Old 08-21-2013, 08:03 PM   #51
benscool1
benscool1's Avatar
Re: 1986 Short bed 2WD
Any info or pics on how you wired the windstar fan? I picked one up for my 84 today.
Ben
84 C10 Silverado
14 Silverado Z71
benscool1 is offline   Reply With Quote
Old 09-08-2013, 11:16 AM   #52
MalibuSSwagon
Sorry I missed your post. I used the two relay circuit outlined in the GM diagram below. I was able to use the dual fan control on my TPI ecm to control them. If you are TBI or carb, you can use a 1986 2.8 V6 Camaro fan switch to control the fans in place of the ECM, it screws into a 3/8" NPT coolant port on your engine. Turns on the fans at 190.
MalibuSSwagon is offline   Reply With Quote
Old 09-21-2013, 01:40 PM   #53
MalibuSSwagon
Shortbeds are heavier than they look, but three of us managed it.
One end of the broken spring, the other end is completely snapped off. Maybe from overloading? I've towed a few times at 10k+ gross weight; factory rating is 6500 gross.
Picking up 8/1 HD springs at a local spring shop for 265 each.
Old 09-24-2013, 02:37 PM   #54
MalibuSSwagon
Went down to my local spring shop today and picked up the new rear leaf springs. It was a pretty good hit to the wallet but I need them; I also got new u-bolt bent up and the eye bolts.
My new 3/4 ton springs:
Old 09-24-2013, 04:46 PM   #55
fxdxharley
Just a nother gear head
fxdxharley's Avatar
nice having the spring shop close by. Did they have to make the springs for you? i need some for my blazer. just havent given them a call yet. What did they set you back?
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 09-24-2013, 05:08 PM   #56
MalibuSSwagon
Just give them a ring, they had 4 of these springs in stock. I paid 530 out the door for the pair.
Old 09-24-2013, 05:14 PM   #57
MalibuSSwagon
Part numbers and bolt sizes for a heavy half rear spring conversion.
Old 09-24-2013, 08:58 PM   #58
MalibuSSwagon
And done!
Mostly a one man job here, got some help from my father lining up the springs to insert the eye bolts.
Got the truck back on the ground after some undercoating was applied to the frame. Measuring at the hitch, it looks like I gained about 3 inches of height. yikes! I figure the springs are going to settle some, but maybe its time to put on lowering shackles while it's easy.
Old 09-25-2013, 01:46 PM   #59
fxdxharley
fxdxharley's Avatar
thats a fair price. you'll pay that plus shipping threw lmc or any other mail order place.
2013 HD FLHX
2000 harley fxdx
Old 10-02-2013, 08:27 PM   #60
jpnh
jpnh's Avatar
looks good/beefy springs-jeff
jpnh is offline   Reply With Quote
Old 11-24-2013, 11:52 AM   #61
MalibuSSwagon
Teaser pic...
Going to need a new air dam
Old 11-28-2013, 10:51 AM   #62
MalibuSSwagon
Done besides the exhaust.
Old 11-28-2013, 12:03 PM   #63
jpnh
jpnh's Avatar
good progress/looks good-jeff
Old 11-28-2013, 01:10 PM   #64
bohmankid
bohmankid's Avatar
So are you still planning on putting the supercharger on? How's the tpi running? Truck looks great, you've definitely turned it around!
bohmankid is offline   Reply With Quote
Old 11-28-2013, 08:22 PM   #65
MalibuSSwagon
Thanks Jeff!
TPI is great! Still starts right up, no issues if the truck sits for a few weeks. I am planning on installing the supercharger if I can design and fabricate a mount for it. That may not happen.
Old 12-05-2013, 10:00 PM   #66
MalibuSSwagon
Headers coated, ready to be installed. And a cat.
Old 12-09-2013, 02:08 PM   #67
MalibuSSwagon
The Road Warrior, back for more.
Old 01-01-2014, 12:56 PM   #68
Malo83
Cruzzzn' Vet
Malo83's Avatar
Hats off to you Bro! great job, what's in the future for the Lady
Malo83 is offline   Reply With Quote
Old 04-03-2014, 04:12 PM   #69
MalibuSSwagon
Well nothing new to report. I let her sit outside all winter with a dead battery. Pulled the battery and charged up a spare one I had, put it in today and she lit off as soon as I hit the key! Gotta love EFI.
Took her for a ride to pickup some parts for my Olds, and man it's running great. 3/4ton springs make for a rough ride on these back country roads however.
Sitting nose to nose with my Olds Custom Cruiser
Old 05-04-2014, 10:10 AM   #70
MalibuSSwagon
Started the interior project this week..
All surface rust on the drivers side pan. Gonna clean it all up and lay down fresh jute. Dyeing the carpet black and spraying bedliner on the kick panels to finish it off.
Old 05-23-2014, 09:51 PM   #71
MalibuSSwagon
Time for a front end rebuild and other things that need attention.
Half of my drop kit is here too.
Old 06-23-2014, 10:52 PM   #72
MalibuSSwagon
Front end done! All new Moog wear parts, Western Chassis 2.5" drop spindles and rear hanger kit.
Quite a difference from what I started with 5 years ago.
I did also finish the interior, came out pretty good for $25 invested. Lately I've been taking a page out of TX Firefighter's book and saving cash to buy things. In this case I got a windfall when I turned in a bunch of cores and cat convertors to the local recycler, ended up with way more cash than I was expecting.
Old 06-24-2014, 12:53 PM   #73
jpnh
jpnh's Avatar
sweet/getting there-jeff
Old 06-25-2014, 02:00 AM   #74
Hankster
Hankster's Avatar
Just read through your whole thread, I must say I dig the tpi and It looks way better now that you've lowered it!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 06-25-2014, 03:30 AM   #75
bigwheel15
bigwheel15's Avatar
Quick question, id assume the grill you have currently is the correct one for your year, 85-87 with a few sections painted black; am I correct? I really like it.
bigwheel15 is offline   Reply With Quote
