Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 04-29-2013, 02:40 PM   #51
niceguy678us
Re: 1972 Highlander 6.0/4L80E/LoMax
All right, here goes the next chapter.
I found a listing on craigslist for a 12,000lb Ramsey winch. I went to look at it, pulled the covers and examined the gears, negotiated a VERY apropriate price, and brought her home.
Story goes it was purchased by the guys grandfather "way back in the day", passed down to his dad but he couldn't get it to work right and tossed it in the back of the lawnmower shed in the 80's. He bought the property from his dad and cleaned out the shed. He hooked up the winch to a car battery and the motor ran but it wouldn't spool in or out.
After I got it home I had to pressure wash all the years of grime and grease that was caked all over the thing.
The tag read 9/78, the year I was born!
The gears were like new, I would venture to say it wasn't used more than a dozen times. All the rest of the abuse was only external on the cases, and the years of buildup from riding on or under a front bumper and getting kicked around a dirt floor shed it's whole life.
Complete teardown began.
I got all the housings bead blasted.
All of the mounting bolt holes were stripped out. Not hard to mess those up with cast aluminum. So I brought them to my friends at Dubois Machine Shop to drill them out square so I could heli-coil them.
Next step was paint prep. Here are the pieces all cleaned with paint thinner and ready to go.
I decided to go with Hammered style paint. I've never tried it before but I like the look.
I had a nice long conversation with the Ramsey tech guy. I gave him the part number on the bull gear and he verified that it was in fact an 8000lb winch. Ramsey still makes this model of winch, but they redesigned some of the internal parts back in the mid 80's. So some of the new stuff won't fit. I got the guy to dig up the ancient parts manual for the older style winch. He litterally had to go find it in an old filing cabinet in the back storage room lol. He graciously scanned a copy of the exploded view with all the old part number manifest to go along with it and emailed it to me a few days later.
I found out by cross referencing part numbers between the three different models (RE8000, RE10000 RE12000) that they were all EXACTLY the same winch, with only a few pieces changing between the three. The only difference between the RE8000 and the RE10000 is a different bull gear and worm gear. The only difference between the RE10000 and the RE12000 was a stronger electric motor.
My Blazer is pretty heavy, so I wanted to up the capacity of the RE8000 to the RE1000, and run it like that until the old electric motor goes out. If that happens I'll just order the higher output motor and install it on my winch and that will increase the capacity from 10000 to 12000lbs! So I called the tech guy back and asked if he had access to the old style bull/worm gear. He said they discontinued those parts back in the 80's when they redesigned the winch internals and the new stuff won't fit the older style main shaft.
So I went on a hunt just to see if I could find the matching bull/worm gear set. Sure enough I got luckey. After calling almost every ramsey dealer/repair facility in the country, I struck gold in a warehouse in New Orleans Louisiana of all places. They were actually just sitting there on the back shelf in a warehouse with an inch of dust on them. The guy said they have had them on that shelf for over 14 years (that's as far back as their computer system was installed). This warehouse survived hurricane Katrina! Boy did I feel lucky.
Here they are next to each other for comparison.
I ordered all new gaskets, bearings, bushings, seals, a few new springs, and a new neutral shift lever. That's why the winch wouldn't work because the neutral shifter was broken inside the winch and kept it from engaging the drum to the main shaft.
This is what the shifter slides back and forth, on the main shaft to engage with the drum to make it turn.
Final assembly.
1970 Datsun 240Z
1972 K5 Blazer Highlander
1972 Chevelle
1959 Apache 3100 SWB Fleetside
2006 VTX 1800f
Build thread:
http://67-72chevytrucks.com/vboard/s...ght=highlander
niceguy678us is offline   Reply With Quote
Old 04-30-2013, 10:41 AM   #52
hilljob26
hilljob26's Avatar
i have that exact winch on my car trailer,,very powerful winch
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 12-27-2013, 02:09 PM   #53
Chulisohombre
Chulisohombre's Avatar
Awesome build. Lots of tech and welding skills went into this. Great writ ups to help others.
Chulisohombre is offline   Reply With Quote
Old 04-12-2015, 02:30 PM   #54
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Nice job, do you have any pics of the side of your blazer with your rims and tires? Looking at possibly the same combo for my crew cab build. Thanks Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 06-04-2015, 02:28 PM   #55
niceguy678us
Sorry Trevor, I didn't see you posted on my thread. I can take a pic for you if you want?
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 06-04-2015, 11:15 PM   #56
71blksuper4x4
SWB 4x4 Collector
If you wouldn't mind, I'm on the fence about them, but they are growing on me. Trevor
TREVOR
Old 05-21-2016, 09:27 AM   #57
preciador6
nice work.
preciador6 is offline   Reply With Quote
Old 05-21-2016, 10:06 AM   #58
Greenlee
Greenlee's Avatar
Cool rig Good work and nice rebuild on the winch!
Greenlee is offline   Reply With Quote
Old 05-21-2016, 11:10 AM   #59
Greenlee
Greenlee's Avatar
Old 05-31-2016, 03:44 AM   #60
niceguy678us
Thank you guys. Ol' Blue is still my favorite. We've had a lot of rain down here the last few months and it always floods. It's nice to jump in and get where I need to go when there's 2 foot of water all over town. I haven't been on the trails in about a year, life/work/etc... so that's the only duty she's seen lately. Still reliable and daily driveable.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 01-14-2017, 09:13 AM   #61
rayray767
Super talented !
rayray767 is offline   Reply With Quote
