Old 11-05-2013, 02:08 AM   #51
swamp rat
swamp rat's Avatar
Re: 1968 GMC 3/4 Ton 4x4 lwb step side?
SaaaaaWeeeeeeetttttt!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-05-2013, 02:57 AM   #52
K20chevy
K20chevy's Avatar
Originally Posted by purdeydoubles View Post
I will do my best to get a picture tomorrow assuming it doesn't snow too much tonight and tomorrow! You say those are mag wheels? I don't know much about wheel styles, so you are teaching me what I have. The only bad things about those wheels, and tires for that matter, is that there is a pretty serious ding in the driver's rear wheel right in the bead area, the rubber is dry rotted, and even if the wheels were in good shape they are still 16.5". Darn!!!
Thanks, I´m really looking forward to the puicture. But no rush on it, if it snows, take it another day. I´ll survive!
Yes they look like mag wheels. You say they are 16.5" wheels. Too badm, tire choice is somewhat limited and expensive. BUT they do make these wheels in 16" too, which should fit your brakes fine. So maybe it would be wise to change then out for 16´s because one of yours is damaged anyways and the extra you spend on 16.5" tires, you can buy the 16" wheels and tires for about the same price. There was a website I found, they sell these and have prices too. I have to digg it up and send it to you.
I really love the stance of your truck! I´m looking for a truck similar to that myself. But keep it a little more old school, like yours, no go as crazy as I ahve with my current "never ending project".
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
Old 11-05-2013, 09:27 AM   #53
1972RedNeck
1972RedNeck's Avatar
Cool Truck!
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 11-05-2013, 10:20 AM   #54
nutsforchevys
nutsforchevys's Avatar
I love your truck!! Except the ford radio would have to go!
72 Super Cheyenne lwb 4X4 Ocra / White
88 Chevy 1 ton Dumptruck
88 Chevy 1ton Flat bed 4X4 white
nutsforchevys is offline   Reply With Quote
Old 12-18-2013, 10:08 AM   #55
K20chevy
K20chevy's Avatar
Any news on what you did? And did you remember to take the full side shot for me? If not, would you please do that for me? I´d appreciate that! Thanks!!!
Old 07-21-2014, 10:24 PM   #56
purdeydoubles
It's been a few months since i last updated, but i just had to drop the truck off at the mechanic's shop with a broken driver's side knuckle. We opened the rear differential cover and to my surprise, this truck does have 4.56 gears, which just happens to match the beautiful Dana 60 front diff sitting in his shop!
purdeydoubles is offline   Reply With Quote
Old 07-22-2014, 12:23 AM   #57
K20chevy
K20chevy's Avatar
Now if that is not a good reason to upgrade the front to the D60!! Remember do change the master cylinder and proportioning valve though as you are going from drum/drum to disc/drum!!
Does your original D44 have the 12" drum brakes? Are they still any good?
What did you do to break the knuckle?
Old 07-22-2014, 12:41 AM   #58
cheyenne shortstep
cheyenne shortstep's Avatar
You should take a look at the inside of those wheels and see what they are, if they are Ansen Sprints you've got something. Slot mags are my absolute favorite wheel and the only wheel I would put on a '67-'72 K20.
cheyenne shortstep is offline   Reply With Quote
Old 07-23-2014, 09:36 PM   #59
purdeydoubles
Yeah we will be doing the full disc conversion, hopefully the rear too, with all of the appropriate parts. Doing a high/crossover steer with 2wd steering gear box, detroit mechanical lockers front and rear, redesigned shock mounts up front, new suspension rear, ladder bars on the rear, and I am sure there are some other items I am forgetting. Big job but it is going to be great when it is done. As to how it broke, I have no clue. I haven't had it off road or anything crazy recently.
Old 07-23-2014, 09:53 PM   #60
purdeydoubles
I just checked out your build thread K20chevy, that is way too cool. I was planning on using the exact transmission and transfer case that you used in your build, but had no clue that anyone had done it and posted it here. I am planning on using the LSX454, which nearly pushes the limits of the torque rating of that transmission. That phase of the build will not happen though until probably next year.
