09-27-2017, 10:31 AM | #51 | |
Re: '60-'66 Body On A '73-'87 Frame
ron |
09-27-2017, 11:38 AM | #52 | |
But Found Her 25yrs Later!
But I did a search and found a few threads on topic: http://67-72chevytrucks.com/vboard/s...d.php?t=667010
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-27-2017, 12:09 PM | #53 | |
61 apache |
09-27-2017, 12:42 PM | #54 | |
The swap is really quite simple. Bolt the body mounts to the cab, drop the cab onto the frame, weld the mounts to the frame. Done. Eric
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera |
09-27-2017, 12:58 PM | #55 |
frames are very seldom a problem. most of these swaps are made with boxes on them and most do not alter the w/base to have the tires centred properly which looks a little hokey.
ron |
09-27-2017, 02:51 PM | #56 |
09-27-2017, 06:58 PM | #57 |
"Robust"
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
09-27-2017, 07:48 PM | #58 | |
WINGNUTS!!! Wow.
2006 Sierra RCSB V6 5 Speed RWD. |
09-27-2017, 08:49 PM | #59 |
The wingnuts allow quick cab removal for easy cleaning.
09-27-2017, 10:21 PM | #60 |
I can tell you are pretty passionate about this topic, may I ask why it bothers you so much? Please correct me if I'm wrong, but doesn't your truck have an earlier frame swapped in?
If I desired to own a 4x4 60-66 this is likely the route I would take. If I had a truck with a damaged frame and the only replacement I could find was a later model, I possibly would try this route was well. The person you are mocking has a good looking truck. From the pictures he provided the work appears well done. I don't understand the disgruntlement in how others choose to build their trucks. |
09-27-2017, 10:38 PM | #61 |
You're right, that was rude of me. I apologize.
. For a 4x4, it may be the simplest route. But for disc brakes and power steering on a 2wd it's best to use one's original frame. But yes, it bothers me because those who encourage others to do it aren't giving sound advice. My 65 is on a 62 gmc frame. I did it after I totaled it in the 80's. I was 18 and didn't know better.
09-27-2017, 10:47 PM | #62 | |
Posted via Mobile Device |
09-27-2017, 10:51 PM | #63 | ||
In my opinion someone showing others it is possible to get good results swapping frames doesn't constitute giving bad advice. |
09-27-2017, 10:52 PM | #64 |
Some one did a little rigging there.
09-28-2017, 05:33 AM | #65 |
You guys do realize the point of this thread isn't for those who Need a new frame. It's for those that think it's the easier route for the upgrades the 2 wheel drive guys want. To swap out the original frame for the upgrades isn't a practical route.
09-28-2017, 08:44 AM | #66 | |
This thread has been bumped multiple times over the years, each time by people looking for more information, the most recent by someone who admits they have a damaged frame. I don't see where I'm off topic here |
09-28-2017, 09:20 AM | #67 |
I surely don't want to get into a pissing match. But I do deserve it.
But for the original purpose of this thread, aligned with what is the purpose for swapping frames, if ones frame is good, there is absolutely no advantage to go to the newer frame. That was the point of my post. Body mounts, frame contour, frame horns, and especially VIN. But I understand I deserve your method of replies because of my snarky reply to another member.
09-28-2017, 07:13 PM | #68 | |
We are all here for the same reason and we all bring something different to the table. We need to be able to share opinions, experiences and be able to disagree without it turning ugly....we are better than politicians. |
09-28-2017, 07:18 PM | #69 | |
My bad.
09-28-2017, 10:50 PM | #70 |
Oh boy i thought you almost opened a can of worms man.
10-07-2017, 01:48 PM | #71 |
I would never swap to a square body frame for 2 wheel drive. 4wd on the other hand, would do it again in a heartbeat
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
10-09-2017, 11:59 AM | #72 |
I'm going to start a thread where I overlay different frames with the 63-66 frame along with a greyscale of the cab and such so we can visually see see where things line up or not.
10-09-2017, 06:14 PM | #73 |
10-11-2017, 06:12 PM | #74 |
What about our body on a 1999 or newer LS equipped frame?
10-11-2017, 06:27 PM | #75 |
