04-09-2014, 07:34 PM | #51 |
Re: My side marker light fuel filler idea
Anyone tried one of these? Just ordered one yesterday, thought it might make it easier than removing the small cap from inside of the marker light area.
http://www.yogisinc.com/index.cfm/pa...d/prd13675.htm
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build http://67-72chevytrucks.com/vboard/s...d.php?t=589869 |
04-09-2014, 07:46 PM | #52 |
trucks tv show did one of those on their ls build. through the marker light. let us know how you like it
04-09-2014, 07:55 PM | #53 |
Will do. I must of missed that episode.
04-09-2014, 08:19 PM | #54 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-09-2014, 08:36 PM | #55 | |
I think your right, I have a setup similar to yours but its hard to get the filler nozzle in without overflowing or touching the marker light sheet metal edges. I'll probably modify the inside of the bed if needed. Your setup looks a lot cleaner than mine! Great job and write up.
04-10-2014, 12:03 AM | #56 |
I am working on the same modification for my 69' step side. I am using a capless filler system that you can fined on 08' through 14' ford cars. Also Slant offers replacment capless filler caps that will fit any fill neck. My hand was to big to pull a cap off and on in this small space. I will be hitting the salvage yards for the door hing and fill neck bezel that can bolt on to the existing light box. I may be expecting to cut the inner light box to have the filler neck fit.
I like the hing you used. I have looked at this and was wondering if this would close and open with the clearance needed. Looks easy to install |
04-22-2014, 03:48 PM | #57 |
Quick update. I swapped out my tank (again....) and while I had it out, I replaced the 1.75" filler neck with a 2" filler neck because the other one would occasionally burp fuel depending on the gas station I used. So far the 2" neck appears to provide more flow and quicker fills.
04-22-2014, 04:07 PM | #58 |
Still Learning
Thanks for the link Rob. I sure thought I saw this modification somewhere in the past. I am planning on doing the same. One problem I can see already, my truck has a blazer tank. It's only got a 1-1/2" dia. opening so even if I had 2" pipe it will reduce the flow at the tank.
04-22-2014, 05:51 PM | #59 | |
04-24-2014, 05:14 PM | #60 |
You could add a vent tube from the tank back up to the top area of the filler and it will help with the burping.
My filler was out of an 88 S10, it has a vent tube integrated into it. But don't know if your tank has a vent fitting.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
04-24-2014, 05:19 PM | #61 |
The tank is vented.
04-24-2014, 05:26 PM | #62 |
70+ ( Old Skool Club )
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-29-2014, 11:19 AM | #63 |
I am looking to get a rear tank for my '72. Probably going to get the brothers one which has a 1 3/8" filler neck so I will need to be patient as well.
I have been thinking of doing a sidemarker fill since I don't want to cut into the bed of my truck either and it is lined as well. My initial thought was to just cut out a hold on the side of the rear panel but if I can make the sidemarker fill work then it would be a lot cleaner.
'72 GMC Super Custom 1500 350 V8 w/AC |
06-19-2014, 10:10 AM | #64 |
So im starting to gather parts for this.
wanted to know if you turned down the filler flange... this one has a 3" flange, but the picture on page one suggests that the flange is just over 2". http://www.westmarine.com/whitecap--...06_209_001_500 did you modify the filler cap/flange in any way? thanks! |
06-19-2014, 10:28 AM | #65 | ||
06-19-2014, 12:50 PM | #66 |
I intend on using a Permacap from Kleen Wheels. The only issue is that the Permacap is compatible with only screw type filler necks. Fairly inexpensive at 15.25 plus shipping. Ordered one this week, waiting for delivery.
Here is the link. https://www.kleenwheels.com/vmchk/Pe...rmacap-PC24001 I have a 1970 SWB and am using the filler neck, etc. from a 96 S10 to fill through the side marker. |
06-19-2014, 02:49 PM | #67 |
Well I decided to go with the boyd side fill tank. It has a 2" fill neck so won't need an adapter. Will update on my progress. Thanks.
09-15-2014, 02:26 PM | #68 |
Using the cabinet hinge is the side marker still functional as a light?
09-15-2014, 02:46 PM | #69 |
Yes it does!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-05-2021 at 09:47 AM. |
09-15-2014, 03:00 PM | #70 |
How did you secure the C-Channel to the bed on the inner and outer sides?
09-15-2014, 03:01 PM | #71 |
Which tank are you using?
09-15-2014, 03:28 PM | #72 | |
I used the front side marker screw hole. I have a Boyds EFI tank.
09-15-2014, 03:39 PM | #73 |
I have a successful setup for a hidden fuel fill neck. The parts include a late model fuel door from a Chevy or GMC suburban or truch. The two mounting holes will need to be adjusted in closer. This will allow the tow mounting screws to be behind the side marker. No welding required. The next is the fuel neck. The way to go is using a Ford F150 08 or later fuel neck. This is a capless system and will make it easier to fill without the hassle of a cap. The F150 has the right length of pipe and an overflow tub which connects well with the new tank. Just need a 4 inch fuel hose and clamps.
09-15-2014, 04:32 PM | #74 |
My photo is upside down. I fastened the fuel door to the front and drilled two holes by the inside marker light. The step side has a inner housing which will hold the fuel neck. For fleet side I found another option Still checking
09-27-2016, 11:06 AM | #75 |
bump
