07-19-2011, 03:04 AM | #51 |
Re: 1951 Suburban a 4 year project....
All loaded up and headed for paint
07-19-2011, 03:09 AM | #52 |
While suburban was off getting body work and paint the motor and trans were detailed and painted..
07-19-2011, 03:14 AM | #53 |
A few shots of it while in the body shop getting paint and lizard skin sprayed inside.. Also the wood grain goes on dash
07-19-2011, 03:17 AM | #54 |
more of parts getting painted
07-19-2011, 01:30 PM | #55 |
what color is the paint?
07-19-2011, 10:36 PM | #56 |
A beutiful burb you have there, all the build pictures put together makes it look like a smooth quick build, Ha! Great docmentation, I love the overall theme, restored stock, but slamed & updated driveline, welcome to the board parkwood. Howbout some pics of the wagon?
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
07-19-2011, 11:19 PM | #57 |
man, i wish i would have seen this build before i did mine. you have alot of good ideas. what is that black setup that connection from the frame to the upper control arm? does it just limit the air bag from over inflating? what did you do in the front to stop the crossmember from hitting the ground when you deflate the air bags.
07-20-2011, 01:01 AM | #58 |
07-20-2011, 01:09 AM | #59 | |
The real story is i had it for almost 4 years but the build in real time was a little over 2 years.. We worked on at least 4 other car and trucks while working on the Burb... Maybe i'll post some of those pictures Here's a few just for you... |
07-20-2011, 01:10 AM | #60 |
56 - autocross
Bring them on!
07-20-2011, 01:25 AM | #61 | |
As for the crossmember hitting the ground the kit comes with a bumb stop you weld on and this stops the x-member from hitting.. I just lowered it down to where i wanted it to stop and that's where i put the stop.. Hope this helps... |
07-20-2011, 01:30 AM | #62 |
07-20-2011, 01:36 AM | #63 |
56 - autocross
now you are talking our language.
07-20-2011, 01:41 AM | #64 |
With the Grand National Roadster Show just over 3 months away we got the suburban back from paint. The only thing done was the body was bolted down to the frame and the some wheels were on it... only thing left to do was everything...... no big deal.. ha
07-20-2011, 01:44 AM | #65 |
07-20-2011, 01:57 AM | #66 |
shots of the frame coming together, air tanks on the frame rails, a/c in, and seat frames at power coater..
07-20-2011, 02:04 AM | #67 |
The head liner had to go in before the glass, wood was screwed to the top bows and tin was used to round the corners and then foam was glued and sanded to make smooth and nice shape.. then the head liner was glued to all that. one big piece... came out very nice and smooth..
07-20-2011, 02:12 AM | #68 |
We use power windows in the burb. and the the switchs were the kind that looks like a stock window handle... works great...
Time for glass.. |
07-20-2011, 02:16 AM | #69 |
The motor is a ZZ4 350 and the trans is a 700R4..
The motor was torn down and rebuilt with better rods and pistons and a little hotter cam.. sounds great. |
07-20-2011, 02:21 AM | #70 |
Time to get it wired up. everyone's job of choice...
07-20-2011, 02:26 AM | #71 |
Painting a few things the body shop didn't... steering wheel, and grill bars.
07-20-2011, 02:30 AM | #72 |
Installing the sun visor
07-20-2011, 02:37 AM | #73 |
Getting front on..
07-20-2011, 10:13 AM | #74 |
Wayne
Nice pics....I should have made it easy on myself and just had you come to MI and finish putting my truck together for me.......We would have called it a "vacation" so I would not have to pay your west coast hourly rate.....JK You must have a ton of pics because some of these I have not seen before and I know that you have sent me quite a few. I saw a small pic on pg 101 of the newest Streetrucks mag. They were covering the GNRS. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
07-20-2011, 01:58 PM | #75 | |
My shop rate is so low i'm almost on food stamps.. Yes i have almost 1000 pictures of the suburban build, and some of the other trucks i've worked on not so many only because we only had them for 6 months or less.. want me to make you a CD and send it to you..? |
