Old 04-30-2014, 08:16 PM   #51
Old_Truck_Fan
Re: Project "Financial Burden": 1968 SWB C10
Going to go with a rear mounted gas tank for the LS engine fuel system. No need for the filler neck hole on the cab anymore although it is one of my favorite features of these classic trucks.
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675
2011 Dodge Ram 1500
2012 Camaro ZL1
Old_Truck_Fan is offline   Reply With Quote
Old 04-30-2014, 08:22 PM   #52
Old_Truck_Fan
Originally Posted by Xeen View Post
You already have your go baby go machine so a great choice for your truck would be the 5.3L Vortec w/4l60e and 3.42:1 gear.
Originally Posted by eagleuh1 View Post
I second the 5.3/ 4l60e. Good milage, available at reasonable prices, and plenty of pow.er for hauling stuff. Unless you just want to go really, really fast .
That would be a great combination. I have a 5.3L engine I will be using for mock up. I am still up in the air on what combination I will settle on. I think I change my mind every other week.
Originally Posted by swamp rat View Post
Your doing some real nice work on the rust repair. First time to your build, my eye caught your title "Financial Burden" I can relate, i was thinking i should have named my trucks thread "Going Broke" keep up the good work!
Thanks for the comments. Back when I was a kid my older brother told me about a drag car he saw labeled "Financial Burden." I've always thought it was a great name for a project. I like "Going Broke" too!
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 04-30-2014, 08:24 PM   #53
jlaird
jlaird's Avatar
Man that rust repair looks oh so familiar. So glad that stage is over for me! Your metalwork looks meticulous! I like it!
jlaird is offline   Reply With Quote
Old 04-30-2014, 08:36 PM   #54
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Love your craftsmenship. Your doing a fine job and its looking great.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 05-01-2014, 12:13 AM   #55
mcbassin
Still Learning
mcbassin's Avatar
You have done a great job on the chassis and cab. I really like the rust repair work. You are making it look too easy. I remember before I repaired my cab, I saw a bunch of pictures like your's, I thought well that looks easy enough...little did I know the repair panels were a joke in many cases, the rust is everywhere on these old trucks and it takes some serious time to do it right. Very clean work and some nice welders you have there.
Looking foward to following the rest of the restoration.
mcbassin is offline   Reply With Quote
Old 06-07-2014, 06:15 PM   #56
Old_Truck_Fan
Thanks again for all the comments. It sure helps me stay motivated. I was able to save the lower part of the original rear door pillar and finished up the front pillar repair.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-08-2014, 08:13 AM   #57
Old_Truck_Fan
Since I've gotten a few requests to show more details around my work I've decided to do a more in depth summary of the cab corner replacement on this side of the truck. The first thing you need is a quality replacement patch panel. This picture shows the main thing to look for in a cab corner patch panel. You want a nice 90 degree contour on the bottom of the panel just like the original. This task is already challenging enough so make sure you start with good materials. The lower panel would have been a lot more work so I used the Goodmark branded panel (that I got from GMCPaul's Truck Parts) and sent the other one to the scrap pile.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-08-2014, 08:18 AM   #58
Old_Truck_Fan
I then used Eastwood's Weld Thru Primer on everything that was going to be covered up by the new patch panel. I was able to cut along the brace line for this repair which hides most of the patch seam where you can't see it from the inside. I also added a small brace (before I cut anything out) to help keep things in alignment.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-08-2014, 08:24 AM   #59
Old_Truck_Fan
Using the old panel as a template I made a rough mark on the patch panel with about 3/4 of an inch to spare. This helps get the panel in a more workable size. I also like to use a small round file to remove the burrs left behind to prevent cutting my hands up. Always were gloves when handling sheet metal!
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-08-2014, 08:30 AM   #60
Old_Truck_Fan
I then prepped the rocker panel and cab corner interface to get a nice tight fit between the two pieces. I used a hammer and dolly to get things flat and then removed a bit of the "puckered" areas with a grinder.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-08-2014, 08:34 AM   #61
Old_Truck_Fan
I then clamped the patch panel in place making sure to align it with the rocker and scribed the inside of the panel for the final cut line.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-08-2014, 08:40 AM   #62
Old_Truck_Fan
To get the other side of the final cut line (since I could not scribe it from the inside) I made an offset mark from the cab cut line using my 12 inch steel ruler. I then clamped the patch panel back in place and used the offset line to transfer onto the patch panel using the same 12 inch steel ruler.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-08-2014, 08:44 AM   #63
Old_Truck_Fan
I then added a couple of rosette weld locations at the bottom of the panel and trimmed off some excess material. I like to use a red scuff disk to remove the e-coat and prep everything for welding.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-08-2014, 08:57 AM   #64
Old_Truck_Fan
Now we can start welding! I like to start near the rocker panel and work my way around about every inch or so making sure that the panel fitment is tight along the way. I then weld in between the previous set of welds and then in between the next and so on until you have a continuous weld. I like to lightly smooth the welds in between each round and use a wire wheel to keep things nice and clean. The wire wheel also removes the heat marks so you can see exactly where your new round of welds are located. I take a lot of time in this process to keep the panel cool.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-08-2014, 09:04 AM   #65
Old_Truck_Fan
Now that the panel is fully welded I smooth things out with a variety of sanding disk including the sanding rolls that are used for porting cylinder heads. Now you have to be sure to work the hammer and dolly when necessary in between all those rounds of welding to keep everything as flat as possible. I hope this was helpful. Now onto rocker panel installation...
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-29-2014, 07:46 PM   #66
Old_Truck_Fan
Now onto the rocker panel installation. You can never have too may clamps.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-29-2014, 07:50 PM   #67
Old_Truck_Fan
I put on some primer just to keep the bare metal from rusting and took a picture of all of the sections I had to remove.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-29-2014, 07:58 PM   #68
Old_Truck_Fan
I had to make some room for the Tremec T56 transmission I am planning on running by doing a high hump conversion.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 06-29-2014, 09:28 PM   #69
lolife99
67-72 parts collector,…
lolife99's Avatar
Very nice work!
Keith
Convert to disc brakes.
Old 06-30-2014, 01:09 AM   #70
swamp rat
swamp rat's Avatar
X2 ^^
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-30-2014, 08:25 AM   #71
mcbassin
Still Learning
mcbassin's Avatar
Excellent write up and pictures. You are a master at making those repairs look easy.
Keep the pictures coming.
Old 07-19-2014, 04:46 PM   #72
Old_Truck_Fan
Had to fix the 1990's era modifications for a CD player. Luckily I scored a patch panel for $10 at a swap meet.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 07-19-2014, 08:23 PM   #73
cericd
cericd's Avatar
Nice work! I sure wish I had these skills.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 07-19-2014, 11:56 PM   #74
19GMC66
19GMC66's Avatar
Awesome work!
19GMC66 is offline   Reply With Quote
Old 07-23-2014, 04:57 AM   #75
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
VERY VERY nice work, I am really impressed with your repairs so far. I'm ready for more updates so get with it!!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
