Old 03-09-2016, 05:37 PM   #51
rwade
rwade's Avatar
Re: Daves new 68 chevy swb
If you put a 3/8" spacer wouldn't you need to put some longer wheel studs? Seems like you want to know you've got all the thread you can get. A lot of mass there.
rwade is offline   Reply With Quote
Old 03-09-2016, 10:09 PM   #52
Woodnears
I had them machined down because I'm utilizing a disc brake with the 3" rotor bore. And as an added benefit. I can rotate tires without an issue. Does anyone know if the 68 ball joint taper is smaller than 72? My supposed 72 spindles don't fit the 72 ball joint.
Woodnears is offline   Reply With Quote
Old 03-09-2016, 11:02 PM   #53
lolife99
67-72 parts collector,…
lolife99's Avatar
63-70 balljoints are different from 71-72 and 73-87.
The easiest way to determine your spindle "year" is to identify the upper balljoint or outer tie rod.
Take your spindle to your local auto parts store and find out.
I like using the tie rod hole as reference.
The 63-70 outer tie rod is definitely a smaller diameter than the 71-72 and the 73-87 version.
All three are different sizes.
Keith
Convert to disc brakes.
Old 03-10-2016, 12:13 AM   #54
Woodnears
Lolife, I did just that. It appears as the 72 ball joint from parts house has the same taper as my spindle as it's tight and a good fit. I think the taper could just be deeper. If I don't use a washer it all works just fine.
Old 04-20-2016, 12:21 AM   #55
69short
69short's Avatar
It's time for more updates on this bad boy. Everything is looking good.
Classic parts is here in Riverside MO. It may be worth your drive to pickup new bedsides and any other large parts there to save on shipping.
69short is offline   Reply With Quote
Old 04-25-2016, 09:08 PM   #56
Woodnears
Well, I managed to get the air lines done!
Old 04-25-2016, 09:11 PM   #57
Woodnears
Fuel lines routed through the frame, al 6an braided stainless with all stainless clamps. I need to order the pump from properformance still but it's all plumbed.
Old 04-25-2016, 09:12 PM   #58
Woodnears
This whole setup is a fairy tight for but I managed to squeeze it all in a. Ice clean package including two water traps.
Old 04-25-2016, 09:14 PM   #59
Woodnears
One more from the front.
Old 04-27-2016, 10:02 AM   #60
Gus350
68 C 10
Gus350's Avatar
Looks Killer
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 04-27-2016, 09:38 PM   #61
69short
69short's Avatar
It's looking great man! Keep it up!
Old 04-28-2016, 02:16 AM   #62
RustenPaines
RustenPaines's Avatar
Looking great!
69 C10 "Torchered"
RC Crawler Nut
http://www.dorkstarproductions.com/orcrc.com/forum/
RustenPaines is offline   Reply With Quote
Old 04-30-2016, 11:02 PM   #63
Woodnears
One more pic
Old 04-30-2016, 11:26 PM   #64
69short
69short's Avatar
Nice pic! Makes me want to go clean my garage.
Old 05-01-2016, 08:54 AM   #65
Bennett68C10
Bennett68C10's Avatar
Hell yeah! That looks good
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-21-2016, 02:31 PM   #66
Woodnears
here are a few better pics for your viewing pleasure!
Old 07-21-2016, 03:23 PM   #67
Hart_Rod
Hart_Rod's Avatar
Nice job,
Hart_Rod is offline   Reply With Quote
Old 07-21-2016, 09:13 PM   #68
Woodnears
Thanks hartrod, I promise you one day I'll be far enough along to get into the bed where I will definitely call on you for the rear tubs and your bed knowledge.
Old 07-22-2016, 08:26 AM   #69
mcbassin
Still Learning
mcbassin's Avatar
Very clean work! Looks great!
mcbassin is offline   Reply With Quote
Old 07-22-2016, 08:30 AM   #70
Hart_Rod
Hart_Rod's Avatar
No worries bro. Keep plugging away!
Old 07-22-2016, 04:32 PM   #71
MMcMasters
MMcMasters's Avatar
very clean work!! It looks great!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 07-24-2016, 01:07 AM   #72
69short
69short's Avatar
Looking good man
Old 07-24-2016, 09:07 AM   #73
Bennett68C10
Nice job on those airlines!
Keith
66 Suburban
IG: bennett68c10
Old 07-25-2016, 10:20 PM   #74
Woodnears
Guys it runs! I'm missing a radiator hose then I'll have a video for you. All I'm lacking is a driveshaft, uninterrupted steering joints, and power steering lines oh and a few brake lines and she will drive. It may not have fenders, hood, grill or a bed but she can drive.
Old 07-25-2016, 10:47 PM   #75
88Stanger
88Stanger's Avatar
nice job so far
88Stanger is offline   Reply With Quote
