Old 11-06-2010, 10:59 PM   #51
jason65
Registerd User
jason65's Avatar
Re: #3 The Sickness Continues
Congrats dude. It looks like a good truck.
jason65 is offline   Reply With Quote
Old 11-06-2010, 11:06 PM   #52
protrash64
Resistance is Futile
protrash64's Avatar
Originally Posted by TimE View Post
Lookin good Jeff!
Originally Posted by daverod View Post
Come on tomorrow.
Thanx guys.......yeah, come on!!!!
Thanx Jason, where you been, man????????
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-06-2010, 11:16 PM   #53
jason65
Registerd User
jason65's Avatar
Trying to keep up with my costomers cars and the cars at work. 2 trucks, a burb and a blazer. You have got to be one busy guy.
Old 11-07-2010, 12:03 PM   #54
daverod
SSN 706
daverod's Avatar
Done yet? Whats the drop on the spindles? I was thinking about puttting some on my 64 but I think my headers will drag. Guess I'll have to get some shorty headers. Should heave got them in the first place.
daverod is offline   Reply With Quote
Old 11-07-2010, 09:15 PM   #55
protrash64
protrash64's Avatar
Here it is at its new height!!!! Like it alot!! Dave, the spindles are 2.5''. First up are the brakes and then went to battle with the rear. One bolt came out like it was brand new and three fought and lost.......
The bottom spring bolts got ground down and pounded up thru the trailing arm. The tops came out by using the air chisel and folding the retaining plates and then sawing off the bolt with a sawzall. I had an extra set, so I didnt care about preserving them. Visit the pic of the aftermath . Included a pic of the 4''HD springs I had for comparison.
Old 11-07-2010, 09:22 PM   #56
protrash64
protrash64's Avatar
Didn't get the panhard in as I was getting tired, but wanted to drop it down and see what it looked like. Here it is. Started mocking up the ms/cyl and went out and got new brake lines. The people at Autozone didnt know what they were......I took them in back and showed them and then picked up flare fittings and so forth.
I was going to cut a gasket out of a sheet of material I had and found three T-stat gaskets. Check it out; they're perfect for brake cylinders!? Lucky I guess. Bolted in the ms/cyl so I can start working some lines in at some point.
Later........
Old 11-07-2010, 11:19 PM   #57
Dinos63
chevy only
Dinos63's Avatar
duude nice work kat!!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 11-07-2010, 11:29 PM   #58
daverod
SSN 706
daverod's Avatar
Looks like a good day.
Old 11-08-2010, 11:13 AM   #59
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
I would love to stop by and check out your builds in person some day....
BTW, the only qualification Auto-Zone has for employees is that they have half a brain and the propensity to argue with every customer.
Example; telling me the 400 small block valve cover gaskets are the same as my 400 Pontiac.... IDIOTS!
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 11-08-2010, 03:45 PM   #60
daverod
SSN 706
daverod's Avatar
How about some shots of your headers / exhaust system?
Old 11-08-2010, 08:29 PM   #61
protrash64
protrash64's Avatar
Dave, this thing is rollin' ramhorns with about 2'' pipe. It's only a 283. The pipe is tucked up hard so clearance isnt an issue at this hite.
Old 11-09-2010, 09:30 PM   #62
scum1
scum1's Avatar
hell ya man looks awesome
scum1 is offline   Reply With Quote
Old 11-14-2010, 09:46 AM   #63
protrash64
protrash64's Avatar
Thanx dude!!!
Just worked on the brake lines and started bleeding out the system. The front was easy and the rear is giving me grief. Pumping the brakes and using a vac to get it through......also found my coils not seated correctly so I wrestled those around and got another 3/4'' drop ..
Old 11-14-2010, 02:26 PM   #64
66-PMD-GMC
66-PMD-GMC's Avatar
Bleeding the brakes using a jar of brake fluid and a line from the bleeder works nice.
I have used this method for decades with fantastic results.
Projects..
440CID 2X4 Pontiac
Old 11-14-2010, 10:17 PM   #65
protrash64
protrash64's Avatar
OK, the brakes are still F'n with me, but the fluid is through and its just a matter of getting the rear done. Worked on some other stuff today....
Drivers window regulator was shot so I replaced it. I guess the PO lubed the regulators with every bearing service!! They were covered in grease!!! I actually used engine degreaser and rags to clean up the inside of the door. Took apart my windows and lubed everything and got it back together. Also threw some insulation in the door panels before reinstalling.
Took a shot of the door without the vent; damn, one piece windows would look good on these doors!!
Old 11-14-2010, 11:55 PM   #66
daverod
SSN 706
daverod's Avatar
Do they make 1 piece windows? Think I'll stick some insulation in my doors.
Old 11-14-2010, 11:58 PM   #67
daverod
SSN 706
daverod's Avatar
Originally Posted by protrash64 View Post
Thanx dude!!!
Almost an 1" for free.
Old 11-15-2010, 02:27 AM   #68
Captainfab
60-66 Nut
Coming along nicely Jeff.
Yep, one piece windows are on the list for my Burb........
Old 11-15-2010, 11:29 PM   #69
protrash64
protrash64's Avatar
I think there is a one piec kit, but I have read some negative things about it; not sure how it works at all. I just know those doors look clean without the vent windows.
Thanx Cap'n. I took that picture because I stopped to grab a drink and looked at the door.....they look awesome. I imagine you should be able to sort out the one piece window kit.
Picked up some speed bleeders tonite. I'll put them in tomorrow and see if I can get the rear done. It's hard to bleed stuff by yourself.....
Old 12-04-2010, 12:48 AM   #70
protrash64
protrash64's Avatar
Been very busy working many hours and then had people come in for T-giving. Therefore I haven't posted an update in awhile.
I decided to look into the rear brakes and they were a mess. They were due for a rebuild so I decided to get it all done. Didnt take a bunch of pics as we've all been there. First pic the old set-up; adjusters all the way out and the shoes cracked in the center at the rivets. Drums were grooved and wheel cylinders were shot. One was frozen, the other beginning to leak. Got all my parts at local auto stores. Wheel cylinders, shoes, hardware and new drums. Used the FAQ thread to stare at some pics of a drum rebuild as it's been awhile. Goes together easily after you start doing it. Have a pic of the completed brakes and one of the new tires mounted on the 6-lug rally wheels. Went with 235/70/15's for the old school kinda look.
I'm also adding relays to the headlites and repainting the grill and bumper as I hated the black. They are silver now....more pics soon.
Old 12-25-2010, 02:47 PM   #71
protrash64
protrash64's Avatar
I've worked on this one quite a bit and haven't updated in awhile. Just drove it around today for the first time and it was nice.
Let's see: Relayed the headlites, repainted the grill and bumper, bolted on the Rally's with 235/70/15's, new hoses, filters, cut out about 20' of unused wiring, new brakes, installed volt and tach, rewired a bunch of stupid crap, tool box in but not mounted.......you all know how it goes!!! Anyway, had a fuel pump on the list yesterday and decided not to get it and sure as sh!t it leaks!! Easy one to fix.
Here are some pics for today..........Merry X-mas
Old 12-25-2010, 03:04 PM   #72
lolife99
67-72 parts collector,…
lolife99's Avatar
Everything you have done,... has made it 100% better.
Perfect.
Keith
Convert to disc brakes.
Old 12-25-2010, 03:09 PM   #73
protrash64
protrash64's Avatar
Thanks lolife!!!! More projects to come!!!!
Old 12-25-2010, 06:48 PM   #74
daverod
SSN 706
daverod's Avatar
Man that thing is straight. Looking good. Put some miles on that thing. I was wishing I had your air chisel today. Ever get the pan bar on?
Old 12-25-2010, 09:40 PM   #75
protrash64
protrash64's Avatar
Ola Amigo!!........I wish it looked as good as it does in the pics!! I have not put the panhard on and I'm wondering if I even need to do it??? No clearance issues and it rides great.
My air chisel is a cheapo, but it comes in handy when its needed.
