03-12-2012, 08:59 PM | #51 |
Re: New member with barn find
Thanks Richard, it was nice meeting you on Sat.
04-25-2012, 06:12 PM | #52 |
Post some progress john! Saw some great pics in your Photobucket.
04-25-2012, 09:05 PM | #53 |
Equal opportunity joke ofender
Yea what he said ^^^^^^
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
04-26-2012, 08:54 PM | #54 |
Just a nother gear head
wow, thats alot of pictures in your photobucket. great documentation of the build. i know i will be looking at those more than once. rust on my jimmy is par with yours. giving me insperation to go work on it.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 Last edited by fxdxharley; 04-26-2012 at 08:54 PM. Reason: spelling |
05-25-2012, 10:53 PM | #55 |
It's still alive, I started the Blazer up and turned it around, I don't like to work too close to the chevelle. I didn't think it would run after removing so many wires. Ounce I get the pass side windshield frame and around the blower motor done I can get starter on the replacement frame. Click the engine to hear it run.
05-26-2012, 04:46 PM | #56 |
Well you have a lot of work there, but it is well worth it, they rock when they are done, less and less around now.
05-30-2012, 03:35 PM | #57 |
Wow! great build man. I have been lurking around for a couple weeks now but just noticed from your posts and the responses that there are several semi-local vintage blazer builds going on in the Philly area. I gotta get my thread started.....Keep up the good work.
05-30-2012, 11:11 PM | #58 |
Nice Build!
10-31-2012, 09:00 PM | #59 |
I got alot done since my last post. First think if the MOD reads this could you move in over to projects and builds for me?
I bought a repop radiator support and mounted it up, I just didn't like the way it fit so I cut out everything my factory one needed, It took alot of time but it was worth it. Also I repaired my fenders that were trimed for larger tires and sand blasted the frame then painted it with POR-15 and some chassis black. I got a 2" all leaf spring lift for it and mounted the one tons under it so the wife and I could rolled the frame under the body. I hope to have the body finished and drivetrain back in for spring time. |
10-31-2012, 09:14 PM | #60 |
10-31-2012, 09:26 PM | #61 |
VA72C10
Very nice work on the core support. Will as someone to move the thread for you In the future you can use the report post button...
Looking for a 67-72 swb or blazer project in or around VA. |
10-31-2012, 09:30 PM | #62 |
10-31-2012, 10:25 PM | #63 |
John, im impressed with the surgery you performed on the windshield, well done! Body lookslike it is starting to come back together also....any pics of the bedfloor, you can unload it now, Sandy has passed
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-02-2012, 07:46 AM | #64 |
PROJECT 7DEUCE
Nice work lots of rust removal wow..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-02-2012, 09:24 AM | #65 |
Very impressive John. Nice work! Can't wait to see it. I wish I had the time to learn how to do all the body work myself. If I had attempted that my Blazer wouldn't be finished for like 15 years.
01-07-2013, 08:26 PM | #66 |
Got the top on Today, I put the top on so I could check to see if everything will line up, and it looks good. I still need to bolt it down, fine tune the doors, weld in the rockers and get the hood on and then it's time for some bondo. I'm glad I kept the winch off my jeep, I mounted it in the garage attic and ran the cable thru the drywall.
Also got a chance to get the toys out and clean up. |
01-07-2013, 09:03 PM | #67 |
Looking good John
Richard Posted via Mobile Device
02-11-2013, 05:52 PM | #68 |
Up dates
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer CST Highlander 15YR project 2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) |
02-11-2013, 06:24 PM | #69 |
02-11-2013, 08:37 PM | #70 |
Not much to update, I've been working on door gaps and body shims. Boy what a PITA, I think I have the pass side door dialed in, the gap at the quarter panel is a hair over the thickness of a paint stick. On the drivers side I have a great body line but it's about 1/4" wide on top and a hair wider at the bottom of the quarter and the hing is back as far as it will go. If I lift at #3 body mount the top will get wider. Any ideas? before I elongate the lower hing bolt holes.
02-11-2013, 09:20 PM | #71 | |
02-12-2013, 08:30 PM | #72 |
Here's some pics, I've heard of the 2X4 in the jam trick but the door lines up great it's the gap that is off. I had it dialed in before ( see post 55) I wonder if it could be the hinges, they are from a 68 c10 and look a little different.
03-04-2013, 06:13 PM | #73 |
Add your pics now we want to see how much you have been loffing around doing nothing to the blazer like myself . All I have done is spending money on parts/parts that Iam not even close on using LOOKS GREAT JOHN
03-05-2013, 09:36 PM | #74 |
Here's a couple Dave. I pushed it out of the garage so I could install the hood. I did the old hang the hood from a pulley them role the blazer under it and push the hood back to the hinges trick. I'm still messing with the door gaps, I'd like to get the gap at the quarter to door closer.
I think it's time for us local guys To plan a wrenching party at Dave's house and get his blazer running and ready for the street. Springs coming! |
03-05-2013, 10:01 PM | #75 |
Nice work John!
Almost time to ride the dual sport....lmk, when you go to Daves. Gaps look good from here
