#51 |
Re: MIG Weld Wire for Sheet Metal Repairs
There is a mig wire called "silicon bronze". I'm told by a friend that it works well at low temperature and hammers/grinds really well. Down side is that you must use 100% argon with it. Both my bottle are full of Co2/Argon 75/25 so I must wait til one is empty to try it.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
#52 |
WOW wait till i show my wife this!!!!
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
#53 |
Hu..hum. I think someone owes someone a beer.
#54 |
#55 |
![]() Join Date: Jul 2012
mmm beer
What kinda gas are you guys using? |
#56 |
Airgas 75% argon, 25% CO2 for me. This is the garden-variety gas for mig welding. If you do stainless you might want to consider a tri-mix of helium, argon & CO2. See your supplier about amounts of each. Aluminum works well with straight argon.
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
#57 |
a while back, i hadn't use my cheap old hf helmet for about 9 mths and it was just staying dark
i set it outside in direct sun for a couple of hours and the battery charged up that revived it for a couple more years until the head strap broke so yes; i'd say the flash sensor is also the solar cell for keeping the battery charged
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#58 |
if you are a welder were you work go were they get there items from most use Airgas and get there discount I have gotten 44 lbs rolls of .35/ .45 for $10 bucks so about $40 off , or at lest a 10% off if you say you are a student welder.
#59 |
I just picked up a Pro Mig 135 and need gas. Going to do some practicing on my Blazer before anything on the SWB. Good stuff here! Going to get some smaller wire now.
I have a auto helmet from Lowe's and it's the best thing that ever happened to my welds. Solar powered and I always test it prior to welding with a quick flash from a Bic lighter. Skylight in the shed keeps it charged and ready! ![]()
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#60 |
![]() ![]() Join Date: Nov 2008
What I noticed the last time I used my Harbor Freight metallic blue auto helmet is that it didn't turn on! Like an idiot, I flashd myself TWICE (DOH!) before I realized I had to turn it on manually inside the hood where the darkness adjustment is. It actually clicks from Off to On. Once I turned it on - and I hadn't used it in months - it worked perfectly.
#61 | |
