures
structures's Avatar
Looking good!!
Guys appreciate the comments. It keeps me motivated!
So I was pretty lucky with the harness I got with the engine. The guy I bought it from unplugged it from the donor truck as opposed to cutting it. This was really great because I didn't have to chase wires and I could immediately know what wire went to which port on the computer and where the fused wires needed to go to. I did do a sanity check with a continuity tester only to make sure what I thought where the computer wires went, actually did go.
I plan on soldering and shrink tubing the splices once I'm ready. I bought my fuse block from current performance and it has all the necessary connections labeled. I was going to make my own fuse block but for $100 this was well worth it. I also made up a little connection chart diagram to follow when I'm ready. I've been wanting to post it but it's not quite done. I've been planning on making a ls build thread in the engine/drivetrain section but haven't taken the time. I will soon though.
Robert
1965 Chevy C10
Old 08-04-2010, 12:06 AM   #69
structures
structures's Avatar
Today I got my driveshaft installed. Took about 5 minutes. I had this made locally from Driveshafts of Tulsa. It ended up being 72 inches long which I think is the longest you can go before requiring a 2 piece shaft.
Robert
1965 Chevy C10
Old 08-06-2010, 04:22 PM   #70
structures
structures's Avatar
I'm getting set up for sand blasting and I was needing a cab dolly to move the cab in and out of the way.
I took an old utility cart I had which I was planning on replacing the bed anyway. I removed the wheels, built a flatbed out of 2x4s, plywood and lag bolts and bolted it to the wheels. voila! cab dolly.
Robert
1965 Chevy C10
Old 08-06-2010, 06:23 PM   #71
joe231
joe231's Avatar
Nice!
don't let that cab fall off of your wagon and on to your pinky toe.....believe me it hurts
Oh and the one on my toe had doors too
CHEVY ONLY
Old 08-06-2010, 09:11 PM   #72
Strodder
Strodder's Avatar
You should put this picture in the Show Us Your Wheels thread....
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-06-2010, 10:21 PM   #73
structures
structures's Avatar
dennis that's funny.
Nice!
I need to tie it down to the cart bed.
Robert
1965 Chevy C10
Old 08-06-2010, 10:52 PM   #74
Alan's Classic
Nice work on the dolly!! A great way to recycle from stuff laying around. I wish mine had big tires like that so I could roll it outside. I do have one question. Well you do the panel replacements or hire it out? If you do and use the cart may I make a suggestion (if you haven't already thought of it) mount the cab at the points where it bolts to the truck frame. That will give you access to the inner and outer rockers and most of the floor.
The dolly could be modified to do this as you well know.
Just a suggestion.
Here is an example:
Old 08-06-2010, 11:13 PM   #75
Strodder
Strodder's Avatar
I roll it on those Harbor Freight Dollies, the put it on the lift to do the body stuff.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
