12-03-2012, 03:19 PM | #51 |
Re: Hub caps on truck question
I just bought a pair of OG 64-66 hubcaps for my truck. It looks like, however, I may have later model wheels. The little "nub" that is on the center part of the wheel that generally holds the cap on, is on the outer edge of the center ring instead of the inside. Did chevy make specific wheel designs for 64-66 to match their caps? Or, will I have to make something work similar to your trick above?
12-03-2012, 03:28 PM | #52 |
There were several different rims. The earlier rims had clips as did some of the 3/4 & 1 tons. There was also a 3 bump rim (drum brake) and a 4 bump rim (disk brake). Look at thread #79 on hubcaps
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-03-2012, 03:35 PM | #53 |
These are the caps my 64 came with...
12-03-2012, 04:01 PM | #54 |
Those are 73-87 caps.
12-03-2012, 04:03 PM | #55 |
so, I can assume the wheels on this truck are from 73-87?
12-03-2012, 05:36 PM | #56 |
Can you post a pic of them?
12-03-2012, 08:28 PM | #57 |
03-03-2013, 02:56 PM | #58 |
any updates on what clips wprk best as i just scored a set of 5 73-87 4x4 8" wide i "believe" wheels for thirty five bucks and want to run some sort of poverty cap or hub cap instead of the exposed lug nut center cap any new info is appreciated thanks
03-03-2013, 04:41 PM | #60 |
Senior Enthusiast
That wheel cover is absolutely wicked looking! The last time I saw anything remotely close to that cool was back in 1959 watching the chariot race in Ben Hur!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
03-03-2013, 04:54 PM | #61 |
"Where were you in '62?"
The Romans were the first to have spinners!!!
Customized 4 Horse Power Chariot..... Very first Nascar Race???? Ha ha ;-)
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 03-03-2013 at 05:01 PM. |
03-19-2013, 01:31 AM | #62 |
I have been following this thread for a little while but it seems to have stalled. I finally got the 73-87 6-lug rallys cleaned and painted. Went with body color (don't use touch up paint online (dot) com) and smaller trim rings but still looking for center cap ideas. My rallys came with 6 lug 4X4 caps but of course 2 are open and they are all four pitted.
Keith, thanks for sharing but I noticed that your idea allows the cap to snal on OVER the center band(?) I was looking for something smaller that fits inside the groove. Very much small economy/police style cap. Anybody have anything new?
1979 C-10 LWB |
03-19-2013, 01:06 PM | #63 |
LMC Truck has new caps.
http://www.lmctruck.com/icatalog/csb/full.aspx?Page=102
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
03-19-2013, 02:07 PM | #64 |
Haha...love it, but Ben-hur didn't have chrome. Looks like some LED's in there too.
03-19-2013, 02:08 PM | #65 |
Thanks. I saw these but the smoothies/plain Jane caps are available for repop car rally's that have been machined for truck pattern. I have 6-lug truck rallys 73-87. They have replacements for my application but I wanted something a little different.
1979 C-10 LWB Last edited by rod1701; 03-19-2013 at 02:30 PM. Reason: Incomplete |
01-17-2019, 12:19 PM | #66 | |
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
01-17-2019, 01:13 PM | #67 |
Lots of cool innovative ideas but I ended up using a centercap from mid 90s wheel. Little shorter than 70s. Turned out okay.
1979 C-10 LWB |
01-17-2019, 01:32 PM | #68 |
Any pictures?
01-17-2019, 09:15 PM | #69 |
Junior Member
Just saying, I wanted 8" steel wheels on my ' 64 panel but still use dog dish hubcaps. I got wheel vintiques. Centered the dog dish hubcaps on the wheels and marked the outline of the hub cap on the wheel. Then welded three tabs on the wheel inside the marked line. They've stayed on there for over 10,000 miles.
01-18-2019, 08:33 PM | #70 | |
Check The Champ, Demonstrator
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
01-19-2019, 01:55 AM | #71 | |
01-19-2019, 01:51 PM | #72 |
Junior Member
Attached are pix, sorry for the dirt. First pix is dog dish cap on 8" vintiques wheel. Second shows the three weld beads on the rim.
01-19-2019, 06:54 PM | #73 |
I ran into the same issue with my truck. The '66 C20 wheels had small clips on the inside ring of the rim that held the cap in place, or so I've been told. So, I bought the caps that fit my wheels. '67-early seventies caps may not be 'right' for my truck, but I like them.
