Old 03-04-2011, 07:50 PM   #51
sdwolff98
Turning Wrenches Daily
Re: 1964 GMC 3/4 ton build :D
ok been a little busy bee today got my lokar shifter modded to fit the 6l80e trans. Ordered the 2wd tail shaft housing today via reliable chevy here in richardson and should have it in next week so I can stab the engine next sat afternoon . here are some shots of the modded lokar shifter.
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 03-04-2011, 08:10 PM   #52
trevrolet65
Good work, are those trans. hard to adjust the shift linkages? Newest I ever mess with is 700r4. Keep up the good work.
trevrolet65 is offline   Reply With Quote
Old 03-04-2011, 10:27 PM   #53
sdwolff98
naah they are almost the same as the 700r4 same number of stops actually. The 700 lever fit that trans perfectly without any problems just had to space it to clear the casing. Will have some more pics up next saturday when I get the 2wd tail shaft housing in hand and in place thinking I may have to trim the ribs on it but will know more when I have the part in my hand and get it in place.
Sean
Old 03-07-2011, 01:07 PM   #54
sdwolff98
Ok the big week is coming soon another 40 hours of wiring work in the future. I orde3red direct from GM parts direct a 2009 cadillac l92/l9h harness for my truck. Once I get it in hand I will be taking pictures as I do the conversion to standalone and put them on here and my website. I also orders the fuseblock and relay modules for this engine as well so should have them soon also.
sean
Old 03-10-2011, 12:59 PM   #55
sdwolff98
ok more progress got the oil pressure sensor in place and the water temp sensor done as well. pictures to follow
Waiting on gm parts direct for my harness at this time, will be picking up the 6l80 tailshaft saturday after my gear head meeting with pickups n panels.
Sean
the oil pressure gauge uses a 1/8 inch 27 thread pipe tap to get it into place. worked out beautifully. will be reassembling it and checking for leaks this weekend. I have oil splashed on that side of the cylinder block with no clear spot of origin so will be checking things there carefully.
Old 03-10-2011, 01:04 PM   #56
sdwolff98
here is the water temp sensor. it takes the same tap as the oil pressure on the gauge package I bought from TPI gauges.
Sean
Old 03-12-2011, 12:10 AM   #57
sdwolff98
ok gto the tailhousing in and was fiddling with it tonight amongst working on the brakes think I need to trim the mount bracket because it is at a slight angle right now not that that bothers me any I like quirky things in vehicles in the right places lol.
Take an eyeball,
Sean
Old 03-12-2011, 01:22 AM   #58
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Some how I have missed this build. Nice work!! Keep it up.
Alan's Classic is offline   Reply With Quote
Old 03-12-2011, 10:55 AM   #59
trevrolet65
Nice work, I'd like to come out one day and check that out, maybe learn something smart. My skills involve only one kind of computer, HEI, very little TBI, The rest stumps me alot. Keep up the good work, and good pics.
Old 03-12-2011, 03:12 PM   #60
sdwolff98
yeah give me a shout I am usually off on saturdays so it would be a good time to catch me. I am taking the brake rotors back to the machinist so he can machine the sapcer bushing a bit more to get them where they slided on the studs better there is not enough play in them atm to make up for heat expansion during braking so we are going to fix that.
Sean
Old 03-13-2011, 11:51 PM   #61
sdwolff98
Found another interesting ls mod on another forum quite by accident today . check this out cheap high mount ac bracket using existing parts from chevy. Will have to change to an older style water pump to make it happen but looks dammed promising. Might even look at some cool flex hoses and see if they can route around the bracket assembly.
Sean
below is the link to the forum where they did this Cheers!
http://www.maliburacing.com/forum/vi...p?f=34&t=79059
Old 03-16-2011, 10:13 PM   #62
trevrolet65
That's a cool trick. So tbi 4.3, cut, shim-brace, ac lines, metering orfice, accumelater,and oil replace the o'rings? Neat.
Old 03-16-2011, 10:25 PM   #63
sdwolff98
Yeah Friday going to get an older truck water pump on order and see what I can do with it and the electronic throttle body. Hoping it will work just need to turn the neck a slight bit and get it aimed right.
Sean
Old 03-16-2011, 10:41 PM   #64
trevrolet65
Be carefull heating that aluminum up, once it melts it floods. Alternate top to bottem on both sides of the tube while useing the cheater pipe. Maybe put a wet rag on the motor?
Old 03-16-2011, 11:25 PM   #65
sdwolff98
naaah will let my radiator expert do that one he does some neat stuff the pump will be off the engine when that happens .
Sean
Old 03-21-2011, 02:49 PM   #66
sdwolff98
WOOHOOOO@!!!!!!!!!!!!!!!!!!!! Scored an 08 gmc truck engine harness 6.2 HO engine new in box from a junkyard in IL for 170 with shipping!!!!!!!! Will be in next week and will be getting lotsa pictures of it while I do the strip down and convert to standalone!!!! Harness will be in tommorrow afternoon so will have pics coming up soon of the teardown and rebuild to make it standalone.
Sean
I am attaching a pdf scan of one of the wiring schematicsI have aquired for those that are looking to do their own harnesses. This one is from a 2007 escalade 6.2 engine. I also have one for the 2008 chevy silverado and 2009 escalade if you want a copy emailed to you.
Old 03-24-2011, 01:35 AM   #67
sdwolff98
Ok been spending a little time on the ac bracket idea and here are some more pics of what I have so far. Trying to get a used ac compressor and alternator together to get them in place so I figure out how long a belt I am going to need for this setup. I got 2 of the 3 braces done and will include some pics of them and the bracket together.
Sean
Old 03-25-2011, 10:20 PM   #68
sdwolff98
Ok Gang,
Have the harness stripped and ready to take out the chaff have everything labled so I know what is what in this mass of wires lol. Here are some shots of this mess in my computer room.
Sean
Old 03-27-2011, 02:16 PM   #69
trevrolet65
Originally Posted by sdwolff98 View Post
Ok Gang,
Sean
That is why you don't eat spaghetti in the computer room lol.
Old 03-27-2011, 02:20 PM   #70
sdwolff98
Be the best kinda spaghetti when finished and the motor will run. Gonna be adding a few circuits into the firewall plug for the mil and data link cisrcuits and also the throttle pedal wiring. Definielty got a busy few weeks ahead of me. I am currently waiting on the harness tools to come in to me at oreillys so I can de pin what I dont need and canabilize it into the harness mods.
Sean
Old 03-28-2011, 12:36 AM   #71
sdwolff98
well got the harness torn down just waiting on tools now to start taking out the connections I do not need and figuring out what the heck some of these wires go to in the scheme of things.
Sean
Old 04-01-2011, 08:24 PM   #72
sdwolff98
will have pics up tommorrow night the engine is in the truck and with the way it is mounted the transmission brackets just about slid into place on the frame mounting locations. Little bit tight on the radiator but will know more in the next few weeks when I throw the core support back and and check things out. I am definitely going to need headers the factory exahust does not clear the frame or mounts.
Sean
Old 04-05-2011, 07:39 PM   #73
sdwolff98
nearly finished with the fuel injection wiring section of the harness just waiting on a few parts to come in for it at the moment. Working on the mounting plate next for the injection harness. Will be throwing up some pics here pretty soon.
sean
Old 04-06-2011, 03:04 PM   #74
sdwolff98
got the engine dropped in place couple of days ago and am working on where I need adjustments and such. Here are some pics of the work so far!
Sean
Old 04-06-2011, 03:06 PM   #75
sdwolff98
here are some pics of the issues i am having with the exhaust manifolds from the engine going to have to go with headers it is looking like to me.
Sean
