Old 09-05-2011, 06:10 PM   #51
Devillusion
Devillusion's Avatar
Re: Project: Crew'd Attitude
Originally Posted by ghettoluxury View Post
When you foamed the roof did you drill from inside the cab or through the roof?
Inside.....cause I plan on putting a full interior in eventually and it will cover it up. Just be careful not to push to hard cause when the bit goes through the first layer, you will punch a dimple into the outer layer causing yourself a crap load of extra work.
So I was looking back through this thread and saw this pic without any explanation
Did you build or buy this snorkel? I need to fab one up on my Burb, I'd appreciate any info you could provide
Ooops, not sure why that picture ended up in this thread...lmfao. Got to many builds on the go. That is from my K5 Diesel trail rig build....Yes built it myself. My "shnorkle"....made from sewer pipe....lol. Just went to the hardware store and started piecing things together. There are more pictures/description in my "gangreen" build thread. I just pieced the connector parts together in series then sanded it so that it all looks like one piece, and there are voids inside along every piece so that any type of debris/water will get stuck there instead of in the filter. Also has a drop pipe just before the air cleaner just incase anything decides to get past or seep in.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 09-05-2011, 06:29 PM   #52
joe231
joe231's Avatar
Lol
If I pm you my email adress, can you send me pics?
Thanks!
CHEVY ONLY
Old 09-05-2011, 07:38 PM   #53
Devillusion
absolutley...
1970 Chevelle
Old 09-05-2011, 07:57 PM   #54
joe231
joe231's Avatar
CHEVY ONLY
Old 09-06-2011, 12:30 AM   #55
Devillusion
sent
1970 Chevelle
Old 09-06-2011, 12:38 AM   #56
joe231
joe231's Avatar
Thanks!
CHEVY ONLY
Old 09-11-2011, 04:09 PM   #57
Devillusion
Managed to get some more work done this weekend. Welded up the cab light mounting holes as the new ones appearantly mount different (caught it before priming...thank god), 2 coats of PPG industrial epoxy, 3 coats of highbuild primer, now just let her bake in the sun for a few weeks while I work on some other stuff and then block it out.
1970 Chevelle
Old 09-11-2011, 05:54 PM   #58
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Looking very nice!!!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 10-26-2011, 07:50 PM   #59
85sierraclassic
85sierraclassic's Avatar
any updates on this?
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 10-26-2011, 08:39 PM   #60
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
x2
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-27-2011, 02:22 AM   #61
Devillusion
Not a whole lot at this point...been busy trying to prep for winter (covering the septic field, putting parts away and just general clean up around the yard before snow flies).
...and brought home another crew cab 4x4....lol. This one was super nice but all in pieces as it was a project that someone lost interest in. Will get shortened as well and have some plans in place for it as well. Small lift, steelie 16x10's with max of 35's, just a nice clean driver. Should be pretty sweet when done too...but time will tell and gotta get this one to a drivable state first.
Did get the front fenders (insides) sanded down ready for primer and paint, guide coated the cab and have it 50% blocked out, dually fenders are prepped, repaired and primed. Other than that...not much has happened yet. Will get some updates here soon.
1970 Chevelle
Old 12-09-2011, 12:01 PM   #62
Devillusion
.....on the fence again about keeping it a dually or swapping over to a srw. Will still stay 8 lug but really don't know what it will look like as a shorty dually. Any opinions?
1970 Chevelle
Old 12-09-2011, 12:12 PM   #63
Gordonr1973
Home Built '87
There was a guy on here that had one...I'll try searching for a pic of it...
Gordon
Old 12-09-2011, 12:15 PM   #64
cochino12
It followed me home?
cochino12's Avatar
Bigger the better
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-09-2011, 12:26 PM   #65
Gordonr1973
Home Built '87
Here's his build:
http://67-72chevytrucks.com/vboard/s...=491551&page=3
Gordon
Old 12-09-2011, 09:15 PM   #66
my4by2
my4by2's Avatar
Go with SRW - it looks cleaner & it's ALWAYS easier to park!!!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 12-09-2011, 09:45 PM   #67
ghettoluxury
ghettoluxury's Avatar
The only way to do a ccsb is with dually fenders. It takes makes the conversion unnoticeable at first sight.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 12-09-2011, 10:07 PM   #68
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
nice work! love the dash!
bowtieguy79 is offline   Reply With Quote
Old 12-11-2011, 09:29 AM   #69
rs72z
rs72z's Avatar
Wink Re: Project: Crew'd Attitude
x2
But i guesse i might be a little biased.
rs72z is offline   Reply With Quote
Old 12-12-2011, 08:22 PM   #70
Dieselwrencher
I'd leave it as a CC SWB DRW. Everyone has a SRW!
Ryan
Old 12-12-2011, 10:47 PM   #71
Devillusion
anyone have any pictures of said dually shorty?
1970 Chevelle
Old 12-12-2011, 11:24 PM   #72
rs72z
rs72z's Avatar
I will try and get the bed back on it again this weekend and take some more pics.
Look in the crewcab sticky there's a red ccsb dually with flames on it there. page 2 post 23.
Old 12-13-2011, 02:39 AM   #73
Devillusion
ya, seen that but hard to tell. I have one of a 4x4 version as well and it looks like they set the fenders back a couple inches to and looks ok. Just need to see some pics I guess to be able to make up my mind. I have a crap load of work to do in the meantime anyways, but would like to decide for wheel/tire combo soon so that I can keep an eye out for the right deals.
1970 Chevelle
Old 12-13-2011, 08:09 PM   #74
Gordonr1973
Home Built '87
Here are some reg cabs...maybe you could use these pics to get a pic of your truck photoshopped?
http://67-72chevytrucks.com/vboard/s...345243&page=53
Gordon
Old 01-10-2012, 12:08 AM   #75
Devillusion
Another dilema I have been fighting with......paint schemes. I have a few going through my head and I'm sure they would all look ok but wouldn't mind some unbiased insight.
** Things to consider: I already have brand new carpet sitting here in grey, can find seats like the black ones in the thread at the wrecker for probably around $300 bux, and have grey door panels already. This truck will be a driver and will see gravel roads, parts runs, kids, and of course shows. I like to keep my builds realistic and as drivable as possible but still keeping the "what the *$&^$" effect if you will.
Not really worried about what has been done or not done at this point with paint cause depending where you are located it all will vary, and technically it has nearly all been done before somewhere.
1) Patina white exterior (hand painted buisness logo on doors and down box sides)
Lipstick red interior
2) Patina white exterior (hand painted buisness logo on doors and down box sides)
Patina white dash with grey carpet, seats, door panels, etc.
Airbrushed/tatoo'd mayhem all over the dash in a collage of old school stuff from the
hot rod era. Then made to look sort of patina'd and old.
3) Bright white exterior
Bright white dash with grey carpet, seats, door panels, etc.
4) Original 73-74? GMC metallic green
Grey interior
5) Original 73-74? GMC metallic green
Tan/doeskin interior
6) Flat black exterior
Grey interior
7) Flat black exterior
....this being said I am now picturing a SRW conversion keeping it 8 bolt pattern and steelies or possibly the smoothies in a 20-22" painted to resemble the steelies with factory hub caps. If I go with factory 16"ers (which I very well might just to be a bit different) I would like to go with a big fat white wall on white wheels. Photoshop is down for a bit or I would chop something up.
Regardless, let me know what you think.
1970 Chevelle
