Old 01-14-2011, 03:52 PM   #51
HuggerCST
HuggerCST's Avatar
Re: Fuel filler options
I agree, that is something to be mindfull of when building one, and also when refueling. My cap is not vented, so there are no fumes or fuel there unless I remove the cap, but it will burp fuel out when refueling occasionally, so there is a danger of fire.
Originally Posted by 502ss View Post
all wires will be incased in an abrasive resistant jacket.
That's another thing that should be done because the wires will be flexed everytime the door is opened.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 01-14-2011, 11:51 PM   #52
swamp rat
swamp rat's Avatar
Yeah I thought about that too. Mixing electrical and gas fumes could end badly. I plan to convert the tail lights to led and because the light will be hinged the harness will need to be redone anyway so all connections will be soldered and all wires will be incased in an abrasive resistant jacket. There will be a plug where the new harness connects into the existing harness but this plug will be located under the truck far away from the filler neck.
It doesn't hurt to take the extra steps to avoid a possible issue!
There ya go! What kinda jacket would you be refering to? Personally really like the rear tail light and marker light mods, just for me it didn't seem to be the best choice, now if i had a 1/2T short box it would be a different story..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-15-2011, 12:27 AM   #53
dixietruck71
dixietruck71's Avatar
Originally Posted by 69step4x4 View Post
this is mine on my stepside, but truck is painted now
this is my favorite idea. i think i could pull it off with out having to weld to the body. i dont want to burn my paint yet.
71 gme Sierra Grande lwb.
68 Rambler American 2 door
75 jeep cj5
dixietruck71 is offline   Reply With Quote
Old 01-15-2011, 02:42 AM   #54
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Originally Posted by swamp rat View Post
One comment or concern that was brought up in a different thread that i was reading that i have not seen here is that some folks have been a bit concerned about the possibility of sparks, bad wire or connection and gas fumes after filling. I cant speak first hand of this but thought at least you should be aware of it if you do a light filler mod be it ether tail light or rear marker..
Good point, I hadn't thought of that. I think as long as all of your wiring is done properly it shouldn't cause issue, look at all the cars with in-tank pumps these days, and those are much higher current than a tail light. Still it's better to be safe than sorry, thanks for the heads up.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-15-2011, 04:40 AM   #55
ls1nova71
ls1nova71's Avatar
1956 Chevys had the fuel filler behind the taillight from the factory, and I've never heard of one of them ever blowing up because of it. I've been driving my station wagon with the taillight filler mod for several years, without incident. Hope I didn'justt jinx myself!
ls1nova71 is offline   Reply With Quote
Old 01-15-2011, 05:05 AM   #56
Jacfourteen
I really doubt you will ever will have a problem, but it never hurts to think ahead and play it safe.
Old 01-15-2011, 11:07 AM   #57
502ss
502ss's Avatar
I like the spark resistant material located on this page!
http://www.mcmaster.com/#catalog/116/803/=alnooi
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
Old 01-15-2011, 11:10 AM   #58
502ss
502ss's Avatar
Bingo! The wires will be clamped to the hinge inside of a protective coating!
Old 01-15-2011, 12:53 PM   #59
Hart_Rod
Hart_Rod's Avatar
Here's mine. No cuttin or welding on the bed....
Hart_Rod is offline   Reply With Quote
Old 01-15-2011, 12:57 PM   #60
swamp rat
swamp rat's Avatar
Thanks for the link!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-15-2011, 01:18 PM   #61
dixietruck71
hart_rod i like it, so simple its retarded. does that hinge have like a detent built into it that keeps it from flopping in the closed position?
75 jeep cj5
Old 01-15-2011, 05:15 PM   #62
502ss
502ss's Avatar
Hart_rod very nice! Can you share where you found the hinge? It almost looks like something I have seen on a kitchen cabinet?
Old 01-15-2011, 06:39 PM   #63
Hart_Rod
Hart_Rod's Avatar
It's spring loaded open and closed although I use the factory tail light screw to keep it "locked".
Bingo! Picked 2 of them up a Home Depot for about $5. Here's a picture and part number.
Old 01-15-2011, 06:51 PM   #64
superchevy
Got big-block?
superchevy's Avatar
Here's mine.
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 01-15-2011, 08:06 PM   #65
TugOwar
I like this thread, lots of great ideas accompanied by photos. I think I like the side marker light idea best. The in-bed/top rail options seem the simplest but I may want to run a camper shell or tonneau cover at some point. Already have the blazer tank just have to find the time to work on the install. Keep the ideas coming!
TugOwar is offline   Reply With Quote
Old 01-15-2011, 10:36 PM   #66
swamp rat
swamp rat's Avatar
Originally Posted by superchevy View Post
Here's mine.
Nice idea!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-15-2011, 10:49 PM   #67
502ss
502ss's Avatar
Your the man! I will be off to home depot tomorrow morning just so I can start mocking up the design!
Old 01-15-2011, 11:20 PM   #68
Hart_Rod
Hart_Rod's Avatar
Here's mine.
I really like that! Have you thought about putting a hinged cover over it?
Old 01-16-2011, 12:03 AM   #69
maynardtruckin
maynardtruckin's Avatar
LMAO sorry bro didnt mean to piss in your wheaties
yea I already have a suburban tank in the truck so my options are limited.
First love the wheaties bit, but just because you have the blazer/burb tank does not mean your options are limited. You are limited only by your imagination, skill, and equipment!
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 01-16-2011, 11:02 PM   #70
502ss
502ss's Avatar
Tackled my hinged tail light for my gas filler. I have 5 hours in the project and it's functional. I have some cleaning up of the design and some small adjustments to make but it works. Next will be to tackle the filler neck and wiring. Pics can be seen here.....
http://67-72chevytrucks.com/vboard/s...=1#post4416666
Old 01-16-2011, 11:28 PM   #71
weircc
weircc's Avatar
here's mine hope this helps
weircc is offline   Reply With Quote
Old 01-17-2011, 06:24 PM   #72
thesledhead
thesledhead's Avatar
Mine has a spring attached to the side of the leans backing plate. That spring is mounted at an angle so that it cams over and holds it open, or closed. I simply push on the bottom of the lens to open it.
is that a kit ??? looks good
Wow that looks way to simple
thanks guys they all look great and your giving me some good ideas
thesledhead is offline   Reply With Quote
Old 02-13-2011, 11:02 PM   #73
RaceAGMC
RaceAGMC's Avatar
Can you explain to me why you have to run the trim with your set up? Maybe show me too?
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 02-13-2011, 11:36 PM   #74
Stano
Stano's Avatar
Heres mine i did several years ago. 88-98 cap and opening.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 02-14-2011, 10:30 AM   #75
HuggerCST
HuggerCST's Avatar
If you see it without the trim, you can see where I had to enlarge the opening at the bottom to give the lens clearance when it opens. The trim hides this.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
