Old 01-13-2012, 09:57 PM   #51
mjensen
mjensen's Avatar
Re: 67-72 Chev Crewcab Build
Wow! That is awesome!
I'm really digging the 4 doors!, there was a snapshot of one in the latest issue of Classic Trucks (article about Bonneville Salt Flats). Damn nice looking.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 01-13-2012, 10:11 PM   #52
Car'n'Guitars
Car'n'Guitars's Avatar
Love the look of the cab looks amazing.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 01-14-2012, 01:39 AM   #53
hgs_notes
GEARHEAD
hgs_notes's Avatar
Great idea doing all that work with the skin off.
hgs_notes is offline   Reply With Quote
Old 01-14-2012, 01:50 AM   #54
KensChevy
KensChevy's Avatar
KensChevy is offline   Reply With Quote
Old 01-14-2012, 02:30 AM   #55
jbclassix
Junk Yartist
jbclassix's Avatar
did you lap weld all the seams?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-14-2012, 10:56 AM   #56
atvpro
atvpro's Avatar
In some places I did , but only where it was needed. I tend to over weld things as it is.
atvpro is offline   Reply With Quote
Old 01-14-2012, 11:11 AM   #57
jbclassix
Junk Yartist
jbclassix's Avatar
No such thing, Ha! Did you have any issues with warping? I really like the idea of flanging and lap welds with spot welds. I't should be extra strong. I'm probably going to pick your brain all the way through this build. I can't wait to see what you do for your window frames!
-Jeremy
Rebuilding an NP205
Old 01-14-2012, 11:20 AM   #58
tomsprojects
tomsprojects's Avatar
Your killing me with all that your getting done. I don't have any time right now to work on my.
tomsprojects is offline   Reply With Quote
Old 01-14-2012, 12:04 PM   #59
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work! I was curious what you were going to use for a skin. I assumed a donor piece from the burb just where you are going to use. The burb donor I'm getting has big dents in that area. So I'm wondering if it would be better for me to use an old box side, or I need to find another burb to hack that section off of.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-14-2012, 01:29 PM   #60
atvpro
atvpro's Avatar
Weezer I couldn't imagine doing it any other way.
Regarding lap welding; lap welding in this particular case is not necessary where ever a joint turns and goes in a different direction you can see that as a reinforcement lap welding on sheet metal is hardly necessarily especially when you consider spot welding with a mig welder is way more effective than factory spot welding. Before I button up the door I will go back through and check all areas for flex.
Regarding the question about warping; I never spot weld more than three in a row before I move somewhere else and then come back, I also use an air blower to instantly cool the weld when I think warpage could happen.
Regarding flanging; is there really any other way. I broke my flanging tool earlier this week trying to flange into a corner, stopped what I was doing and went and replaced the tool instantly. The hole punch on the flanging tool is invaluable wouldn't even think about doing this job without a high quality flanging tool.
Regarding the window frames; if you look back on the window frame pictures the window frame is done. It was a cake walk.
Regarding how quickly I am getting this done; nothing quick about it but this is my living.
Ryan yes I did use the skin behind the driver's door because the body line is consistent; you need 35 inches continuous I don't know if a bedside would work or not.
Just after 9:00 on Saturday getting ready to roll out the rotisserie and do some media blasting. Mainly the roof and the inside of the door and then I will be pulling it back in and finishing the door. All future crew cab projects will be media blasted before I start any work. Getting tired of smelling burnt paint and welding is a lot easier when there is no rust or paint.
Always remember guys my shop is always open to visitors just be careful I might put you to work. Looking forward to building myself a 70’ 4 door one ton 4wd burb.
Old 01-14-2012, 04:44 PM   #61
jbclassix
Junk Yartist
jbclassix's Avatar
Thanks for the info!
-Jeremy
Rebuilding an NP205
Old 01-15-2012, 02:09 PM   #62
rodc77
rodc77's Avatar
Looks great. What is your wheelbase now?
rodc77 is offline   Reply With Quote
Old 01-15-2012, 02:41 PM   #63
atvpro
atvpro's Avatar
160" hub to hub.
Old 01-15-2012, 03:12 PM   #64
Maxxd07
Maxxd07's Avatar
This will be a great truck! Cant wait to see it done.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 01-15-2012, 03:16 PM   #65
atvpro
atvpro's Avatar
Thanks Les. I can't wait to drive it
Old 01-15-2012, 04:28 PM   #66
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Awesome...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-15-2012, 05:02 PM   #67
VA72C10
VA72C10
VA72C10's Avatar
Awesome work!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-16-2012, 01:21 AM   #68
YBNORML
YBNORML's Avatar
Nice work, I wish I had 1/10th of your skill.
Are you planning on building cabs for sale?
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-16-2012, 01:23 AM   #69
atvpro
atvpro's Avatar
Rtechfabrications.com
Old 01-16-2012, 01:43 AM   #70
YBNORML
YBNORML's Avatar
Thank for the quick response. You have now given me something else to save for.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-16-2012, 02:55 AM   #71
Dieselwrencher
Thanks for the info and continue the great work!
Ryan
Old 01-16-2012, 11:31 AM   #72
Hart_Rod
Hart_Rod's Avatar
Originally Posted by atvpro View Post
A ton more hours working on the locking system, the inside door handle and the linkage that goes with that. The window rolls up and have a few things to do to the front of the door then I'm ready to skin it however before I do anything else I plan to media blast the inside of the door and roof. Getting tired of working with dirty metal. The door skin I will be using will be coming from a suburban behind drivers door.
ATV is there anyway to straighten up the rear door window channel and still have it functional? I think it would give it a cleaner look.
Hart_Rod is offline   Reply With Quote
Old 01-16-2012, 12:31 PM   #73
atvpro
atvpro's Avatar
Rob,
I have looked at this from many different angles and lets face it this door is already well over 100 hours to build. I don't see a way of doing it that will clear the latch mechanism and the hinge indentation on the front, I had one guy ask me if you could completely do away with it, I would say no it would look really weird with a big piece of glass in the back and a small piece glass on the front door.
Old 01-16-2012, 12:32 PM   #74
atvpro
atvpro's Avatar
Just got done painting seamsealing and rubber coating the inside of the door, will probably try to have the door skin on by the end of the day.
Old 01-16-2012, 04:50 PM   #75
Hart_Rod
Hart_Rod's Avatar
Rob,
Here's a picture of my 67 Crew that is done like I was talking about. I was trying to figure out why it works and yours wouldn't. I think I figured it out, let me know what you think is different, .
