Old 03-01-2010, 12:53 AM   #51
thepartsguy
thepartsguy's Avatar
Re: My 63
Also, can u tell me what bags you used in the front? Thank you sir.
63 C10
65 Chevy Custom Cab w/ Big Back Window
66 C30
72 skylark w/ 454
65 K10
May the bridges I burn light the way....
thepartsguy is offline   Reply With Quote
Old 03-01-2010, 12:56 AM   #52
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: My 63
thanks man.
Looks like he's running Slam RE7's
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-01-2010, 01:04 AM   #53
thepartsguy
Re: My 63
Does that have a firestone or a goodyear number attached to it? I wanna try and bring em in thru my freightliner pdc, but Im lookin for a number on em.
63 C10
66 C30
72 skylark w/ 454
65 K10
Old 03-01-2010, 01:27 AM   #54
ruffrida2005
Re: My 63
I dont know what the part numbers would be, But they would 2600 lb bags.
Paul
Old 03-01-2010, 08:16 AM   #55
Broke1
Broke1's Avatar
Re: My 63
i got my bushing from *****************
Broke1 is offline   Reply With Quote
Old 03-04-2010, 10:01 PM   #56
Broke1
Broke1's Avatar
Re: My 63
Ok i got a problem with my wishbone it binds going up and down here is a picture of it
Old 03-04-2010, 11:56 PM   #57
ruffrida2005
Re: My 63
I would say that it's probably binding because of how the axle is bolted with the u-bolts. Just my guess.
Paul
Old 03-05-2010, 12:09 AM   #58
thepartsguy
Re: My 63
Is the crossbar your centerlink ties to attached to the frame or the rearend? It could be deceiving, but it looks like its welded to the frame. Shouldnt it be attached to the rearend? Also, are the bolts in the front too tight and pulling the mounting tabs into the eys of ur centrlink?
63 C10
66 C30
72 skylark w/ 454
65 K10
Old 03-05-2010, 12:18 AM   #59
ruffrida2005
Re: My 63
Looks like it's mounted to the top of the rearend. You can see the tabs. I wonder if everything is mounted perfect. Just hard to tell.
Paul
Old 03-05-2010, 12:31 AM   #60
thepartsguy
Re: My 63
I must be blind. I cant see any brackets.
63 C10
66 C30
72 skylark w/ 454
65 K10
Old 03-05-2010, 12:37 AM   #61
ruffrida2005
Re: My 63
here you go!
Paul
Old 03-05-2010, 12:59 AM   #62
thepartsguy
Re: My 63
It looked like they were attached to the bottom of the crossbar. ooops.
63 C10
66 C30
72 skylark w/ 454
65 K10
Old 03-07-2010, 09:36 PM   #63
Broke1
Broke1's Avatar
Re: My 63
Well i rebuild the bottom links and got it all painted
Old 03-08-2010, 01:42 AM   #64
thepartsguy
Re: My 63
Very cool! I really like your trailing arm setup. great work!
63 C10
66 C30
72 skylark w/ 454
65 K10
Old 03-08-2010, 01:43 AM   #65
thepartsguy
Re: My 63
What ended up causin the binding?
63 C10
66 C30
72 skylark w/ 454
65 K10
Old 03-08-2010, 05:29 PM   #66
creep
Registered Loser
creep's Avatar
Re: My 63
Nice! It really makes me want to get mine finished so badly.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 03-08-2010, 08:55 PM   #67
Broke1
Broke1's Avatar
Re: My 63
cause i had the axle mounted with the u-bolts so i had to get 2 more bushings and change it
my wishbone is a hairpin off a straight axle
Old 03-14-2010, 11:55 AM   #68
Broke1
Broke1's Avatar
Re: My 63
got fleetside bed tore apart and the paint stripped off it . driver side needs half the panel replaced passenger side just needs some hammer work and some welding. not sure how many times it was painted but the paint was thick
Old 03-14-2010, 12:09 PM   #69
thepartsguy
Re: My 63
Its warmin up, but I wish it was as warm here as it looks like it is there. I cant wait to start tearin into mine. I hate the cold. Progress looks great!
63 C10
66 C30
72 skylark w/ 454
65 K10
Old 03-14-2010, 01:48 PM   #70
ruffrida2005
Re: My 63
good to seee some work going on. looks like you'll have it driving prety quick. If you were closer I would let you use my sand blaster.
Paul
Old 03-14-2010, 04:48 PM   #71
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: My 63
Dam that box sides look like something Picasso would have dreamed up. I lost two layers of skin chemically stripping a buddy's car even though I had industrial rubber gloves. No tingling from your hands I hope!
Old 03-14-2010, 08:41 PM   #72
Broke1
Broke1's Avatar
Re: My 63
Still got all my skin Chopped a piece off the long bed to patch driver side
Old 03-14-2010, 11:37 PM   #73
ruffrida2005
Re: My 63
Nice Mator cart.
Paul
Old 03-15-2010, 09:49 PM   #74
Broke1
Broke1's Avatar
Re: My 63
here's a better picture of mator
Old 03-15-2010, 09:51 PM   #75
Broke1
Broke1's Avatar
Re: My 63
if i had my wire machine back i would be working on the bed ,but i may have to go to a friends house to do my welding
