Old 06-01-2012, 01:40 PM   #51
jhrusk
Re: SANFORD build thread
Thanks guys,lolife99 it is to the driver side,I did not center the r&p housing,the rack It has a 2 1/2 turn lock to lock,I centered it between left and right and tried to center the outer tie rod swivel which is under the boot,however I did manage to get it to the driver side about a 1/2 to far,I know It should be exactly centered but I am going to check the bumpsteer when I do the alignment,if things do not work out Speedway motors has a set of offset mounting bushings that I will use to move it.Time will tell but honestly for a cruiser I dont think I will notice any difference except maybe turning radius.Hope this makes sense.Thanks for looking guys.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 06-01-2012, 10:25 PM   #52
dbomb53
dbomb53's Avatar
Nice fab work, wheels and tires are killer. perfect stance.
"I wanna be like Dino when I grow up"
dbomb53 is offline   Reply With Quote
Old 06-08-2012, 01:41 AM   #53
Dinos63
chevy only
Dinos63's Avatar
bump
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-08-2012, 02:02 AM   #54
shrunken66stroker
shrunken66stroker's Avatar
Nice build. Sanford is looking good!
shrunken66stroker is offline   Reply With Quote
Old 06-08-2012, 04:22 PM   #55
jhrusk
update,I have just about everything finished in the rear,I was able to set my pinion angle and then I installed my lower bag mounts.I had to move the upper bag mounts in order to get the truck to sit where I wanted it to.I also braced everything up pretty good because I will be doing a little bit of towing with this thing,I got the shocks mounted as well.I am pretty much finished with the fabrication on the rear suspension just a little bit of final welding when I strip it down to paint it.I also re-purposed the factory bump stops so if it does bottom out it hopefully will not damage anything.Name:  mr holder racecar 032.jpg
Name:  mr holder racecar 033.jpg
Name:  mr holder racecar 034.jpg
Name:  mr holder racecar 035.jpg
Name:  mr holder racecar 036.jpg
Old 06-08-2012, 04:27 PM   #56
jhrusk
I also have most everything for the exhaust,I got a spare set of headers on the cheap that I will cut up and use to modify the ones I will use.well that is it for now. Thanks for lookingName:  mr holder racecar 038.jpg
Name:  mr holder racecar 039.jpg
Name:  mr holder racecar 031.jpg
Old 06-08-2012, 04:39 PM   #57
Dinos63
chevy only
Dinos63's Avatar
one of my favorite builds going on, such nice work on the rear
Old 06-15-2012, 07:10 PM   #58
OLDIRON69
subscribed
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 06-16-2012, 09:20 PM   #59
jhrusk
Just a small update,I have been working on some loose ends and one of those was getting the steering shaft made which in itself was not that hard however modifying the motor mount was a major PIA.I spent most of today doing that and re-enforcing the mounting tab on the trans mount.I also shortened my drive shaft so I will send it out to have balanced.I still have to make the upper shock mounts and then on to the exhaust.Name:  sanford 002.jpg
Old 06-16-2012, 09:30 PM   #60
jhrusk
this is what the shaft looks like and the motor mount mods complete,in some of my previous posts it was pointed out that my rack wasnt centered in the frame,I knew it was to the drivers side a little but after checking it with the crossmember in the frame rail it was off more than I thought so I cut it out and re-positioned it,so this was a screw up on my part but now is the time to fix it.That is how it goes sometimes and thanks for pointing that out.Thanks guys for looking. Name:  sanford 008.jpg
Old 07-22-2012, 07:59 PM   #61
jhrusk
not a lot to update,but I did finish modifying the headers and making the exhaust,I forgot to take a pic before I removed it from the truckName:  exh1.jpg
Old 07-22-2012, 08:01 PM   #62
jhrusk
Old 07-22-2012, 11:21 PM   #63
Dinos63
chevy only
Dinos63's Avatar
such nice work,killer job
Old 08-05-2012, 11:46 PM   #64
coulter
coulter's Avatar
Dang i havent checked up on this in a while!!! Killer fab work man!!! Keep it up its looking great
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 08-14-2012, 07:43 PM   #65
jhrusk
Just a small update.I am just about done with all the heavy fabrication,I still have a few things like front shock mounts,front sway bar ,trans linkage and so on.I still have to finish modifying the trailing arm crossmember and get the rear brake assemblies on and route the parking cables.I will blow this thing in the near future and paint the chassis and other components etc.thanks for looking.Thought I would trow a few pics of it together one last time before paint.Name:  sanford10.jpg
Old 08-14-2012, 07:45 PM   #66
jhrusk
few moreName:  sanford 15.jpg
Old 08-14-2012, 11:22 PM   #67
VA72C10
VA72C10
VA72C10's Avatar
Nice work! So...no issues with clearance with the exhaust at the notches?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-14-2012, 11:39 PM   #68
Corts60
Just here to tinker
Corts60's Avatar
Hol-y man. This is coming out super awesome. Looking forward to some paint shots. Inspiring build thread!
Old 08-14-2012, 11:54 PM   #69
Dinos63
chevy only
Dinos63's Avatar
always such nice work!
Old 08-15-2012, 05:56 AM   #70
mark 66
looks well laid out and tidy.nice job.
mark 66 is offline   Reply With Quote
Old 08-15-2012, 08:11 AM   #71
jhrusk
Thanks guys,VA72C10 it does appear it is hitting,but it is not.also this is at full drop and there is at the closest point about 3/8 clearance so I dont think there will be any problems.I have had this thing together and apart about 3 or 4 times to check for any unforseen problems.Hopefully this is the last time as I am about to lose a little steam on this project.Wife and I have made reservations for power tour next June so I better get on the ball.Thaks again.
Old 08-17-2012, 09:24 AM   #72
61 son of a Gun
61 son of a Gun's Avatar
Dig your work !
Hey, how exactly is a rainbow made?
How exactly does the sun set?
How exactly does the posi-trac
rear end on a Plymouth work?
It just does.
61 son of a Gun is offline   Reply With Quote
Old 09-03-2012, 04:14 PM   #73
jhrusk
got the engine ready to go in,currently cleaning and painting trans and other driveline components,will update Name:  sanford 017.jpg
Old 09-03-2012, 11:44 PM   #74
Dinos63
chevy only
Dinos63's Avatar
nice & clean
Old 09-04-2012, 09:18 AM   #75
dbomb53
dbomb53's Avatar
Damn..that motor color looks like a Jolly Rancher candy..makes you wanna lick it..wow did I say that!.. nice job
