Old 12-21-2015, 03:26 PM   #51
davepl
davepl's Avatar
Re: Anyone: Delco Pleasur-lift air shocks w POWER PAC compressor?
Wow, I really need one of these setups complete. I have the "shraeder fill" manual kind. Right now I have too much rake anyway, so haven't installed it yet.
BTW, on the topic of concealed carry and newly acquired firearms, I should throw this out there. I have three of them (non-fingerprint kind). Since a gun should be in a holster or a safe and never elsewhere, this makes it trivial:
http://www.gunvault.com/
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-22-2015, 01:10 AM   #52
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I have a complete NOS Pleasur-lift set up (not what's pictured above, another w hoses, mount hardware, etc. complete) - my brother shows no interest in using it on his 66 GTO sadly. If interested, shoot me a PM.
Old 05-01-2020, 03:02 PM   #53
kehstr
kehstr's Avatar
Sorry to revive a almost 5 year old thread, but I just got ahold of a gauge like you have pictured here, and want to set it up like Andy did.
My question. What line went where in the back of the gauge, and is the plug that is there suppose to be there? Just unsure how the gauge works
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 05-01-2020, 10:07 PM   #54
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Anyone: Delco Pleasur-lift air shocks w POWER PAC compressor?
Do you have the Vacuum pump also? One line is for the vacuum and the other is to go to the shocks.
I have this in the Ramp truck now hooked up to my air tank for pumping up tires and such. The fittings are the orignal's for it. I have a couple of extra's just in case one fails.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-01-2020, 10:12 PM   #55
Andy4639
Old member
Andy4639's Avatar
Here is how it looks now. I plugged the one inlet off since all this is a gauge for the air tank. I'm not using the vacuum pump.
Old 05-02-2020, 12:18 AM   #56
kehstr
kehstr's Avatar
After looking at your pictures I went right out to the garage and put air on the fitting on the gauge side. Gauge worked perfect! Pushed the center button, and the pressure bled off perfectly!
I plan to just use it as a gauge and do a momentary contact switch to an electric pump to air up my air helper springs just like you did earlier in the thread.
Where did you get a fitting to go into the back of the gauge?
I also am curious even though it is not relavent to me setting it up properly. How is the knob suppose to work? Is it suppose to allow more pressure the more you turn it??
@Chad's Fab
Old 05-02-2020, 07:22 AM   #57
Andy4639
Old member
Andy4639's Avatar
The knob is how you turned the Vacuum pump on when used. It didn't change pressure it was a ON/OFF only.
Old 07-10-2020, 04:42 PM   #58
kehstr
kehstr's Avatar
I appreciate your help Andy!
One final question.
Do you remember the part number for the fitting that holds the line in the back of the gauge? Or at least where you got it
@Chad's Fab
Old 07-10-2020, 10:12 PM   #59
Andy4639
Old member
Andy4639's Avatar
One final question.
Those fittings where what my dad had left over when he gave it to me. I got a few more from a member on here but ended up using all of them. I have no part numbers and not home to look.
Old 07-10-2020, 11:34 PM   #60
kehstr
kehstr's Avatar
Okay I understand. If you do find a part number would you please post it here?
@Chad's Fab
Old 07-11-2020, 09:52 AM   #61
Andy4639
Old member
Andy4639's Avatar
Will do sir!
