Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 11-13-2010, 01:39 AM   #51
getbent
Re: which one would you build?
got the new gauges mounted to some 1/4 inch black plexiglass should have them installed tommorow
By null at 2010-11-08
a few more build pics that I took along the way
relays for the gauges
By null at 2010-11-05
the schematics for the wiring, thanks to my buddy with access to alldata
By null at 2010-11-01
the wiring harness before surgery
shedding all of the bull**** I dont need
the harness cleaned up and resized with lots of solder, heatshrink, and wire loom
the harness is back in the truck and all of the sending units are hooked up, more progress tommorow, maybe a first start up video soon
getbent is offline   Reply With Quote
Old 11-14-2010, 01:35 AM   #52
getbent
Old 11-15-2010, 09:49 AM   #53
scooterskoolkustoms
scooterskoolkustoms's Avatar
wow nice build.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 11-15-2010, 04:33 PM   #54
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Sounds good!
Brandon...
"IT ONLY TAKES EVERYTHING YOU GOT!!"
Semper Fi
Chevy350V8 is offline   Reply With Quote
Old 11-17-2010, 09:31 PM   #55
4ofakind
4ofakind's Avatar
Originally Posted by getbent View Post
now gonna work on the dash, try and get some gauges mounted this week
check engine light I dont need no stinkin check engine light
By null at 2010-11-06
stay tuned , more progress updates in a few days!
Would like to know details of what you did to your wiring harness to instal guages and eliminate indicators. I take it you have no smog laws in Fla. Here if a code is thrown you fail smog. Wondering if you are throwing any codes with your harness changes since you are using the stock PCM. I want to copy you if I can still do it legally.
Mal
PS. I'll even give you money for copies of your schematics. :-)
4ofakind is offline   Reply With Quote
Old 11-19-2010, 11:49 PM   #56
getbent
no computer = no codes
Old 11-20-2010, 12:17 AM   #57
4ofakind
4ofakind's Avatar
Man I saw that video and completely missed you're not efi.
Ok I'll be the guinea pig. When I get to it you guys will be the first to know. Thanks for the reply.
Mal
Old 11-21-2010, 07:55 PM   #58
getbent
Mal
complete wiring schematics from alldata a power probe and an ohm meter, tied in new gauges through bulk head connector via factory wiring, was time consuming but its clean and I didnt have to by a wiring harness since I basically made a new one out of the stock harness by eliminating all the stuff I didnt need, fuel injection , air bags, o2 sensors all the smog crap, and a few other cicuits I didnt wnt like cruise controll, ecm,
Old 11-24-2010, 12:48 PM   #59
getbent
had to pull motor out due to low oil pressure, so its back to the machine shop, for a repair,
Old 11-25-2010, 01:46 AM   #60
getbent
should know more come monday
Old 12-01-2010, 08:56 PM   #61
getbent
well its bad news at the machine shop I ate up the #6&8 lobe on the flat tappet cam, everything else looks ok so Im gonna perlace with a hydr roller and go from there, should be rebuilt by the end of next weekish, I must admit the low pressure was a bummer, hopefully round 2 goes better!
Old 12-01-2010, 10:29 PM   #62
spudz
spudz's Avatar
damn man that sux!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 12-01-2010, 11:22 PM   #63
benoit454
Chris
benoit454's Avatar
did you build the motor? if not and you bought it or had it built take it back to them and make them eat it. no reason an all new motor should have low oil pressure much less wipe a lobe off.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 12-02-2010, 10:40 PM   #64
91rcsb
Hey, Just wondering what the part number is on the headers you used.
Thanks!
91rcsb is offline   Reply With Quote
Old 01-03-2011, 11:29 PM   #65
spudz
spudz's Avatar
how bout it man? get the motor back in? Dont let the bad luck get you down. this thing is awesome . this thing is awesome, I'm just waiting for the first burnout video!
