Old 03-03-2010, 08:00 PM   #51
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Re: 572 update
Nice!
Just a little at a time and you'll get it done.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 03-09-2010, 07:00 PM   #52
handsomerob
handsomerob's Avatar
Talking Re: 572 update
well we got back into the 72 today after making a cradle to hold the bed.
here are some pics to show you whats goin on so far.
handsomerob is offline   Reply With Quote
Old 03-09-2010, 10:02 PM   #53
estig70
estig70's Avatar
Re: 572 update
Yikes!!!!!!!!
estig70 is offline   Reply With Quote
Old 03-10-2010, 01:47 AM   #54
BOOB
BOOB's Avatar
Re: 572 update
Originally Posted by allthrottle,nobottle View Post
can you weld?
if so just custom make your own
...because it's sooooo easy!
1970 Short/Fleet C-10 (Project)
-Slammed and Tubbed
1955 Cameo
-Straight six, Turbo Hydro option
1955 BelAir 2 door post
-All original down to the oil bath air cleaner
1964 Corvette
-All power A/C 327 4 spd. tanker
BOOB is offline   Reply With Quote
Old 03-10-2010, 02:39 AM   #55
highperf4x4
Re: 572 update
Subscribed!
highperf4x4 is offline   Reply With Quote
Old 03-10-2010, 05:34 AM   #56
c10seconds
c10seconds's Avatar
Re: 572 update
this is ridiculous! cool stuff here. I would like to see the header/starter clearance
c10seconds is offline   Reply With Quote
Old 03-10-2010, 05:24 PM   #57
Fitz
Re: 572 update
handsomerob;
just occurred to me....the brake booster you're running can be replaced with a dual diaphragm unit...mine is MUCH smaller than what you're running and completely misses the valve covers. Available from Carolina Classic Trucks.
Fitz is offline   Reply With Quote
Old 03-10-2010, 06:11 PM   #58
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: 572 update
Cool ride! I can't wait to see some vids of this thing ripping the tires off! I can smell the rubber burning already...
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-10-2010, 07:36 PM   #59
handsomerob
Re: 572 update
O.k. some pics from today, dug into the Diff, slapped the tranny in it, moved the crossmember, removed an exhaust hanger etc.
Old 03-10-2010, 10:48 PM   #60
handsomerob
Re: 572 update
Originally Posted by Fitz View Post
handsomerob;
I already have a 9" booster with new master ordered, along with a proportioning valve.
The new booster should give me 3/4" clearance between it and the valve cover. I will also be using a 12V vacuum pump to provide enough vacuum for the brakes.
Old 03-11-2010, 09:23 PM   #61
handsomerob
Re: 572 update
Well drilled some holes today and mounted the tranny cross member, I had to move it back on the frame rails about 5 inches.
I also removed one of the exhaust hangers to allow for the installation of the crossmember.
I will be doing the ladderbar setup this weekend so I should have lots of pics to post.
Old 03-11-2010, 09:40 PM   #62
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: 572 update
subscribed
I noticed its an A/C truck did you have any issues with the A/C box?? I'm planning a 472 caddy trans plant and have been scratching my head on that..
theres no substitute for cubic inchs.............
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-11-2010, 10:13 PM   #63
Painter D
Painter D's Avatar
Re: 572 update
Subscribed as well.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 03-11-2010, 11:26 PM   #64
handsomerob
Re: 572 update
Originally Posted by Hottrucks View Post
subscribed
So far no issues with the A/C box, I'll be replacing the whole system with new replacment parts and using an newer Compressor with some custom lines to interface new with old.
Old 03-12-2010, 08:00 AM   #65
Hottrucks
Hottrucks's Avatar
Re: 572 update
thanx I was going to go that route until.....well the 472 uses that goofy A/C pump that fits over the intake so well see about an update but keep us posted..looks like a killer build
Jeff
Old 03-12-2010, 11:31 AM   #66
highperf4x4
Re: 572 update
Rob, did you take so many pics of that plastic fuel filter just to see if someone was going to complain about it?
Old 03-12-2010, 06:36 PM   #67
weircc
weircc's Avatar
Re: 572 update
can i ask what torque converter you used where you got it? i have a 4l80e im wanting to run it came out of a 6.5 diesel truck
weircc is offline   Reply With Quote
Old 03-12-2010, 06:46 PM   #68
Jacfourteen
Re: 572 update
I noticed that too. Most people throw a fit when they are between the mechanical pump and the carb, because of the fire risk.
Old 03-12-2010, 07:08 PM   #69
handsomerob
Re: 572 update
The Torque converter came with the tranny, I don't have the part number on me right now I will get it tomorrow and post it for you.
Old 03-12-2010, 07:14 PM   #70
handsomerob
Re: 572 update
That filter was installed by whoever installed the 427 in the truck, they didn't have the return line hooked up at all.
I will be using a high flow electric pump and a high flow filter.
Old 03-13-2010, 11:23 PM   #71
handsomerob
Re: 572 update
Well here are some pics of the ladder bar install, it was a long 8.5 hours of labour but I think it'll be worth it.
I'll have more pictures tomorrow.
Old 03-14-2010, 12:06 AM   #72
highperf4x4
Re: 572 update
Man that looks awesome!!
Hard to tell if the 4 link brackets are going to clear the frame though.
Old 03-14-2010, 04:10 PM   #73
handsomerob
Re: 572 update
Well went in and worked on the truck for a few more hours today took some measurments, found I had a mount slightly out so I cracked the spot welds and adjusted it a bit.
Due to the height of the leaf packs I had to fab up some custom spacers for the sliding mounts. I just used some square tube and welded washers to the ends; simple yet effective.
we'll be bringing the truck to a welding shop to get everything profesionnaly welded. I'd hate to have a weld break after mashin the gas pedal.
I'll have a few more pics to post over the next few days.
Old 03-14-2010, 10:01 PM   #74
handsomerob
Re: 572 update
Well here are a few more pics.
Old 03-15-2010, 12:48 AM   #75
cpetersen
cpetersen's Avatar
Re: 572 update
Nice project! How much room did you have for the valve cover on the driver side firewall? Mine was really close, so close i had to trim the firewall. It was with in a 1/2 inch on the passenger side.
cpetersen is offline   Reply With Quote
