Old 06-13-2013, 08:59 AM   #51
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Automotive clearcoat on bed wood, how do i get the color?
That's the forum.It has lots of info on waterproofing wood.The epoxys they use are marine grade and do come at a $$$$$.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-13-2013, 09:36 AM   #52
lenguini
lenguini's Avatar
I found the forum with no issues...it was finding the info within that was a problem.
If you could post a link to that specific topic or at least one of them to start.
Cheers,
Ed.
Always a place in my heart for old Chevy trucks:
My build thread-project truck dream 65"
http://67-72chevytrucks.com/vboard/s...d.php?t=510863
lenguini is offline   Reply With Quote
Old 06-13-2013, 11:25 PM   #53
gkesseru
gkesseru's Avatar
I tried clear epoxy on my 55. lasted about a year, then started to peel at the edges. Problem is that wood WILL expand as the moisture content changes. A rigid plastic coating like epoxy, varnish or urethane will not change size so it splits at the edges first. My 68 now has a flexible coating: Two coats of teak oil, covered by several coats of tung oil on all four sides, then paste wax. Need to paste wax regularly. Holding up so far.....
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 06-14-2013, 12:52 AM   #54
lenguini
lenguini's Avatar
Im hearing good things about the teak oil with a coat of teak guard on top for UV protection...
How long have you has been using the teak and tung oil products on your 68 ?Any pics you could post would be appreciated.
Thank you,
Ed.
Old 06-14-2013, 07:53 PM   #55
gkesseru
gkesseru's Avatar
It's been on there 2 1/2 years with no change, but it is garage kept. It's white oak so it is closed celled wood I would never use red oak, it's open pored and rots easily. Remember that the originals were oiled Southern Yellow Pine, which is somewhat rot resistant because it's so full of sap. Whatever method you finally select, make sure to do all four sides to keep the moisture content same top and bottom. This prevents cupping.
Follow this link to my original build thread.
http://67-72chevytrucks.com/vboard/s...=392932&page=5
72 Fleet (died)
78 Step (sold)
00 F150
Old 06-14-2013, 10:16 PM   #56
PanelDeland
http://www.tnttt.com/search.php?keywords=Epoxy
This is a search on the forum there.CPES is one I remember there are others.It's easy to start an account and ask.There are people there who are as knowledgeable about their hobby as the ones here.
Old 06-20-2013, 08:48 PM   #57
gkesseru
gkesseru's Avatar
The teardrop trailer folks are having success with clear epoxy because they are applying it over this plywood. Since Plywood has layers bonded to each other at right angles, it is dimensionally stable (won't expand lengthwise or widthwise with changes in moisture). Since the plywood used is very thin, they wont have much expansion in that direction either. I agree that putting a top coat of automobile clear will help with UV damage. Marine epoxies such as West System (very expensive) and Raka already have UV inhibitors.
BTW, never use polyester resin on plywood, it will separate after a while.
72 Fleet (died)
78 Step (sold)
00 F150
Old 06-20-2013, 09:35 PM   #58
kijocoz
hi im a floor guy(30 yrs) i do a lot of teak,mahogany... Australian oil great finish 5-7 yrs w/heavy traffic i just put a pressure treated 5/4 bed in my truck and used it. available at better paint stores
kijocoz is offline   Reply With Quote
Old 06-22-2013, 01:29 AM   #59
lenguini
lenguini's Avatar
Thank you,I appreciate the info. I'm wondering if you could post some close up pics of the bed wood so I can see the finish you ended up with.
Thanks,
Ed.
