Old 06-03-2013, 08:11 PM   #51
williamsboys
williamsboys's Avatar
Re: 66 pro-touring build
Where did u get ur driveshaft?
Williamsboy
williamsboys is offline   Reply With Quote
Old 06-04-2013, 01:24 AM   #52
Captainfab
60-66 Nut
Somehow I missed your dash mod until now. I like it .......kind of has a little '60-'63 dash look to it.
Old 06-04-2013, 02:12 AM   #53
Benny-
impressive! I love what you're doing, giving me some great ideas for mine.
Benny- is offline   Reply With Quote
Old 06-04-2013, 07:50 AM   #54
66shortwide
Denny's driveshafts is who made the shaft - they were great to work with. Asked all the right questions before making a recommendation on what i needed.
Trent
12 Cadillac CTS-V
07 Sierra HD 4x4 Duramax
66 C10 Short Wide
63 Chevy II(nova)
66shortwide is offline   Reply With Quote
Old 06-04-2013, 11:03 PM   #55
Hideintire
Hideintire's Avatar
Hello!
Really nice build-up. Thank you for sharing!
I have been thinking of doing this and would like to ask a question...How did you determine the ride height? Are you planning on say a 4/6 drop roughly from stock or much more? Did the Flat Out crossmember allow you different ride height options? Could you have went with only a 2" drop? I am only using these drop dims. for reference...something I can relate to. Did you do the "C-Notch" like shape in the rear because you were planning say...an 8" drop?
I am an old-timer and I am not into the "lay it on the ground" look...I want a truck that handles like a C4/C5 but will function somewhat like a truck when needed. It is surprising how close the weights match from the C4 to the C10...I have even considered installing a C5 rear transaxle setup, but I am not sure I want to deal with the large driveshaft hump required.
One other thought...could you not get the engine behind the rack like it is in the Corvette? Was it just to much set-back into the firewall?
Thanks for the time you are investing in this article...it means a lot to fellow hot rodders!
Jimmy
Hideintire is offline   Reply With Quote
Old 06-05-2013, 09:45 AM   #56
66shortwide
Honestly, I just set ride height with a 28" tire height and the front lower control arms level to the ground - then built the rear to match. With the flat out engineering front crossmember, you could have raised or lowered it some before welding to get the drop you wanted. With my build the plan is for autox and roadracing with some cruising and street driving, so I wanted it as low as possible. Currently at ride height the frame under the cab is 7" off of the ground.
The step notch needed to be that high and long to get the rear end up high enough to match the front. I set up ride height on the rear with the lower link bar level.
The rack is only a little higher than the crossmember, so to move the engine back more it would have to be raised. Also if moved back another foot, it would really effect foot space and floor space inthe cab. On a "race" truck it would probably be worth it, but as a driver not sure.
Not sure what the official drop measurements would be, as I didnt start with a complete truck to see how much the difference would be. I usually just get a wild hair and do it, then figure out what it changes after. I know what I want in my head, just most of the time I'm not 100% sure how to get there, so I just start going and by about the 3rd time doing it I have what I want!!
Trent
12 Cadillac CTS-V
66 C10 Short Wide
63 Chevy II(nova)
Old 06-05-2013, 04:09 PM   #57
jimmydean
jimmydean's Avatar
This is the story of all my projects
Nice work.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 09-17-2013, 05:15 PM   #58
66shortwide
Been awhile since an update - had to go out of town for a while and work, plus got side tracked with a couple of other things.
Finally got 95% of the patch panels welded in and dressed on the cab. Ordered my rear wheels and tires - mickey thompson wheels 20X10.5 and 315/35 nitto invos. After a quick test, it looks like I will be able to run that same size in the front as well. I'll get some pics up soon of the little bit of progress i've made lately.
Trent
12 Cadillac CTS-V
66 C10 Short Wide
63 Chevy II(nova)
Old 09-19-2013, 07:58 PM   #59
66shortwide
Here is the pic of the wheel - due to the track with of the c4 corvette stuff it is a 20x10.5 with 7" of backspace. Still plenty of wheel without a big lip, not something you see very often in the classic truck world.
Trent
12 Cadillac CTS-V
66 C10 Short Wide
63 Chevy II(nova)
Old 09-19-2013, 09:48 PM   #60
likaroc13
Rollin' Old Skool
Nice looking wheels! I must admit when I got email notification of your previous post, I was thinking "how's he gonna fit a 20x10.5 up front?" Without realizing which thread it was from, I forgot about the Vette suspension.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 09-19-2013, 10:10 PM   #61
darkhorse970
darkhorse970's Avatar
Cool build! I will follow along.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 09-20-2013, 08:19 AM   #62
66shortwide
yeh, I was originally planing on running a 20x9 in the front, nut after getting the 10.5s in - i mocked them on the front and everything clears the suspension and frame. just need to get the front fenders on and see exactly how much clearance I have. The front track width is a couple inchs shorter than the rear, so I think it will be ok. we will see.
Trent
12 Cadillac CTS-V
66 C10 Short Wide
63 Chevy II(nova)
Old 09-20-2013, 10:21 AM   #63
Jeff La
Looking good and waiting for more pics LOL
Jeff La is offline   Reply With Quote
Old 09-29-2013, 04:24 PM   #64
66shortwide
finally had some time to sneak out to the shop and try to get some work done. Mounted the cab back on the frame, hopefully for the last time in mock-up, threw the bed on and a front fender to try and get some motivation back. Also started widening the wheelwells to fit the 315 tires. Looks like a 315 on the front will just touch the frame at full steering lock, so thinking of going with 295 for the front tires.
Trent
12 Cadillac CTS-V
66 C10 Short Wide
63 Chevy II(nova)
Old 09-29-2013, 04:44 PM   #65
poorboy
poorboy's Avatar
Awesome build!
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 09-29-2013, 08:09 PM   #66
mud.man.rj
mud.man.rj's Avatar
cool, nothing like pushing the tire size, do it all the time.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 12-02-2013, 08:49 PM   #67
66shortwide
Got a little time during thanksgiving holiday to do some more work on the cab. Got the vintage air mocked up and holes drilled, then started working on the dash vents, a/c control, and radio. Also got my painless wiring harness - went with the integrated chassis and engine harness, also got my gauge package in. Here are some quick mock up pics.
Trent
12 Cadillac CTS-V
66 C10 Short Wide
63 Chevy II(nova)
Old 12-02-2013, 08:54 PM   #68
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Looks good! Nice work!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-16-2014, 12:05 PM   #69
hotrod1
56 - autocross
hotrod1's Avatar
Hey, any updates? I want to see pics of that dash install.
hotrod1 is offline   Reply With Quote
Old 03-16-2014, 04:13 PM   #70
McMurphy
McMurphy's Avatar
What are the two screens on the guage set up for? I am guessing they show idiot lights symbols like check engine, fasten seatbelts, stuff like that ??
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 03-17-2014, 07:53 PM   #71
duallyjams
duallyjams's Avatar
Cool build hope your still working on it.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-24-2014, 07:01 PM   #72
mr incredible
mr incredible's Avatar
guess it's lost
USN RETIRED
there are two things you don't need in the navy. that's a wife and a pick up truck. cause when your out to sea someone else is using them
mr incredible is offline   Reply With Quote
Old 08-21-2014, 10:29 AM   #73
66shortwide
its been over a year since my last post - where does the time go? Finished most of the cab and got it mounted on the frame. Sprayed bed liner on the bottom of the cab. Have decided to go seude(spelling?) on the paint - so, gloss on the inside the engine compartment and seude everywhere else.
Decided that I needed to get the interior painted so I could start reassembly just to try and get remotivated. That is done and dash and air conditioning assembly has started as well as wiring. Below is a cell phone pic of where it sits today. Hopefully I can get some time on this poject and get-r-done.
Trent
12 Cadillac CTS-V
66 C10 Short Wide
63 Chevy II(nova)
Old 08-21-2014, 10:33 AM   #74
66shortwide
the two screens are dispays that you can set to show different read outs of voltage, trans temp, oil temp, PRND, etc.
Ended up changing jobs and the new job requires alot more travel which of course means less time for the truck. I plan on getting some real pictures for the next update as well as trying to stay current on my post.
Trent
12 Cadillac CTS-V
66 C10 Short Wide
63 Chevy II(nova)
Old 08-21-2014, 11:01 AM   #75
likaroc13
Rollin' Old Skool
Glad you're back on it! Life does get in the way sometimes. I like the suede paint idea. How is that achieved? Do you just reduce the gloss a certain percentage?
Phillip
My Build threads:
Pics:
Previous Rides:
