12-07-2013, 03:13 PM | #51 |
Carpe manana
Re: Blazer sliding window
Here's an excerpt from the install instructs that shows one top style needs to be trimmed (style #1) to accept the slider but suggests the OEM gasket is re-used for both types. Which type of top has the glass in-line with the fiberglass (style #2) and which has the glass offset as shown in the diagram? I think it's a double wall that needs to be cut.
Either way these instructs show differing gasket styles that I assume represent single vs. double wall tops.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
12-07-2013, 07:38 PM | #52 |
I definitely like the single slider much better than the double. Looks a lot cleaner to me. Nice blazer guana.
12-08-2013, 10:08 PM | #53 |
I like the single slider as well. I may have to get mine done this way.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
12-09-2013, 03:36 PM | #54 |
The 73 sliders do fit I've seen them in 69-72 blazers I have a set in my garage I was planning to use but never got around to it. Don't know if I ever will really. I just bought that STC fast trac top that was posted a few days ago... Anyone need a double wall top pm me.
12-17-2013, 01:26 AM | #55 |
I thought the window openings were a different size?
12-17-2013, 03:54 PM | #56 |
I thought they were different as well.
12-17-2013, 06:10 PM | #57 |
I upload some photos
12-17-2013, 11:22 PM | #58 |
There is no way 73 and up windows fit in a 69-72 top without significant modification to one or both. But I will wait for pictures....
12-18-2013, 06:09 PM | #59 |
I agree they look different.
12-18-2013, 07:34 PM | #60 |
12-18-2013, 07:45 PM | #61 |
As I did say I do have a pair but I never installed them. I did take a measurement they are the same size . That's as far as I got . They been sitting in the garage. Maybe they fit only a double wall or single wall I just don't know . I do know I have seen several 69-72 Blazers online and on this site with this style window. Just don't know what's all involved in installing them . I think I would just go to safe-lite auto glass and ask
12-19-2013, 06:50 PM | #62 |
That is a picture of member Guana's Blazer from earlier in this thread. He didn't mention that they were 73+ sliders installed in a 69-72 top, and I don't think they are. It would be like putting a square peg in a round hole. overall measurement might be similar, but the shape is different.
12-19-2013, 07:37 PM | #63 |
If that style slider window is a 69-72 in Guan's Blazer that would really surprise me. As I was told the 69-72 slider window was a two sliding combo. Yes that is Guana' blazer in the photo. But I don't think it's the 69-72 blazer slider he's using. I've seen photo ads with the double combo. But again never got to far on my window switch out. Maybe they did make two style sliding window. Another member says they do fit with some trim work. The square peg and round hole would sure be a lot more trim work... However the shape appeared the same last Time I held it up to my 72 window. I think Guana need to get into this post. I'd love to hear what he has to say about the slider he has.
12-19-2013, 08:11 PM | #64 |
Pretty sure the 73 up windows are a couple inches bigger all around. There'd be a pretty good amount of trimming and glass work to make it fit and look right.
12-20-2013, 03:50 AM | #65 |
I would think of it was as simple as picking up some sliding windows from a 73 up anyone wanting the sliders would do it. I have owned both years and am pretty sure the 73 up are larger. Wouldn't the solid windows interchange if they were the same size?
06-08-2019, 08:30 AM | #66 |
Carpe manana
Finally got a set in use. The double pane slider frame is thinner where it inserts into the gasket groove than the single pane examples much like the difference between single vs double wall glass (single wall thinner). Therefore, I went with these 2x pane examples to ease installation into the 1x wall top. That said, these replaced the thicker double pane glass that I had installed into the single wall top and that worked so I suspect a single pane slider would also without trimming the top.
06-08-2019, 09:38 AM | #67 |
OMG! SOOO Jello! Very nice. I guess I better stop buying houses and get back to work on that truck of mine! Let me know if anyone has a set of these babies they just cannot stand to continue to own.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
06-08-2019, 08:17 PM | #68 |
Nice. Mine are still sitting in storage waiting for the day. I have two single wall tops now so I’m going to restore the best one and keep the other for a spare. I’m still working on my ls3 install so it will probably be next year before I get to it.
06-11-2019, 09:32 AM | #69 |
I love the look of the Double slider, here are mine in my JIMMY!
06-14-2019, 09:50 AM | #70 |
I want a set! If a set of the single slider that fit the 69-72 Blazers came available I would be all over them but think that even the double sliders would be good.
If anyone has a lead on a set, either style, let me know! |
06-21-2019, 03:46 PM | #71 |
'72 K5, known as 'the Fox.' |
06-22-2019, 09:53 AM | #72 |
https://www.motorcityk5.com/i-13101-...91-blazer.html
It appears to be close to a 73-91, but you’d have to flip the window upside down to match the first gen shape. Without them side by side and measured it’s tough to tell. They are close but look to be elongated on the 73+
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. Last edited by Chulisohombre; 06-22-2019 at 10:00 AM. |
06-22-2019, 11:05 AM | #73 |
Those are not 73+ sliders. There were two types available from the aftermarket and those are the more rare of the two. I have only seen two blazers with them.
