01-04-2013, 12:55 PM | #51 | |
Re: 454 vs. 5.3 efi vs. 5.3 carbed
Best milage, maybe.. Lowest cost to operate? Probably not. With 87 octane at aprox $3.40 in California and Diesel at $4.10, if the math was done I bet the 5.3 might win. Posted via Mobile Device
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
01-04-2013, 01:33 PM | #52 |
meowMEOWmeowMEOW
isn't fuel basically priced by BTU output now? I though that almost fundamentally defeated the "diesel swap" mantra from a savings perspective.
It was different when diesel was .80 CHEAPER than regular.
01-04-2013, 05:39 PM | #53 |
The only reason I won't do a diesel swap is because when a diesel breaks down, parts are thousands of dollars. eff that. I'll do my entire ls swap for 2 thousand and when stuff breaks, spend a few bucks
01-04-2013, 06:35 PM | #54 |
Let me know how your 2000 dollar budget works! I haven't added up all of the little things yet but I'm over 2500 and climbing. I never looked back and I'd do it again. My S10-5.3 is a blast to drive
01-04-2013, 07:01 PM | #55 |
I definitely will do it again as well. I had a budget of $2000, but I spent $2400, and that includes all of the little things. Every bolt and paint can as well haha. I'm pretty sure I can do it again for cheaper.
01-04-2013, 07:12 PM | #56 |
I prob spent more that both of you...lol. and I'd do it again as well...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-04-2013, 07:57 PM | #57 | |
The only reason I spent over my 2K budget is because I splurged on stainless steel headers otherwise, I would've been under budget. |
01-04-2013, 08:07 PM | #58 |
I've done a few LM7 swaps and they can be done for under 2k if you have the ability to do some things yourself - harness, tune, plumbing and other things similar.
Current project is my 71, I'm hoping to get it done for ~1600. It's going to be close. As follows: Motor w/harness, all accy's - 500 4L60 w/converter - 200 Headers - 200 Mounts - 40 Intake tubing - 40 Driveshaft cut down - 80 - maybe, might have another shaft I can use. Fuel pump/filter - 120 Exhaust tubing - 60 E-fan - 80 Harness kit - 150 but I might just pay to have it whacked up, it's only another 200 so 350 if I do that. Still have a few things to do and pick up but nothing major. Fluids and the like. Not including costs associated with cam, head milling and/or converter as they are optional but what's the fun in a stock LS motor? Cam - 250 Springs - 250 Head gaskets - 100 Head Bolts - 60 Milling - 80 Converter - 400
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
01-04-2013, 08:39 PM | #59 |
thanks....I splurged on almost everything...lol.
01-05-2013, 01:52 AM | #60 |
Good thing is that where i come from nobody does any kind of custom anything unless its a honda lol. Plus my dad and the lady that owns the salvage yard are real good friends. Its all in my favor. Being im from north alabama, yall have any idea what a full 454/400 is worth? All acc and carb included?
01-18-2013, 10:27 PM | #61 | |
Figure maybe another 100 - 250 for the trans depending on condition. Lot more TH400's around than 454's. |
03-11-2013, 09:39 PM | #62 |
man you guys really drank the ls kool aid didnt you? with a good tune and an overdrive a 454 can easily get 15mpg, and as far as saying the ls motors are more reliable i can go out there right now and start my truck, from 110 degrees when i was living in texas to below 0 in ohio it has never failed to start in 7 years!
03-12-2013, 12:06 AM | #63 |
I can do the same, yet drive around your big block with the wheels up... just giving you a bad time. There is a place in the world for most every engine platform. Even an old school BBC
03-12-2013, 08:51 AM | #64 |
you know i was going to put a 6.0 in my truck but i kept talking to people with them in duallys and i kept hearing i would be lucky to get 12mpg, so i am just going to put the 4l80e from the combo in my truck and rebuild the 454 i figured i could get 400 hp and 550 ft lbs very easy out of it and get 15 mpg as opposed to the 6.0s 300 hp and 360 ft lbs, and be money ahead, but what to do with the lq4? hhmmm......i have a s480 turbo sitting around and a 66 chevelle....
03-12-2013, 12:34 PM | #65 |
Truck and auto performance nut
you're kidding right? LQ4 6.0's had various ratings (up to 325hp/370tq in '01 others may be higher)...w/o tweaking. The stock LS2 6.0 in my TBSS was factory rated 395hp/400tq...(ever looked at the air/fuel/spark tables on a factory tune?) a few tuning tweaks w/o opening it up could be producing over 450+?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
03-12-2013, 03:50 PM | #66 |
for a 2005 3/4 ton van the lq4 is rated at 290/360, thats what i have for what i would spend on a cam and lifters alone i could do a nice rebuild on the 454
oh and remember this is for a double cab dually, so horepower numbers are a moot point, its all about torque, whats it take to get a 6.0 up to 550 ft lbs?
"DON'T TOUCH THE TRIM!!"-Early Kyler |
03-12-2013, 03:59 PM | #67 | |
NAME: TRAVIS TRUCK: BRUISER 71 C/10 SWB 3.5/5" drop 4.11 GEARS. F.A.S.T. BBC 408 496hp/479ft/lb JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530 |
03-12-2013, 08:04 PM | #68 |
I won't argue that it is easier to get 550fltbs from a 454 vs a 362 which is what a 6.0 is. Heck, you have 92 extra cubic inches to help (roughly 25.5% more displacement).
The 454 would have to make 1.21ftlbs per ci where the 6.0 would have to make 1.52ftlbs per ci (roughly 26.5% more tq). That is a lot of tq to make up. Even with more compression (like the LS2) better heads, and optimized valve events, headers... It would be a stretch to get an honest 550tq out of it. Now, lets talk milage.. My wife's AWD trailblazer SS come with an aluminum 6.0. It makes an honest 400/400. It has no issues towing my racetruck to the track over some hills. On long freeway trips it will get high 18mpg. Mixed driving it will get high 15 to mid 16 depending on who is driving it (less if I do). Remember though, this is all wheel drive all the time, has 4.10 gears from the factory and weighs 4,900lbs. I think it will be hard to get a 454 to get the same milage a well optimized 6.0 will get given the same platform. With all that said, if you put a 4" crank in the 6.0 with ls6 heads and a ls6 cam, get the compression to 11-1, you would probably make that 550ftlbs and get better milage than the 454. Posted via Mobile Device
03-12-2013, 08:54 PM | #69 |
i will be happy with 15, i know i can do it, it hs been done too many time before, now 15 highway, i know theres no way in hell im getting that around town, i have 3.73 gears 30 inch tall tires and weigh 5800 lbs
03-13-2013, 09:04 AM | #70 |
Boosted Member
I just have a hard time with a gas engine in a tow rig no matter what the platform is
However, I've been spoiled with a Dmax/Allison combo in my tow rig over the past 8 years. For what it's worth, I also have a hard time with Dmax guys who try to make them fast, lol.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
03-13-2013, 03:01 PM | #71 | |
03-13-2013, 05:21 PM | #72 | |
My '04 6.0 Denali is OK unloaded, but even a couple of quads on a single axle trailer has that thing spinning like a sewing machine up our AZ hills. RPM gauge to the right, fuel needle to the left. Blame torque management I guess, but overall it is not that impressive.
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
03-13-2013, 06:46 PM | #73 |
Boosted Member
They payment was only $740 / month for the first 5 years. Been paid for a few years now, has 202k miles on it, and all i put into it is fuel, oil changes, and tires.
Still hauls just fine through the Ozarks...even with a bit of a load. haha To the OP...I'd sell the BBC to someone for more than it's worth (seems easy to do with BBC stuff...), pick up a junkyard 5.3, and find a used magnacharger for it. Reliability and strength of the LS, with the torque of the BBC. http://www.lsxtv.com/news/swap-insan...ered-jet-boat/ However, I'm biased...been there done that...I replaced a cammed 454 carb motor in my jet boat with a stock with cammed EFI 6.0L....picked up 3 mph, docking manners, fuel economy and "OMFG" reactions at the ramp
03-18-2013, 11:30 AM | #74 |
04-02-2013, 09:52 PM | #75 |
Im n process of switching from BBC to 5.3 with turbo. I like how they look but loosing the weight and now the ease of power for low price was a no brainer for me.
