View Poll Results: which paint job looks best?
1 0 0%
2 0 0%
3 1 5.88%
4 0 0%
5 0 0%
6 0 0%
7 6 35.29%
8 2 11.76%
9 4 23.53%
10 1 5.88%
11 1 5.88%
12 4 23.53%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
Old 04-14-2013, 05:11 PM   #51
71' Custom
71' Custom's Avatar
Re: 71' (gonna be) a one of a kind custom
Originally Posted by 72_ChevyMan View Post
Love your truck man. I got a few questions about ur gauges... what brand are they? How did you get them led and did you have to wire different? Been wanting to do the same in my dash
It was relatively easy to do, just a little shaving to the bezel. Mine are auto meter phantom II. Had to completely rewire the whole thing. But, at the time, I had rewired the whole truck with the painless 18 circuit kit.
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Project: Under Pressure II
http://www.67-72chevytrucks.com/vboa...d.php?t=559720
71' Custom is offline   Reply With Quote
Old 04-15-2013, 12:09 AM   #52
71' Custom
71' Custom's Avatar
Originally Posted by calvin78612 View Post
Try Southwestern Classics in Arlington,or Sasche hotrod shop.
Thanks, I will try those out
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 04-16-2013, 08:00 PM   #53
71' Custom
71' Custom's Avatar
Well, there is one lower control arm "on"
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 04-17-2013, 11:40 AM   #54
71' Custom
71' Custom's Avatar
been thinking a lot about the paint job on the truck, originally i was thinking just matte black with some blue accents. i also want to shave the handles and the marker lights. the problem i am having is accenting with the blue is hard to do when there is no trim down the side of the truck. i thought about pin striping and still kinda like the idea but with that i was also feeling like the truck will also need some contrast as well. so here is my idea: doing a "factory" style paint job with the matte black as the base and a gloss black as the secondary color with the blue molding or blue pin striping. what does everybody think?
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 04-21-2013, 11:20 PM   #55
71' Custom
71' Custom's Avatar
Size:  51.9 KBPosted via Mobile Device
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 04-21-2013, 11:21 PM   #56
71' Custom
71' Custom's Avatar
Spindles will be here in a couple of days
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 04-23-2013, 10:20 PM   #57
71' Custom
71' Custom's Avatar
Spindles installed...........
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 04-24-2013, 01:11 PM   #58
Low Elco
STOP RIGHT THERE! Go right now and get one of your dust shields and try it on. If it doesn't fall right on and lay right down on your mount pads, you're gonna have to grind hell out of the bottom side of the upright to get them to fit/wheel to go on and seat and turn. Had the same problem with the CPP spindles on Yeller. Word to the wise. Our Pass one was fine, Driver's was AFU. At least it was oversize and only cost me 2.5 hrs of grind and fit. Good luck, progress looks great!
Low Elco is offline   Reply With Quote
Old 04-24-2013, 01:23 PM   #59
67cheby
67cheby
67cheby's Avatar
looking good man !
67cheby is offline   Reply With Quote
Old 04-24-2013, 01:44 PM   #60
71' Custom
71' Custom's Avatar
Don't have the new dust shields yet, putting the willwood 6 piston brake system on the truck. I will pay close attention to that though, thanks!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 04-26-2013, 03:47 AM   #61
wayne72
wayne72's Avatar
nice job! what year spindles did you have to order for the hotchkis set up?Im getting all my parts together and I can't remember the year for that ball joint set up ,Thanks and keep up the great work!
wayne72 is offline   Reply With Quote
Old 04-26-2013, 09:33 AM   #62
71' Custom
71' Custom's Avatar
The spindles I ordered were "technically" for the 71-72. I did a lot of research making sure these were the correct ones for the setup I am going with (the hotchkis suspension and the willwood 6-piston brake setup). And these are the ones I kept coming up with every time without fail. These are just for a 2" drop, didn't want to drop the truck too much. Part number on them is CP30106-3.
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 05-09-2013, 03:04 PM   #63
71' Custom
71' Custom's Avatar
found my upper control arm spacers i was looking for and got the other side put together. now just need to clean up the garage, lol
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 05-09-2013, 05:42 PM   #64
71' Custom
71' Custom's Avatar
here is the next step......
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 05-27-2013, 03:28 PM   #65
71' Custom
71' Custom's Avatar
Has anyone here installed the No Limit rack and pinion kit? I just found it on an ad at the top of the page. It is less expensive than the one I was looking at, but looks like it requires a lot more fab work. Just wanted to see if anyone had any run-ins with it?
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 05-27-2013, 03:39 PM   #66
Hardesty454
Hardesty454's Avatar
I haven't yet but I've read a lot about them. They are a little bit m
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 05-27-2013, 03:40 PM   #67
Hardesty454
Sorry...
More fab work, but rob from. No limit has an account here and seems to not mind helping people with questions or issues. I'd rather buy theirs (which is what I'm doing) rather than the other brands.
Rob
Old 05-27-2013, 04:33 PM   #68
71' Custom
71' Custom's Avatar
Yeah, I am leaning heavily toward the no limit kit, I just hate the thought of grinding and cutting on my powder coated frame. It was probably inevitable though.
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 05-27-2013, 04:40 PM   #69
Hardesty454
Inevitable yes. If you're good, you can touch it up with paint from your powdercoater. I'm a fabricator and all my stuff I do I get matching paint from my coater for touch up.
Rob
Old 05-27-2013, 05:04 PM   #70
VA72C10
VA72C10
VA72C10's Avatar
Nice looking project! I see you're using some quality parts on the suspension!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-27-2013, 05:15 PM   #71
71' Custom
71' Custom's Avatar
Yeah, I am still in touch with the shop that did the work so I guess I can go see them for that, thanks!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 05-27-2013, 05:18 PM   #72
71' Custom
71' Custom's Avatar
Yes, nothing but the best! I want a real quality ride, did a LOT of research before choosing. Those quality parts just have that big price tag to go with it, but well worth it from what I hear!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 05-31-2013, 12:01 AM   #73
71' Custom
71' Custom's Avatar
Been rethinking the wheels, what does everybody think of these?
Will still have to paint the brushed part blue, can't have that brushed aluminum
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 05-31-2013, 12:48 AM   #74
BossHogg69
motor exploder
BossHogg69's Avatar
Those would look great with blue accents. I like that idea better than the Ridler's with a blue rim.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-04-2013, 11:24 AM   #75
71' Custom
71' Custom's Avatar
Yeah, those Ridler wheels are just too over done.
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
