Old 01-22-2011, 10:39 PM   #51
threeonthetree
threeonthetree's Avatar
Re: Project..1962 Bel Air
haha yeah i think it will stay silver
the blocks where orange back in 62
its got some high quality paint on it think well leave it.
got the pan on it. gotta get a water pump
any suggestions on a intake manifold? or carb for this block. the block is rated at 375 high power so anything that will put us close.
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 01-24-2011, 12:23 AM   #52
threeonthetree
hey guys i was welding on the car the other day and i think someone put some lead on this car. how can i tell. i was welding up some pin holes and burned the lead off. im not sure what to do. its above the wheel on the passenger side quarter. i welded up the bottom of it. ill have some pics up. anybody got any suggestions on the intake.
is that 292 cam to big for a 327?
the motor is on the previous page that we got its a
327 with 267/305 heads on it and a 292 comp cam and a steel crank .10 under flat top pistons.
will i be able to run standard gas.
i also have the original heads that came with the 327
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-24-2011, 12:42 AM   #53
67chevy1series
67chevy1series's Avatar
you are a good welder and body man so just cut out were the lead is and weld a new patch in
67chevy1series is offline   Reply With Quote
Old 01-29-2011, 10:41 PM   #54
threeonthetree
Here are some pics for you guys
pic of the welder
pic of this little patch i did. no bondo on it yet.
one more
The inner rocker i started making patches for it
couple patches i made. just gotta make the outter one and weld it in.
got the heater core out.
got some things sand blasted for the 327
THE 327!
should have some more up tomorrow gonna put in a long day in to office!
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-29-2011, 10:47 PM   #55
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Ya still in HS or not, I forgot. Motor/car look great man! Id put new gaskets in if you havent already, and dont skimp here, I did and my new motor leaks oil. FELPRO FTW
Keep at it! Any c10 updates?
John
1999 Toyota Tacoma 4x4
Old 01-29-2011, 11:02 PM   #56
threeonthetree
Yeah still in HS. Thanks man...gaskets are new and i just put a new oil pan gasket in.
FELPRO? gasket company?
I will keep at her. No haven't really been paying much attention to the C10 its just sittin.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-29-2011, 11:04 PM   #57
oldblue1968chevy
Sitting? Why?
Felpro, yeah gasket co. If your like me you DONT want that thing to leak oil everywhere! I used some cheapo cork gaskets for everything, ughh.
John
Old 01-29-2011, 11:05 PM   #58
oldblue1968chevy
Ha just noticed your ridin the bike on ice with the screws in the tire!?!? Sounds pretty crazy! I got the fourwheelers out this past snow we had 5"!!! It was DEEP! Lots of ice too
John
Old 01-29-2011, 11:44 PM   #59
threeonthetree
cause its winter and i dont feel like letting my truck get covered in salt, then rusting out again. plus havent had much time to do anything to it.
haha yeah i told my old man them cork gaskets are junk. thats what we used for the oil pan i want to take it out and get a neprem one.
yeah studded 1983 cr250 for the ice its bad as
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-30-2011, 01:58 AM   #60
threeonthetree
once i get this pass rocker done
the driver should go really fast
then im gonna work on the floor supports
once i get those clean im gonna weld them in
and then drill all the holes in the floor pans
weld them in
then prolly pull the body off this spring pain the frame and ****
then install the drivetrain.. then put the body back on.
POR 15 is it worth it?
where can i buy it
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-30-2011, 02:08 AM   #61
threeonthetree
wat do you guys think of lowering the bel air
cut the front springs?
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-30-2011, 05:09 PM   #62
threeonthetree
Alright today i got some stuff done on the rockers
1st pic the outter rocker patches i did.
more from the inside
test fitting my inners
starting to weld them in after i treated the inner with a rust converter and painted.
all welded in just have to dress my welds gonna finish that up this afternoon
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-30-2011, 08:05 PM   #63
threeonthetree
so i just came back in got the shop all cleaned up started dressing some of the welds really looks alot better in person.
got the old motor out of the shop and organized and cleaned everything up.
i should have the driver side rocker done by the end of this week. if i put my mind to it.
give me some encouragement i could use it.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-30-2011, 08:18 PM   #64
oldblue1968chevy
Hey, your doing an awesome job. I wish I had your skills and motivation. Hang in there.
I cut my front springs on my truck,what would you do for rears for the belair
John
Old 01-30-2011, 08:26 PM   #65
threeonthetree
idk what id do on the rear i think you can cut the rear springs too.
thanks man.
i sure had teh motivation today.
hopefully ill have the driver side done by friday and then to the floors.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-30-2011, 09:01 PM   #66
threeonthetree
yeah i just was reading and you can cut all the coils all the way around
i think ill do that when the time comes.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-30-2011, 09:16 PM   #67
67chevy1series
dude this gonna be anice @$$ car you always need a nice old 67 72 chevy and a 72 below chevy car!!!!
Old 01-30-2011, 11:33 PM   #68
threeonthetree
thanks man
i just got the passanger side rocker all cut up
i cant wait to get home from school and make some pieces for it. ill be done with it sooon.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-30-2011, 11:54 PM   #69
JML55
JML55's Avatar
Looking good
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 01-30-2011, 11:56 PM   #70
threeonthetree
Originally Posted by JML55 View Post
Looking good
Thanks man
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-31-2011, 07:45 PM   #71
threeonthetree
got some stuff done after school.
outter patch
making my inner patch
inner patch test fit. just have to make the front patch and weld them in. then the rockers are done
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 01-31-2011, 07:49 PM   #72
CAL 58 GMC
CAL 58 GMC's Avatar
Nice job on the rockers!
CAL 58 GMC is offline   Reply With Quote
Old 01-31-2011, 09:48 PM   #73
threeonthetree
Thank you CAL sure means alot comming from you
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-01-2011, 12:25 AM   #74
threeonthetree
i ran the vin on this car found out it was made in Janesville wisconsin.
its a six original
cant wait to hear the 327 popping
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-01-2011, 09:58 AM   #75
richards72chevy
richards72chevy's Avatar
Looks good.How many coils are you going to chop off?I chopped 2 off the front of my 69 impala i think it mite have been too much.
richards72chevy is offline   Reply With Quote
