Old 04-01-2010, 07:42 PM   #51
neba
Re: HEI Ignition Problem
i would try installing a clear plastic in line gas filter so you can see if your getting fuel
neba is offline   Reply With Quote
Old 04-01-2010, 11:56 PM   #52
nrb's70gmc
nrb's70gmc's Avatar
i have been asking alot of people and they are telling me it sounds more like a fuel problem (because the truck does start right up) but as you know these old tanks are rough on the motors
(i use two fram G3's) but latly i have been fueling up at a 1/4 tank or a little below. i always used to fill up at 1/2 tank- regardless every time i changed a filter it looked like coffee coming out of the old one's.
i use two filters because it seems like a good idea with an old tank ( i place 1 on the fuel line about 3ft out of the tank and then the 2nd one up by the carb.
cant wait untill i get an aluminum under bed tank
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
Old 04-02-2010, 12:04 AM   #53
highperf4x4
Sounds to me like your sock inside the tank is shot, probably falling apart and clogging up your fuel line. From what you're telling us today I would say it's a fuel problem hands down.
I would pull the whole pickup/sending unit out of the tank and check it out.
highperf4x4 is offline   Reply With Quote
Old 04-02-2010, 12:15 AM   #54
nrb's70gmc
nrb's70gmc's Avatar
Thanks man, for the info
is the sock in the tank like a universal thing i could buy at a auto parts store?
i know what is (dont get me wrong) but if i have to replace it, whare can i get one on short notice?
Old 04-02-2010, 12:21 AM   #55
highperf4x4
Nope. I couldn't find a replacement at a local parts store. You could take one with the right shape and make it work with a piece of hose to attach it maybe if it's only temporary.
Old 04-02-2010, 12:50 AM   #56
nrb's70gmc
nrb's70gmc's Avatar
what do you mean? so do they sell any at the local auto shops? just not one for our trucks?
Old 04-02-2010, 12:50 AM   #57
highperf4x4
Correct.
Old 04-02-2010, 12:55 AM   #58
nrb's70gmc
nrb's70gmc's Avatar
ok thanks
Old 04-02-2010, 12:56 AM   #59
highperf4x4
you're welcome
Old 04-02-2010, 01:03 AM   #60
nrb's70gmc
nrb's70gmc's Avatar
I will update again tomarrow with my findings (and questions)
Old 04-02-2010, 01:12 AM   #61
highperf4x4
we will be here.
Old 04-02-2010, 01:56 AM   #62
nrb's70gmc
nrb's70gmc's Avatar
one more quick fact---i now have a new cap,rotor,pick up coil, and i had both my ignition modules tested (both good) and this problem is still happining.
but i have to say i needed a new cap (for sure) because the other one was chipped/cracked ware the carbon brush sticks though the underside,
Old 04-02-2010, 06:48 PM   #63
nrb's70gmc
nrb's70gmc's Avatar
If the screen/sock inside my tank needs to be replaced ware can i get a new one? BROTHERS/CLASSIC INDUSTRIES/LMC/CLASSIC PARTS OF AMERICA?????? lol i have all the catalogs.
the auto parts stores dont sell them (i confirmed today)
Old 04-02-2010, 07:28 PM   #64
highperf4x4
If you have all the catalogs then why do you need our input?
Old 04-02-2010, 07:57 PM   #65
nrb's70gmc
nrb's70gmc's Avatar
well i looked though brothers and did not see any gas tank socks/screens
just wondering if anyone has had to replace one before.
Old 04-02-2010, 08:20 PM   #66
1-PU70
1-PU70's Avatar
Well I have been following this and for what its worth here is what I think. Even though you had the modules tested that doesn't mean they are good. I have had bad ones test good. This problem sounds exactly like a bade module. And as fare as using 2 fuel filters some might disagree maybe everyone but you never run a fuel filter before a mechanical fuel pump and you never run a fuel filter after an electric pump. Good luck.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 04-02-2010, 08:31 PM   #67
nrb's70gmc
nrb's70gmc's Avatar
ya i have had modules go bad also thats why i thught this problem was a the ignition--but im going to change the fuel filters and test drive it after it stops snowing--before i buy anything else.
Old 04-02-2010, 08:48 PM   #68
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
If you can try just one filter.... do so, two might be starving the carb.
I think this is more fuel related, But like I mentioned earlier... the module is usually the culprit here.
Can you check the fuel pressure with a gauge? You would need to check the pressure at the carb inlet. also...might wanna bump up a jet size too.
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 04-02-2010, 09:13 PM   #69
nrb's70gmc
nrb's70gmc's Avatar
i really have never had a problem with the filters or carb jetting issues before but if both filters pluged up than that would mean the filters are starving the engine (just common sense)
Old 04-03-2010, 03:47 AM   #70
highperf4x4
Did you get that backwards?
Actually a mechanical pump pulls really well and an electric pump pushes really well. It's the electric pump that has trouble pulling. That's why the majority of them are inside the gas tank. It would be impossible not to have the filter "after" a pump that's inside the tank. Even the factory electric pumps that are located outside the tank like the ones on my shop vans have a 2nd primer pump inside the tank to push the fuel to the pressure pump.
Old 04-03-2010, 03:49 AM   #71
highperf4x4
http://www.classicparts.com/1967-87-...ctinfo/23-598/
Or you can just go to www.classicparts.com and do a search for "fuel sock"
Old 04-03-2010, 01:08 PM   #72
nrb's70gmc
nrb's70gmc's Avatar
hay thank for the link man, just a quick question. if the fuel sock happens to be intact--i guess it can still get plugged up over ther years and still may need to be replaced correct?
Old 04-03-2010, 06:14 PM   #73
El Jay
Gone to greener pastures
Going back to spark plugs; I run Accel shorties too.
Mike's Bump & Grind Garage shipped a set to my front door for about $25 last year.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-03-2010, 09:30 PM   #74
bigguy69
dazed and confused
bigguy69's Avatar
i have had a tach wire come loose and ground out, it caused about the same problems you are talking about.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 04-03-2010, 11:18 PM   #75
highperf4x4
Unelss someone has replaced that sock it will be shot by now. When you tell me that you're getting stuff out of your fuel filters that looks like coffee grinds then I'm sure it has already started coming apart. It will probably crumble in your hand. You will be able to tell if it's still flexible and fairly clean as soon as you pull it out. If it needs to be replaced then your filters probably do too.
