Old 06-26-2011, 07:48 AM   #51
msgross
msgross's Avatar
Re: Pretty ticked right now...Rally wheels
Originally Posted by bigblock73 View Post
More useless info for you guys, Mikes (msgross) 6 lug wheels have 10 slots, the C10 5 luggers have 16...lol. How many ppl knew that without looking?
Thanks for the pic Mike, and additional confusion...lol.
I didn't make it out to try the wheels on my 73...had a busy day, will try to get to it tomorrow.
no problem , I don't know what year mine is from, older I assume...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-26-2011, 08:25 AM   #52
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Originally Posted by rwhit57 View Post
My guess is it's the powder coating, a rotary file should solve the problem.
I agree, it's the powder coating not the wheel. You can do this yourself, get a grinding wheel that you can put in your drill, take your time and slowly grind away the powder coating from the center rim.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 06-26-2011, 09:43 AM   #53
1LowToy
I just measured the 1984 rear axle hub flange at 3.175" So a bit more would be needed for clearance. I don't Know where the wheels come from but maybe some of the big chryslers had a 5x5" bolt pattern. I have some of the chrysler wheels on my utillity trailer and I know for sure that they are 5x4.5".
What are yours measuring?
1LowToy is offline   Reply With Quote
Old 06-26-2011, 10:18 AM   #54
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Jeff,
Here are the wheels that are on now on my 85. I think they came off my 87 shortbed diesel but may have been off my 86 longbed. I had them powder coated in 2003 for my 86 project but it has gone nowhere. I bought my little plain jane 85 after the red diesel got totaled and put these wheels on.
They were tight over the centers but fit. As I tightened them down, the rotors/rear axles pushed some powder coating out. They look like your first pic. They are 15x8 and the truck has 1" front brakes and a 10 bolt.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 06-26-2011, 12:18 PM   #55
rcsweet21
went and checked mine on a 1986 long bed they all have the raise screw holes for the wheel center
rcsweet21 is offline   Reply With Quote
Old 06-26-2011, 06:03 PM   #56
bark
not sure if this was mentioned, but the rims with the raised centers are for the older style cap, bolts from the rear, the flat ones are for the cap that bolts from the front, has notches were the wheel nuts are, compared to a nice smooth round cap like the early 70's. bolt pattern is the same, so just pull out the die grinder.
bark is offline   Reply With Quote
Old 06-27-2011, 08:31 PM   #57
bigblock73
yeller
bigblock73's Avatar
The "cap mounting from behind" makes sense with the raised mounting....can anyone confirm the early caps did indeed mount from behind? Pictures to prove it? That might just be it, and if so, an early rally wheel design I was unaware of.
bigblock73 is offline   Reply With Quote
Old 06-27-2011, 08:36 PM   #58
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The earliest rally wheel caps definitely mounted from behind. I've owned them personally.
Old 06-27-2011, 08:38 PM   #59
bigblock73
yeller
bigblock73's Avatar
I hang my head low with great embarrassment...and relief too!
I finally had time tonight to mess with the 75 a little. I picked up a matching fifth Rally wheel (round center), because I wanted all four to match...even though you will never siee it...just because I am anal. I pulled off the drivers front wheel/tire, and the Rally slid right on. Sweet! So I took out the drill and grinding bit, and removed the powdercoating from the inside hole diameter on one of the wheels...and wouldn't you know, it slid on perfect. Did the other three while I was at it. Tonight I will spray some grey epoxy primer/paint on the bare surfaces and be done with it.
The tire shop was way off in their measurements, and I simply took their word for it because I didn't have a spare wheel to test their theory on.
What kind of had me baffled too was my 88-98 powdercoated Rally wheels fit my 77 just fine...no grinding required.
So anyhow, I dropped off the fifth wheel for powdercoating, and should have it back shortly so I can finish getting these wheels and tires on the truck. I will also now have a semi-matching powdercoated spare...lol!
Thanks for everyones help and feedback. I learned a lot about Rally wheels here, something I don't think I will ever forget.
Old 06-27-2011, 08:41 PM   #60
Tx Firefighter
Jeff,
Do you mind telling what your guy gets to blast and coat a rally wheel ? I ask just to gauge my prices against other shops.
Also, do they do just the face of the wheel or the entire wheel, front, back, bead area and all ?
Is it single stage or did they clear the wheels ?
You can PM me if you prefer rather than posting here. Again, I'm not trying to drum up work just see where I stand with my prices.
Old 06-27-2011, 09:00 PM   #61
bigblock73
yeller
bigblock73's Avatar
Kevin, no problem
For a 15" steel wheel, they TYPICALLY charge $100 per wheel. That includes media blast, and two coats of finish for the entire wheel (front/back/bead).
Because I am a return customer (have had wheels, brackets, and valve covers done), they only charged me $75...and I got three coats on these (prime, color and clear).
They do real good work and are nice guys, and are comparable to other shops in the area.
Their turnaround time is about a week.
Old 06-27-2011, 09:03 PM   #62
Tx Firefighter
Kevin, no problem
Thank you for the quick and thorough response. I like to get an idea of where other shops are on their pricing.
Old 06-27-2011, 09:13 PM   #63
bigblock73
yeller
bigblock73's Avatar
Are you pretty close to that? I really like the return customer discount, wish more places did that. Keeps business, and encourages word of mouth advertising. Regardless, I have seen your work, and wish you were closer to do mine.
Old 06-27-2011, 09:18 PM   #64
Tx Firefighter
I'm at 60 for single stage, 90 for two stage for the entire wheel.
Old 06-27-2011, 10:50 PM   #65
BigRed76
BigRed76's Avatar
The only time I've seen a rally wheel like the one in the 2nd picture (with the raised areas) was a 6 lug rally wheel.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-27-2011, 11:07 PM   #66
ElGracho
ElGracho's Avatar
A bit more on the wheels...
The wheels on my Gentleman Jim mount the center caps from the front. I have seen the rear mounted center caps, but I don't know what years they were offered.
I'm confident the wheels on the Gentleman Jim are original since they are in the matching gold to the stripe on the truck.
It would be nice to document when the changes from rear to front mounted center caps happened.
I'm glad your wheels ended up fitting. I was really wondering how your hubs could be an odd size...
Joe
Old 06-28-2011, 08:09 AM   #67
80SPORT
80SPORT's Avatar
Looking at the GM parts book it appears the change was mid 77....
The early caps (C10) show as 359758 and 341430
Mid 77 changes to 469664
A note in the book mentions change in attachment
The special retaining bolt for the late caps is also listed ....14003421
80SPORT is offline   Reply With Quote
Old 06-28-2011, 12:01 PM   #68
N2TRUX
Happy to be here
N2TRUX's Avatar
If I were going to guess, it would have been 77. I have found that 77 was a huge transition year. There are several things that ended in 77, started in 77, and were 77 only. The center caps changing that year goes right along with the rest of it.
Glad to hear you got your mystery solved...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-28-2011, 12:49 PM   #69
rwhit57
rwhit57's Avatar
I've had a ton of these old trucks, and countless sets of rallye wheels, and I have never seen the caps mount from the back side. So do those caps not have holes all the way through? If anyone has some I would like to see a pic. Then I can say I saw them.
rwhit57 is offline   Reply With Quote
Old 06-28-2011, 01:09 PM   #70
Tx Firefighter
Right side of the picture. They were round instead of scalloped and had three threaded bungs in the back side. The holes did not extend through to the front of them.
Old 06-28-2011, 05:39 PM   #71
rwhit57
rwhit57's Avatar
Thanks TX, Those look like the police car caps. I guess I've never had a set of those. Dang learned something.
Old 06-29-2011, 12:23 AM   #72
USSkoval
I'm going to say that the early caps probably had an issue with the bolt threads pulling out, so they were usually replaced with the revised caps.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 06-29-2011, 08:11 AM   #73
TexasDmax
FYI: The 6,000 mile truck on ebay has the center caps that bolt from the back. I had a 71 cheyenne that had those as well.
http://cgi.ebay.com/ebaymotors/All-o...item2a11baf940
TexasDmax is offline   Reply With Quote
Old 05-28-2019, 12:31 PM   #74
hb32
hb32's Avatar
Dragging this back up and here is another visible difference between wheels. Note the inner ring on the rims. Painted pic is of ones with 1984 stamping and other is 1910. Ring is more pronounced on the painted wheels.
Life is too short to drive a boring vehicle.
hb32 is offline   Reply With Quote
Old 05-28-2019, 01:32 PM   #75
Danmcg
How many slots in the first wheel? Corker makes one with sixteen slots, my factory's only has 10. I can't tell by the pic but it looks like more then ten.
Danmcg is offline   Reply With Quote
