Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 02-28-2012, 01:54 AM   #51
Captainfab
60-66 Nut
Re: my new 1963 GMC Suburban.........
Pat
I did a quick search on those heads, and they were used on the 300hp crate engine. Still a decent engine. I just wanted you to be aware that you did not have a 330 hp crate engine. As long as you're happy with it, that's what counts
Originally Posted by Apache63 View Post
Thanks , the deal is realy okay !!
Thanks Captain , i have Numbers for you ,maybe you can help me to tell me what engine i have !
Engine Block #10243880 5.7 SGI CC7220
Head #14096217
I got the engine from a buddy of mine and his ok , the engine has only 1hour on it ,nearly brand new!
Here in Germany cost the engine round abound $5850 with oilpan and valve cover!
Its great that other Members have an Eye on other Members!!
Thanks a lot!!!!!
Old 02-20-2014, 03:50 PM   #52
Apache63
1# Drobmember in Germany
Apache63's Avatar
update soon…….
Pat
Apache63 is offline   Reply With Quote
Old 02-21-2014, 08:11 AM   #53
Captainfab
60-66 Nut
Been wondering what happened to you Pat, haven't seen you post for some time. I'm anxious to see what you have to show us
Old 02-21-2014, 08:32 AM   #54
Apache63
Apache63's Avatar
Hi Captain ,
i was busy all the time ,company and so on .......
but i made progress on the Suburban in the last 6month!
hope to upload some pics this weekend!
Pat
Old 02-21-2014, 02:35 PM   #55
1963c-10
1963c-10's Avatar
very cool thread....nice truck
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-22-2014, 04:14 PM   #56
Apache63
Apache63's Avatar
so guys i'm back with more pic's on my build ............
after storing the frame more than over a year outside it's time to get it back in my garage......
da Frame......
i'll running porterbuild dropmember front and rear !!!
lets go.......
Pat
Old 02-22-2014, 04:24 PM   #57
Apache63
Apache63's Avatar
cutting out the old frame stuff and the first componets of the dropmember are going in ................
OLD ......
NEW....
Pat
Old 02-22-2014, 04:42 PM   #58
Apache63
Apache63's Avatar
more new parts are going in .......
the front end.....
running a big brake kit with 13" rotors....
and the rear end with a 9" moser rear end......
Pat
Old 02-22-2014, 05:03 PM   #59
Apache63
Apache63's Avatar
trying to build a nice exhaust system , but the first try are poor.......
i think thats the better way to mount the muffler to the frame ....
now hows the exhaust tube going to the engine???
RIGHT , cut holes in the frame and here we go......
Pat
Old 02-22-2014, 05:10 PM   #60
Apache63
Apache63's Avatar
bought some Dodge 20" Steel rims to make some roller wheels for my chassis ......
Pat
Old 02-22-2014, 05:16 PM   #61
Apache63
Apache63's Avatar
and this are the wheels i'm running after this build......
Boss 308 in 20x8.5 and 20x10 , they are often to see in the US but here in Germany they're pretty rare.......
Pat
Old 02-22-2014, 05:30 PM   #62
Apache63
Apache63's Avatar
now back to the exhaust.......
and here's the problem.....
okay well i think i got it.....
Pat
Old 02-22-2014, 05:35 PM   #63
Apache63
Apache63's Avatar
and here the modified Transmission Crossmember.......
Pat
Old 02-22-2014, 05:39 PM   #64
Apache63
Apache63's Avatar
and the exhaust complete......
and here can you see that i'm using a Tremec TK600 with a brandnew LS2!!!
Pat
Old 02-22-2014, 05:54 PM   #65
Apache63
Apache63's Avatar
here's the engine a LS2 2006 GTO and the Tremec Transmission .
some modification are necessary .......
changing the oil pan from GTO to Camaro ....
mounting a new Fly Wheels and a new clutch.....
test fitting of the bell housing and tranny.....
Pat
Old 02-22-2014, 06:04 PM   #66
Apache63
Apache63's Avatar
changing from manuel throwout bearing to hydraulic ......
change to mid shift.....
READY/WAITING for install....
Pat
Old 02-22-2014, 06:06 PM   #67
Apache63
Apache63's Avatar
i made the radiator fit to the radiator support ,
its a Impala radiator with 3 row and dual fan assembly....
Pat
Old 02-22-2014, 06:18 PM   #68
Apache63
Apache63's Avatar
cause i'm running the 9" rear end i had to modified the bar between the Trailing arms , the Rear end housing is bigger than our stock axles, here are the pics.....
and there's the space i'm looking for....
Pat
Old 02-22-2014, 06:20 PM   #69
duallyjams
duallyjams's Avatar
WOW lots of updates of all the good stuff good job Pat.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-22-2014, 07:38 PM   #70
MikeS.
MikeS.'s Avatar
I totally agree, I hadn't seen it before.
Herr Pat sehr güte, danke. Ich habe ein 63 4x4, siehe unten bitte.
That is some awesome work, you have some mad skills.
Mike
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 02-23-2014, 05:16 AM   #71
Apache63
Apache63's Avatar
Thanks Guys..........
here i welded the radiator support mounts to the frame , the stock one has rubber and these where in terrible condition.
Pat
Old 02-23-2014, 05:25 AM   #72
Apache63
Apache63's Avatar
I'm using the airride system from ACCUAIR and now i have to built some mounts to mount system to the frame ......
Pat
Old 02-23-2014, 05:31 AM   #73
Apache63
Apache63's Avatar
now it's time to make a bracket for the tank .
i'm using a tank from tanksinc.com .......
Pat
Old 02-23-2014, 05:33 AM   #74
Apache63
Apache63's Avatar
now we have a rolling chassis and it looks good to me........
Pat
Old 02-23-2014, 05:39 AM   #75
Apache63
Apache63's Avatar
so now it's time for powder coating ..........
Pat
