Old 11-29-2012, 11:39 PM   #51
CrewCab59
CrewCab59's Avatar
Re: NV4500/NP205 question (s)
The round pattern Np205 that had Th400 were short inputs, the Np205 that had 4l80E had long input. The short input will bolt up and yes the rear tail housing has to be notched for the shift rails.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 11-30-2012, 01:32 AM   #52
ryanroo
ryanroo's Avatar
All round pattern 205s came stock with long inputs. It was done to streamline the manufacturing so one input was used for all trannys. The shorts came in the racetrack 205s behind th400s only. The inputs are interchangeable.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 11-30-2012, 12:44 PM   #53
72BBCK20
Believe me, I've been down this road and have done extensive research plus I have access to a GM 4x4 salvage yard with just about every single model and year of GM. So the round NP205 comes with a short 32 spl if behind a th400 (86+) and long 32 spl if behind a SM465 (86+) using either input shaft will require notching the tail housing. I am currently running a 6 bolt round NP205, long 32spl, AA spacer and had to notch the tail housing for rail clearance. You also mention using the guts of an older ( 8 track?) NP205. this is not a good idea IMO. because the older np205's have a smaller bore input shaft bearing plus it is not sealed i.e. same oil needed in the T/C as the trans. plus the older NP205's have 10 spl front and rear output shafts, if you're running a big power plant diesel or 454 the shafts will not last long. as minimum you need the rear output to be a 32spl and the front 30spl (standard in 6 bolt 32 spl GM np205's). If your doing hard core off road with execsive driveline angles and 40"+ tires then you need the 32spl front input shaft from a ford or dodge NP205. And don't forget that you will need the bracket to mount the T/C shifter as the NV4500 does not have a mounting boss.
72BBCK20 is offline   Reply With Quote
Old 11-30-2012, 01:53 PM   #54
Redcap
Not true.
Redcap is offline   Reply With Quote
Old 11-30-2012, 09:24 PM   #55
ryanroo
ryanroo's Avatar
i would like to see a pic of the adapter and case. every STOCK set up i've seen has a long 32spl input for every tranny after early '85. i have a TH400 case in my jeep. it had a long output. i have a 205/465 in my parts pile. long input. even the outputs on the TH400 changed for the later 85s-end of production. what would the reasoning be to completely change the case and add yet another input to the pile GM already used? why would they not just keep what they had?
72 K20 12v build
Old 11-30-2012, 11:07 PM   #56
SunSoaked
SunSoaked's Avatar
I'm getting a NOS 32 spline input and bearing with the case. Input bore size should be irrelevant. Please explain what "not sealed" means. With a newer case and newer input it obviously has a "newer seal"? Any seal other than the input shouldn't matter, no?
I'll have to check the rear outputs tomorrow. I dont think they are 10 spline but I would generally agree. I'm only running a vortec 383 with pro-flo injection. I'm not expecting monster shaft breaking torque. 33 or 35 inch tires (2-3 inch lift).
As for the shifter mounts, I dont know what I need yet, but it's getting "twin sticked" if that makes any difference. This is all new to me, so until I start bolting it all together in a few weeks, I'm not sure what I'll need.
SunSoaked is offline   Reply With Quote
Old 12-01-2012, 01:52 PM   #57
72BBCK20
Hi there, if you're running a round NP205 with 32spl input then your good this is what you need. what I meant about the older racetrack np205 is that the input shaft bearing is actually smaller than the one found in the round np205. also the racetrack 205's do not have a seal on the input whereas the round's do. So your all good. As for your twin stick you we still need the same bracket from AA as previously mentionned or if your buying a twin stick kit then you can probably get a bracket from the stick suppiler. This pic is from AA site, disregard the kit as this is not what you need, however the black bracket at the bottom left is what I am talking about
As for the 383 vortec you should be fine with a 32spl rear output and 30 front output.
Old 12-01-2012, 04:28 PM   #58
ryanroo
ryanroo's Avatar
i used that shifter bracket on my GMC. i wasnt impressed. i would either build my own or rework that one if you used it. it was pretty floppy.
Ryan
72 K20 12v build
Old 12-01-2012, 08:39 PM   #59
CrewCab59
CrewCab59's Avatar
The difference in the out put lenght is because of the adapters and drive couplers.
Th400 used long and short ( Np205,Np208 and Np241 )
4l80e are all long
Sm465 all long 32 spline after 85
1971 Chevy C/10
Old 12-02-2012, 08:14 AM   #60
72BBCK20
Crewcab is correct about the input shafts, I've heard of long input mated to a TH400 but have only even seen shorts.
Also Like I mentioned before I didn't use the bracket from AA because yes it's flimsy however you will need to come up with something.
Old 12-03-2012, 08:51 PM   #61
70custom20
70custom20's Avatar
The round pattern 205 I have has a long input. I don't know what trans was originally in front of it, but I do know that the TC had ATF in it when I drained it. I plan on buying a new short input shaft from ORD and bolting the trans and transfer case directly together to keep it as short as possible.
70custom20 is offline   Reply With Quote
Old 12-03-2012, 11:23 PM   #62
Redcap
Refill it with gear oil.
Old 12-04-2012, 07:56 AM   #63
70custom20
70custom20's Avatar
Yeah, I plan on doing that. I wasn't really sure why a gear driven case was ever had ATF in it in the first place.
Old 12-04-2012, 03:03 PM   #64
CrewCab59
CrewCab59's Avatar
Some use ATF because of the cold temps not saying it's the best or right.
1971 Chevy C/10
Old 12-04-2012, 10:42 PM   #65
ryanroo
ryanroo's Avatar
ive seen them with ATF, 90w, 140w, and it was recomended to me that if you have it behind a 4500 to run the synthetic fluid for the 4500 in it in case the cases swap oil. its pretty hard to mess up a 205, as long as it has something oily in it. i use good old 80w90 in mine, but usually try to run a good synthetic.
72 K20 12v build
Old 12-04-2012, 11:07 PM   #66
SunSoaked
SunSoaked's Avatar
Got my NOS roundy 205 case and input today. Next on the list is a new 32 spline front output. Then wrap it up with new bearings and I got my brand new 05 t-case. Next week the 4500 should be here. Mongo happy
