Old 08-14-2010, 02:28 AM   #51
sgtusmc
sgtusmc's Avatar
Re: 1952 chevy home made frame build
I'm blown away by your frame and fab skills, great job. I bought a blazer tank last week and I'm getting ready to install it. Where did you get your tank straps from?
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 08-14-2010, 02:57 PM   #52
hotrod1
56 - autocross
hotrod1's Avatar
Great build. What paint did you use to do the frame? Brush, spray, undercoat? Also, how wide is the rear end, mounting surface to mounting surface?
hotrod1 is offline   Reply With Quote
Old 08-14-2010, 04:58 PM   #53
Thinkblue4 Evr
Thinkblue4 Evr's Avatar
Thank You for all the comments
sgtusmc: We did not buy them we made them out of some scrap stainless and bent them around some 3/8 rod for mounting points. It does not move at all the way we have it mounted.
hotrod1: We used Rustoleum brush on semi gloss primer we did 2 coats of primer and 2 coats of red and got it as thick as we could. Do you want to know from the mounting point to the frame or the wheels?
1952 Chevy 3100
1986 Corvette Suspension
350 motor Tune Port Injected
Thinkblue4 Evr is offline   Reply With Quote
Old 08-14-2010, 06:05 PM   #54
sgtusmc
sgtusmc's Avatar
I'm digging the straps. Are you going to put a cushion between the strap and tank, to keep the squeeking down? I like the way you are painting as you go. I bought a gallon of red Rustoleum to paint my garage doors some time ago. I've been painting/brushing the frame in areas I've worked on. Someday I hope to have a completly red frame...lol
Good luck on your build. Looks outstanding so far!
Old 08-14-2010, 07:17 PM   #55
Thinkblue4 Evr
yes that is what we are doing with the painting get a section done paint it up. We where going to put some pieces of rubber in there but when we try to move it we shake the whole truck and it doesnt make any noise at all. Once we get it on the road and notice some squeeking we might put something in there.
1952 Chevy 3100
Old 08-14-2010, 09:52 PM   #56
hotrod1
56 - autocross
hotrod1's Avatar
mounting surface of one wheel mount to the other wheel mount (hub to hub).
Old 08-15-2010, 01:51 AM   #57
Thinkblue4 Evr
Hub to Hub it is approximately 61 1/2 inches.
1952 Chevy 3100
Old 08-16-2010, 10:50 PM   #58
Thinkblue4 Evr
Well got those Coilover shocks mounted in the front and also the sway bar in place. Here they are.
1952 Chevy 3100
Old 08-16-2010, 11:44 PM   #59
Deabt54
Deabt54's Avatar
Nice job, I,m building a 54 with a 89 front c4 (going to start a thread soon.) I'm using a Progressive Automotive cross-member, I've got it all tacted in ready to mount the upper shock mounts. My question is what Alden shock are you using? I have the 657 with a 650 spring rate (spring is about 9 inch long) and it seems to be a bit too long. I'll be posting pics soon.
Deabt54 is offline   Reply With Quote
Old 08-17-2010, 12:30 AM   #60
Thinkblue4 Evr
We have the 657 also and a 450 spring rate and it is 10 inches I believe. And it is a tight fit to get them in there but they fit.
1952 Chevy 3100
Old 08-17-2010, 09:30 PM   #61
Deabt54
Deabt54's Avatar
Thanks for the info, I would also like to ask what are you using for a lower shock mount. I have the one's Progressive sent with the cross member but I'm not liking the location. Can't seem to get the right angal, too far end. Was thinking of going with the Aldan corvette lower mounts. Once again you guys are doing an awesome job.
Old 08-18-2010, 01:39 AM   #62
Thinkblue4 Evr
Well we made our own bottom mount that also connects the sway bar and we had our shocks modified with universal connections so the mounts swivel like a heim joint. you may want to check out flat out engineering the also make a bottom mount.
1952 Chevy 3100
Old 08-18-2010, 09:47 PM   #63
Thinkblue4 Evr
We have now gotten both sway braces attached
1952 Chevy 3100
Old 08-19-2010, 12:24 AM   #64
Kim57
Kim57's Avatar
Looking good guys. Keep up the work.
Kim
Kim57 is offline   Reply With Quote
Old 08-20-2010, 01:55 AM   #65
Thinkblue4 Evr
Got some Bling for the truck today 18x9.5 off a C5 Z06 corvette
1952 Chevy 3100
Old 08-21-2010, 06:33 PM   #66
Thinkblue4 Evr
We rolled the truck out in the sun today to see how everything looked together. This is how it looks.
1952 Chevy 3100
Old 08-22-2010, 02:56 AM   #67
Kim57
Kim57's Avatar
Looks very nice. I like the frame color.
Kim
Old 09-05-2010, 02:07 AM   #68
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Awesome looking build! What are your plans for paint? Also, will you be using the transverse leaf on the rear?
ChuckDriver is offline   Reply With Quote
Old 09-05-2010, 11:17 AM   #69
Thinkblue4 Evr
we will probably be using hot rod flatz from Kustom shop Daytona Blue Pearl is the color. Yes we will be using the mono leaf.
1952 Chevy 3100
Old 09-05-2010, 12:37 PM   #70
av8tr33337
av8tr33337's Avatar
You guys are kicking ASS on this build. I wish I had the time and motivation (and Money) to whip one out that fast. Working by myself, I find myself slowing down and needing a kick in the butt to get back on track. I actually had to move my cab from the back yard to the garage all by myself. Good thing I have a strong back and a weak mind. But that's the way I have done my whole project, putting the dog house on and removing it, the bed, the cab, etc. Thank god for a cherry picker and good old American ingenuity.
Great workmanship and ingenuity. Thanks for sharing it with everybody.
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 09-05-2010, 12:47 PM   #71
sams60gmc
sams60gmc's Avatar
Subscribed. Nice works!
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 09-05-2010, 02:58 PM   #72
Thinkblue4 Evr
Bartman it sure seems slow and we have gotten very lucky on the financial side of things from here on is where all the money is going to go. There sure is a long list of things we need to consider it driveable. This is not going to be a show truck to start we want to drive it and fix it up as we acheive the funds. But we did just get a steering column and the linkage this past week and just finished it up just need to get a picture.
1952 Chevy 3100
Old 09-05-2010, 11:01 PM   #73
Thinkblue4 Evr
Here is the steering column pictures. With our make shift wheel adapter.
1952 Chevy 3100
Old 09-14-2010, 12:01 AM   #74
Thinkblue4 Evr
My Grandfather has caught the truck bug and found a 1959 Chevy Big Window Fleetside with a 305 and 350 trans. We have not found any rust on it and it supposedly runs but it has a bad starter we are told and the guy gave him a new one and a bunch of extra parts to go with it. All in all it is very straight.
1952 Chevy 3100
Old 09-14-2010, 12:55 PM   #75
53GMC
53GMC's Avatar
I love your build! keep up the amazing work! im jealous of your mad skills!!
1953 GMC/S 10 Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=357365
53GMC is offline   Reply With Quote
