Old 07-08-2012, 12:04 PM   #51
63split
63split's Avatar
Re: Dutch 1955 build
Originally Posted by Chevette View Post
Can't argue that logic. Keep up the good work. Looks real nice. BTW how are you going to grind the welds on the inside of the original part of the frame when you fill the holes, now that you have boxed it?
i will use a copper plate behind it while welding them up
to get a flat surface on the inside
63split is offline   Reply With Quote
Old 07-08-2012, 02:40 PM   #52
oldman3
oldman3's Avatar
Frame looks great....Jim
oldman3 is offline   Reply With Quote
Old 07-08-2012, 06:42 PM   #53
Kim57
Kim57's Avatar
The frame is looking real sharp.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-09-2012, 05:50 PM   #54
63split
63split's Avatar
just fit in a front cross brace right below where the radiator wil be
and pimped up the underside with some embossed
Old 07-09-2012, 06:36 PM   #55
Red Foreman
Red Foreman's Avatar
Your workmanship is incredible!
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 07-09-2012, 08:07 PM   #56
oldman3
oldman3's Avatar
Like the chevy bowties in the cross brace....Jim
Old 07-09-2012, 08:23 PM   #57
Kim57
Kim57's Avatar
That's sweet.
Kim
My build thread
Old 07-09-2012, 11:19 PM   #58
Kabwe
Certified Car Nut
Kabwe's Avatar
Amazing work.
Kabwe is offline   Reply With Quote
Old 07-10-2012, 08:46 AM   #59
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Very cool!
ChuckDriver is offline   Reply With Quote
Old 07-10-2012, 05:09 PM   #60
63split
63split's Avatar
made and tagged the last box plates in place and will weld them in tomorrow
counting 90 holes, I say enough.
Old 07-10-2012, 07:14 PM   #61
Kim57
Kim57's Avatar
Looking good. Love the lightening holes.
Kim
My build thread
Old 07-15-2012, 02:10 PM   #62
63split
63split's Avatar
got the frame done this weekend welded all useless holes in the frame rails
and put the engine back in for furter measurements and match up the diff. angle to the transmission angle
4 link in place and tag welded the diff. housing in place
Old 07-15-2012, 02:31 PM   #63
Kim57
Kim57's Avatar
Looking real nice.
Kim
My build thread
Old 07-15-2012, 04:39 PM   #64
OrrieG
OrrieG's Avatar
Nice clean accessory bracket installation on the engine. Too many of the aftermarket systems seems to be over done and wanting to show off the brackets rather than the engine. Frame is looking very cool too.
OrrieG is offline   Reply With Quote
Old 07-15-2012, 08:30 PM   #65
hotrod1
56 - autocross
hotrod1's Avatar
Very nice. How did you emboss that cross member with the bow ties?
hotrod1 is offline   Reply With Quote
Old 07-16-2012, 11:49 AM   #66
63split
63split's Avatar
its quite easy to do made a die out of 2 pieces of sheet metal, i wil take some picture's tonight
btw did the same trick on the panel truck
Old 07-16-2012, 12:11 PM   #67
hotrod1
56 - autocross
hotrod1's Avatar
That would be great to see. Those look great.
Old 07-16-2012, 04:25 PM   #68
63split
63split's Avatar
here the die´s i made for the bowtie just 1 bowtie and 1 larger cut out bowtie out of 1mm sheetmetal (19 gauge) like i said nothing fancy
Old 07-16-2012, 04:32 PM   #69
hotrod1
56 - autocross
hotrod1's Avatar
Did u just cut it out with a saw? What then? What gauge metal can you emboss? Do you use a press?
Old 07-16-2012, 04:52 PM   #70
63split
63split's Avatar
used an angle grinder with a thin cutting blade
the outher bowtie is made out of 2 pieces and welded back together
as you can see in the picture.
i made them only into 19 gauge sheet (1mm) but i am confident
thicker sheet would work too
i use a medium press (max 4400lbs) and press it between 2 thick piece of steel to spread the load equaly
Old 07-16-2012, 05:04 PM   #71
63split
63split's Avatar
also started to build a 304 stainless steel fuel tank
and made some beads in them with my new aquired bead roller toy
will add some more beads later
Old 07-16-2012, 08:08 PM   #72
oldman3
oldman3's Avatar
Nice....Jim
Old 07-17-2012, 05:31 PM   #73
63split
63split's Avatar
made some more beads in the tank
and installed some front suspension stuff and located where the c notches need to go for the steering rack
Old 07-17-2012, 07:02 PM   #74
seanery
seanery's Avatar
wow! very nice work! I have a friend who lives in Hellevoetsluis, it seems high quality work is a standard trait for the Dutch! He does beautiful things to Porsches.
seanery is offline   Reply With Quote
Old 07-18-2012, 01:48 AM   #75
Kim57
Kim57's Avatar
Looks real sharp.
Kim
My build thread
