Old 12-10-2010, 11:58 AM   #51
jorgensensc
jorgensensc's Avatar
Re: sound deadener
I did a ton of research on this before I lined the burb. I ended up going with raammat. It got great reviews everywhere I looked. I spoke to the owner of the company and he explained everything about it. I used that for the surface noise and vibration. Next I used the neoprene material for the reflective sound vibration ( it absorbs the soundwaves that are airborn) lastly I used the homedepot insulation roll for heat insulation. Then carpet over the top. I must say it quited down the burb substantially. I used it on the floor, ceiling, and sides, including the doors and cargo area. With a big block and pretty loud mufflers it did a great job quieting it down. Now the doors shut with a new car thud, and not a hollow sounding rattle. Hope this helps.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-10-2010, 12:02 PM   #52
greasemonkey71
Re: sound deadener
how does this stuff work for heat insulation
i dont have a heater
and i live in colorado and the truck wont be garaged
greasemonkey71 is offline   Reply With Quote
Old 12-10-2010, 12:05 PM   #53
jorgensensc
Re: sound deadener
Also, this is a great read.
http://www.sounddeadenershowdown.com/
He had a great comparison chart, but I guess he got rid of it. Wish I still had a copy of it. It had all the comparisons of the different products.
Shawn
Old 12-10-2010, 02:27 PM   #54
BearFlagRepublic
Re: sound deadener
I've had good luck with the Fat Mat product in the past. It worked as well as dynamat at a fraction of the price. I wouldn't hesitate to recommend it to anyone.
As far as heat shielding, I haven't noticed any difference from the stock carpet in my DD.
BearFlagRepublic is offline   Reply With Quote
Old 12-10-2010, 02:32 PM   #55
Ipaintgrt
Re: sound deadener
Check out this thread, Silver Dollar made his own sound deadener.
http://67-72chevytrucks.com/vboard/s...=427417&page=9 post #225
Ipaintgrt is offline   Reply With Quote
Old 12-10-2010, 02:49 PM   #56
greasemonkey71
Re: sound deadener
Originally Posted by lakeroadster View Post
Uhmm... not according to the MSDS it isn't. Protecto Wrap BT25XL Window & Door Sealing Tape.
Here is the MSDS http://www.protectowrap.com/pdf/msds/bt25xl-msds.pdf
It clearly states that the main ingredients are:
20-40% Asphalt
10-20% Heavy Naphthenic Distillate (more petroleum)
10-20% Polymers
10-20% Calcium Carbonate (used as a filler)
Wow.... from one Colorado guy to another, you need a heater! What happened to the original heater? If it is gone and the truck has been modified such that replacing it is not practical have you thought about adding one of these?
http://www.southernrods.com/categori...oduct-860.html
http://www.speedwaymotors.com/Street-Rod-Heaters.html
well, im sstationed in san diego and i just got the truck like 2 weeks ago and the heater hoses are not hooked up correctly.
the PO said the heater never worked when he got it
but he said he never really needed it
