12-09-2012, 04:03 PM | #51 |
Re: Green trucks
I am 95% sure that is a factory green white color combination for 1972.
the paint is newer so it shines real well and just a little brighter due to it being new. seeing you have your front end off could you look at the inside of your left front frame and the brake line junctions for me? if so I'll tell you what i am looking for. mine has had all the steel brake lines changed over it's 40 years, i have a new kit and a couple location questions and fitting questions. where the 2 lines from the diverter valve (master cylinder) meet inside the frame is my question area. |
12-09-2012, 04:06 PM | #52 |
Re: Green trucks
i still have the factory lines as far as i know and could take pictures for you, im changing all mine over to 79 half ton brakes disc brakes baby!!
1969 C2500 350/np435 1983 malibu wagon vortec 350/700r4 Gillis |
12-09-2012, 04:13 PM | #53 |
Re: Green trucks
great! take a pic of the lines where they all meet inside the left front frame,
should be a tee at the line from the diverter to the 2 front brakes, one heading each way up and down the frame. another junction from the diverter line that connects right there too for the rear brakes, i cant figure out if the rear brake line has a 90 or just a straight union where they join. i haven't installed all the lines yet, but i have them all figured out where they go. i dont really want to start until i have everything needed. Thanks! |
12-09-2012, 05:59 PM | #54 |
Re: Green trucks
1971 GMC, dark olive green, running torque thrusts, 15x7's up front, 15x9's in the back.
12-09-2012, 06:30 PM | #55 |
Re: Green trucks
my apologies, i just realized i was calling the proportion valve a diverter valve.
I'm sure you knew what i was asking for though. 72's and hydraulic brakes are not field of expertise. I work on big trucks and heavy equipment for a living. |
12-09-2012, 07:11 PM | #56 |
Re: Green trucks
Med Olive Metalliac
12-10-2012, 09:54 AM | #57 |
Re: Green trucks
Some nice looking trucks.
12-10-2012, 10:46 AM | #58 |
Re: Green trucks
Last edited by eastxbbqman; 12-10-2012 at 10:47 AM. Reason: didnt know what I was doin |
12-10-2012, 12:44 PM | #59 |
Re: Green trucks
Very nice truck. Can you give some more specs on it? Lift, tire size, etc. Maybe PM me as to not hyjack this thread. Thanks
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
12-10-2012, 01:59 PM | #60 |
Re: Green trucks
what that is is a 1972 2WD cab on a 71 1/2 ton 4WD chassis.
it has a Sky Jacker 8" lift kit, front in the pic is a 4:88 ratio Dana 44, rear is a 4:88 GM 14 bolt with lincoln lockers. there both brand new internals. it had a manual valve body TH350 with a 3800 stall converter, now a regular TH350 with a 205 transfer case and a 2200 stall converter. it had no motor, i built up a 10.7 CR aluminum head 355 with a 488 lift hydraulic cam, through the 3" exhaust it is loud, it dumps out in front of the rear tires. sounds good to me! I have 2 new drive axles ready to install, changing it to 3:73, both are 8 lug GM, 10 bolt front, 14 rear with regular spider gears. Tires are Mickey Thompson 35 17.5 15 one of Baja claw models. it was built for a dune truck by the 2 previous owners, i have been changing it back to a street use truck. i have been working on it every spare minute i get. i have just under 10 grand in it now. i think I'm OK. |
12-10-2012, 04:01 PM | #61 |
Re: Green trucks
Awesome truck. Best color IMO. Even the black wheels fit..
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
12-13-2012, 02:21 AM | #62 |
Re: Green trucks
Green trucks huh? can this one play? The guy that owns this truck said he would let me have it for the rite price. Not going to say rite now but thinking heavily on it.It does run and drive and the winches work. I have run this truck on a couple big truck wrecks a couple years ago when I was working there. We had 5 big truck accidents within 3 weeks of each other .It helped on all of them with no problems..It was geared quicker than the other truck but it done its share also.
12-13-2012, 12:55 PM | #63 |
Re: Green trucks
Here's Mine
72 GMC Sierra 02 Trans Am Firehawk 91 Firebird Formula 350 06 TBSS (RIP Wife T Boned at intersection ) 04 Tahoe 6" Lift 97 AWD Astro Work Vehicle/Beater |
12-13-2012, 01:07 PM | #64 |
Re: Green trucks
You probably don't count this as green.... But apparently GM did.
- 2010 Silverado - 1984 Chevy M1028 (K-30) - 1969 Chevy C-30 - 1933 Ford Stock Car Last edited by Shaun1162; 12-13-2012 at 01:12 PM. |
12-13-2012, 01:29 PM | #65 |
A day late and $1 short...
Re: Green trucks
Light green...
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
12-14-2012, 01:30 AM | #66 |
Re: Green trucks
Here's Nadine. |
12-14-2012, 01:53 AM | #67 | |
Re: Green trucks
He got best in original class,1st place,and something else. |
12-14-2012, 02:07 AM | #68 |
Re: Green trucks
thanks - wasn't sure if the el caminos shared truck or chevelle paint codes. guess that answers the age-old question... it's a truck. (that looks like a chevelle)
12-14-2012, 03:46 AM | #69 |
Re: Green trucks
The Circuit Rider
[IMG][/IMG]
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-14-2012, 12:40 PM | #70 |
Re: Green trucks
My dad's 69, and my brother's 71:
12-14-2012, 12:46 PM | #71 |
Re: Green trucks
Here is Sweet Pea.....
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
12-14-2012, 01:08 PM | #72 |
Florida Edition
Re: Green trucks
Seamist Green
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
12-14-2012, 02:18 PM | #73 |
Re: Green trucks
Sweet! I need to look up the paint code on mine.
12-15-2012, 01:47 PM | #74 |
Re: Green trucks
Renokeene, this is for you. Dad bought this 1971 C20 Custom Camper longhorn new, when he passed away I got it, about 4.5 years ago. It's dark olive, and mostly original. I'm trying to take care of it by fixing, replacing, cleaning, etc, but dad took really good care of it, so my job is minor, though expensive at times. The radio knobs have been replaced w originals. Enjoy the pics. For those who have seen this truck, sorry for the repeat.
Does anyone have pics of Option Code 629 Olive cloth trim? the upholstery is not original (I think someone on here called it scottish highlander tartan plaid wanna be, ha ha ah ) Last edited by dads longhorn; 12-15-2012 at 01:58 PM. |
12-15-2012, 02:04 PM | #75 |
Re: Green trucks
Turquoise
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
