Old 01-25-2010, 03:40 PM   #51
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Project: Recycle
I missed this one last week I guess...Great write up. Looking forward to more on this one.
Looks Great!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-26-2010, 12:49 AM   #52
SCOTI
SCOTI's Avatar
Not too much from this weekend. I finished welding in the support gussets for the 'inside' leg of the upper shock mount. Since the shocks are 'clocked' when installed, the bolts closest to the frame are close enough to the center of the c.member that they didn't need reinforcement; the bolts closer to the differential pumpkin are farther away from the c.member so I felt it would be best to add some additional support. The plate is 3/16" as are the gussets....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-26-2010, 12:59 AM   #53
SCOTI
SCOTI's Avatar
I also got the gas tank inlet 'patch' & fill nipple ready for welding. I made a template from notebook paper pressed into the depression where the original small blazer inlet nipple was (I cut the original smaller inlet out). I transferred the paper template to poster-board trimming & fitting it as close as possible. I then transferred it again to a piece of 16ga stainless sheet. I hogged the center out on the SS patch to allow the inlet tube to be inserted so it can be welded inside & out.
This will allow the fuel to enter through a stock 2.25" 68 inlet neck (cut off of a 68 in-cab fuel tank) & then transition to a 2" stainless inlet pipe to the tank. I'll route the .500" vent line back up to the 2.25" portion of the inlet neck for maximum venting & tie the remaining 2 vent ports from the tank into a breather....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-29-2010, 01:17 AM   #54
SCOTI
SCOTI's Avatar
A little more progress.... I worked on the bed floor to allow the fuel fill line to 'poke' through for easy, simple access for filling the blazer tank. I know many guys opt for an aftermarket flush mount cap or some sort of OE flip-up gas door assembly, but I wanted to keep it simple.
I cut out the floor 'runner' that's closest to the drivers rear corner of the bed/tailgate area to allow for a flat surface....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-29-2010, 01:24 AM   #55
SCOTI
SCOTI's Avatar
I welded in some steel & cut the remaining runner so that I could form a similar 'slope' where the runner ends (I wanted it comparable to the un-modified floor runners).
A little bit of hammer work, welding, grinding; & then a little more welding & grinding until it looked pretty decent. When that was done, I marked the floor w/various measurements for where my fill tube was going to come through the floor. I tried to set it up so the 'gasket' was just up against the 90° lip the bed floor mounts to....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-29-2010, 01:30 AM   #56
SCOTI
SCOTI's Avatar
Using the reference marks, I cut a hole in that 'just finished' flat surface. I installed an OE tank neck gasket & popped the fill tube in place. I haven't decided if I'll leave it as is or maybe build a 'cover' of some sort.
More than likely, I'll leave it as is since it's simple, clean, & functional....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-29-2010, 01:35 AM   #57
SCOTI
SCOTI's Avatar
Now that that's done, I can finish the pipe that runs from there to the tank. It will be 2.25" @ the fuel fill inlet & neck down to a 2" tank inlet (w/a 2" fuel hose connecting the two pieces).
I've been limited on bed floor progress because I have to store the bed in a corner of the shop to allow room for pedestrian traffic. I had to wait until my buddy could swing by the shop & help move the floor into place. Then, I would have to 'clean-up' earlier than I wanted so we could pull it back off to store so he could get home @ a decent hour.
I needed to figure out a way to move the floor by myself quickly & easily. They say necessity is the mother of invention....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-29-2010, 01:36 AM   #58
VA72C10
VA72C10
VA72C10's Avatar
I like that. Nice and simple and clean. And out of the way if you ever did have anything in the back...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-29-2010, 01:37 AM   #59
SCOTI
SCOTI's Avatar
Works like a charm !
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-29-2010, 08:47 AM   #60
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice progress bro....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-29-2010, 09:29 AM   #61
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
I like it ..... NICE work.....!
ksbrktracer is offline   Reply With Quote
Old 01-29-2010, 12:28 PM   #62
MattA
MattA's Avatar
Very cool dolly set up. Will be easier on the back. Looks great.
MattA is offline   Reply With Quote
Old 01-29-2010, 12:45 PM   #63
SCOTI
SCOTI's Avatar
Kind of . . .... They just help get it from 'here to there'. Getting it on/off the frame solo is still a challange (but do-able).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-30-2010, 12:26 AM   #64
n2billet
Village Idiot....
n2billet's Avatar
Any better pictures of the truck itself?
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 01-30-2010, 12:41 AM   #65
SCOTI
SCOTI's Avatar
Just the one's of it on the trailer when we visited the old SOS shop.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-30-2010, 12:55 AM   #66
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Like the fuel filler SCOTI!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-30-2010, 01:57 AM   #67
SCOTI
SCOTI's Avatar
Thanks!
I cut the stainless tubing for the 'under bed' portion after work today. I had to cut some scrap SS transition pieces to get the 2.25" neck @ the cap & grommet down to the 2" pipe sized for the tank inlet. It was fun trying to keep things nice & square.
Tomorrow, I'll move the bed back on the frame to verify exact dimensions for final fitament of the tube.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-30-2010, 01:22 PM   #68
chevytrucknut
chevytrucknut's Avatar
Scoti, I am really diggin your work. Very clean and with lots of thought. Not to mention skills. I look forward to watching this truck come together.
'77 GMC SWB
'66 SNB (Project)
Battle Ground, WA
chevytrucknut is offline   Reply With Quote
Old 01-30-2010, 03:33 PM   #69
Hart_Rod
Hart_Rod's Avatar
Cool build......
Hart_Rod is offline   Reply With Quote
Old 01-30-2010, 10:31 PM   #70
SCOTI
SCOTI's Avatar
Originally Posted by Hart_Rod
Cool build......
Thanks guys!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-01-2010, 01:20 PM   #71
98L150
///Relaxed Atmosphere
98L150's Avatar
cool build. love all of the details pics and infor you are giving. This is a nice project, cant wait to see more on it.
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 02-01-2010, 06:26 PM   #72
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Scoti, I have been waiting for this thread ever since I saw your chassis months ago. I was impressed then and am impressed again now that you put explanations to all of your mods. Projects like yours are very humbling and make me want to sell my junk and take up stamp collecting or something.
That said, why is moving the bed floor hard ? You have a nice forklift there.
Old 02-01-2010, 07:31 PM   #73
SCOTI
SCOTI's Avatar
I use that as my lift for the extra frame & the bed floor is being kept out of the way so as not to inhibit 'business as usual'. The forklift can't do both. I'll prob slice up the other frame this week as I'm nearing the end of chassis stuff.
Thanks for the props. I'm striving to do work as nice as yours!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-01-2010, 07:33 PM   #74
n2billet
Village Idiot....
n2billet's Avatar
I feel the need for some photos.....starting to have withdraws!
Old 02-01-2010, 07:56 PM   #75
SCOTI
SCOTI's Avatar
I struggled w/the fuel inlet piping over the weekend. I'm going to cheat now & go straight up through the floor so I don't have to worry about it later. Waiting on a couple of parts to have a rolling chassis.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
