Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-22-2010, 03:14 PM   #51
VA72C10
VA72C10
VA72C10's Avatar
Re: 71 Blazer "Finishing Touches"
I hope to be working on it some this evening and maybe some tomorrow. As soon as I get over to the shop I'll get detailed pictures on the hitch. It says valley industries on there and i'll check when there whether it's bolted or welded...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-22-2010, 03:27 PM   #52
AZ 1971 Blazer
thanks VA. i'm new to this site, just bought my 2nd Blazer/ Jimmy, my 4th older GM product. i will be posting pics soon and look forward to the responses! this site it really cool and i'm blown away by the knowledge and craftmanship on this site
AZ 1971 Blazer is offline   Reply With Quote
Old 05-24-2010, 01:02 AM   #53
VA72C10
VA72C10
VA72C10's Avatar
here's the pics of the hitch with the capacity. It's a bolt on also.
Old 05-24-2010, 01:03 AM   #54
VA72C10
VA72C10
VA72C10's Avatar
I believe it was purchased through LMC but it might be found directly cheaper through Valley.
Old 05-28-2010, 02:34 AM   #55
VA72C10
VA72C10
VA72C10's Avatar
Well, bought my new truck tonight and played around with that some....but couldn't neglect this either....
Got the passenger side sanded...really won't need any filler except at the patch and that will be minimal.....
Old 06-02-2010, 01:59 AM   #56
VA72C10
VA72C10
VA72C10's Avatar
Well, trying to keep a balance of work, family, and two projects is hard. Got a couple hours of adjusting and sanding done tonight. The hood was the worst fitting piece on the truck...look above for the "closed" hood. Well out of whack. Thought it was the aftermarket hinges but after swapping in a nice used set I had there was no change.
Old 06-02-2010, 02:02 AM   #57
VA72C10
VA72C10
VA72C10's Avatar
So we started adjusting the hinges and just as we thought we'd adjusted the only ways that would work...I had a "eureka" moment. We loosened up the bolts on the rad support and shifted it over about 5/8". Not perfect but close enough where I can fine tune it now.....
Old 06-02-2010, 02:04 AM   #58
VA72C10
VA72C10
VA72C10's Avatar
Did a little more sanding on the driver's side then moved over to the passenger side. Got the hood and the pass side done all except the back quarter panel.
and we had a visitor tonight....the world traveling Bonnie.....
Old 06-02-2010, 02:05 AM   #59
VA72C10
VA72C10
VA72C10's Avatar
Finally, brought over a trashed gate to use as patches for mine...
Old 06-02-2010, 01:51 PM   #60
nuke1
nuke1's Avatar
nice touches on the truck so far, got a love the visitors, wonder if she will ever visit the great white north, oh yeah, the land far and beyond. LOL. keep up the good work.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 06-02-2010, 02:16 PM   #61
VA72C10
VA72C10
VA72C10's Avatar
Thanks....talking it over with Jason (Pop's Chop Shop) he's shooting for July 1st to be done
Old 06-05-2010, 01:43 AM   #62
VA72C10
VA72C10
VA72C10's Avatar
Finished stage 1 of the sanding...now filler and then stage 2 before we seal and prime it....then one last sanding and PAINT!!!
Started off by finishing up sanding the last panel left from the other day...the driver's rear quarter....
Then moved on to working on removing the guts from my bad gate to go in the good one....just needed a little pb blaster, a little hammer, and a lot of effort
Old 06-05-2010, 01:47 AM   #63
VA72C10
VA72C10
VA72C10's Avatar
Then I loosened up the top and when Jason had time we lifted it off....I don't know if I'll ever have it on again until I sell it....
Got the rest of the gate hardware off
THen removed and sanded the gas filler cover
And finally the bed rails....
Might get filler done Sunday and then more sanding until that's complete.
Old 06-05-2010, 10:40 AM   #64
0331grunt
Now what??
0331grunt's Avatar
Just checked out your build. Looks great! The family will love cruisin' in the topless blazer for sure!
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 06-05-2010, 09:07 PM   #65
Slick67
Sofa King Crazy!!
Slick67's Avatar
VA.......hatin you cause the headers look great. Can't wait to get mine. Blazer looks sweet!!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 06-16-2010, 09:01 AM   #66
VA72C10
VA72C10
VA72C10's Avatar
Thanks guys. Been slacking on the updates but spending money like crazy.
Purchased the materials for my custom interior (recovering the front utility buckets and rear bench to match in a nice black vinyl and fabric combo, and matching door panels and rear cargo area panels.
Bought all the final paint supplies and the primer, sealer, paint, and clear.
Got a nice used factory tach dash to replace the white gauges and column mounted tach.
Getting ready to place a final order for carpet and misc parts for it.
Did some more sanding and little things like working on cleaning up the wiring, installing the brackets under the steering column, installing the rear bedside braces, cleaning and prepping final parts for paint, and sourceing some good tailgate parts out of my "stash"
Jason has been doing filler work. Has put two to three very light skim coats and sanded down between them. The Blazer is ridiculously straight so there's only been a few spots he's needed to do and a few were minor enough primer would probably have been adequate but while the filler was out he went ahead and gave them a quick skim.
Plan is to do a final 400 grit sand and then spray primer beginning of next week. Then it's block sanding and maybe one more coat of primer depending on how that goes. Afterwards it'll be sealer, paint, and clear. Should be in color in a few weeks
I hope to have pics of the seats next week as well. I will be painting the frames and backs gloss black. I'll get some more pictures as soon as some more progress is made....
Old 06-22-2010, 05:25 AM   #67
nuke1
nuke1's Avatar
looking good!! keep it up and it will be pinted in no time!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 06-28-2010, 12:26 AM   #68
mcbassin
Still Learning
mcbassin's Avatar
Looks like another nice project you have! Can't wait to see this one done! Subscribed.
mcbassin is offline   Reply With Quote
Old 06-28-2010, 12:37 AM   #69
VA72C10
VA72C10
VA72C10's Avatar
Thanks...hoping to paint in a week....
Thanks! Shouldn't be long till it's done. Last body work is being finished tuesday hopefully then it's being sealed, primed, and painted.
Next will be interior and final assembly. And then a lot of cleaning because of all the body work dust
Old 06-30-2010, 10:08 PM   #70
VA72C10
VA72C10
VA72C10's Avatar
Body work was finished yesterday as planned...got the front and rear inner tubs coated with a couple coats of bedliner....came out looking great and should be nice and durable against the rocks the 33's decide to throw. Got the ground on the horn lengthened and installed, and made a final gameplan. Hope to have paint on this thing by the end of next week and an interior within a couple weeks after that!!!
Old 06-30-2010, 10:18 PM   #71
mcbassin
Still Learning
mcbassin's Avatar
Did you already say what color scheme you are going with?
Old 06-30-2010, 10:48 PM   #72
gcburdic
Restoration Virgin!
gcburdic's Avatar
Originally Posted by VA72C10 View Post
......and made a final gameplan. Hope to have paint on this thing by the end of next week and an interior within a couple weeks after that!!!
Wooohoooo.....stay with the game plan Jonathan, no changing your mind!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-30-2010, 11:13 PM   #73
VA72C10
VA72C10
VA72C10's Avatar
It's going to be solid blue...the factory color that's already on the windshield, firewall, and firewall....with a white top. Interior is going to be black with blue....the seats will be black vinyl with black cloth on the main seating area. Also doing the same theme on the door panels. Black carpet.
I actually have stuck with it on this one...the gameplan I was talking about was basically just the scheduling...
Old 07-01-2010, 12:02 AM   #74
70k52wd
Blaze-Air
70k52wd's Avatar
Looking good...do you ever sleep?
70k52wd is offline   Reply With Quote
Old 07-01-2010, 12:19 AM   #75
VA72C10
VA72C10
VA72C10's Avatar
not much
