Old 06-12-2013, 11:43 AM   #51
TazmanB
TazmanB's Avatar
Re: Taking the leap to build
Thanks for the compliment VDog. I have not been able to find new original GM hinges. Both hinges on my truck are shot. The rear of the hood will not close, I have to push it down and the hood will not center between the fenders. When I took the hood off both hinges are twisted and the rivet holes are egged. I can get both hinges rebuilt for around $150 + shipping.
If you ask the question. Make sure you are ready for the answer.
69 C-10 Longbed (In Progress) Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=568171
TazmanB is offline   Reply With Quote
Old 06-27-2013, 12:08 PM   #52
TazmanB
TazmanB's Avatar
I was able to get a little bit of work done on my truck this weekend but not as much as I wanted to get done. I got the hood stripped inside and out and got it all sealed. I have a little bit of body work to do but nothing major, a few dings to hammer out then prime it up and it will be ready for paint.
Old 06-27-2013, 04:13 PM   #53
BigDaddyV
BigDaddyV's Avatar
Lookin good bud
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 07-03-2013, 02:52 PM   #54
TazmanB
TazmanB's Avatar
Originally Posted by BigDaddyV View Post
Lookin good bud
Old 07-03-2013, 03:02 PM   #55
TazmanB
TazmanB's Avatar
Well I started stripping down the cab this weekend. I got the seat out and laid in the floor of the cab and looked under the dash and man was I disappointed!! The inner cowl behind the dash was trashed and the PO had covered the rust up with fiberglass, and did not do a very good job at that. The more I looked at and the closer I got to everything is was obvious that the PO loved the use of fiberglass and did not like cutting out rusted metal. Over half the floor was fiberglassed, the kick panels and the rocker panels were all govers with fiberglass. After looking at all the damage and the attempted repair with fiberglass I figure I should just look for another cab. I was so disappointed I didnt even take pictures. I will take some pictures later this week and see who else thinks my cab is the star of a horror show.
Old 07-03-2013, 03:58 PM   #56
BigDaddyV
BigDaddyV's Avatar
Man I hate to hear that! I was lucky to get a truck that isn't to bad, just a few little spots i gotta cut out and fix.
Old 07-03-2013, 04:26 PM   #57
TazmanB
TazmanB's Avatar
I just realized I should have put this in the builds section. Maybe one of the Mods can move it over.
Old 07-13-2013, 09:21 PM   #58
TazmanB
TazmanB's Avatar
After looking all over for another cab in good condition I actually found one sitting at a used car lot around the corner from my house. How lucky is that now I just have to get it picked up and start working on it. Will post pics when I get a chance.
Old 07-13-2013, 09:56 PM   #59
VDOG
Grand PooBaa Member
VDOG's Avatar
Hood Hinges from Classic Industries
http://www.classicindustries.com/tru...onents/?q=Hood hinges&y=1972&p=1&sb=0
The Truck Shop
http://www.truckandcarshop.com/60-72...2013%20web.pdf
Both places cheaper than rebuilding.
VDOG is offline   Reply With Quote
Old 07-13-2013, 10:28 PM   #60
TazmanB
TazmanB's Avatar
The Truck Shop
Thanks for the info however I have a genuine RH hinge and looking to find a LH hinge now. No one has the left hinge.
Old 07-14-2013, 11:52 PM   #61
VDOG
Grand PooBaa Member
VDOG's Avatar
Im going to hit up a few guys I know here. What is up with not being able to find the left hinge?
Old 07-15-2013, 02:51 PM   #62
~Whitey~
~Whitey~'s Avatar
coming together good... That hood was alot of work huh!? been there!
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 07-15-2013, 07:32 PM   #63
TazmanB
TazmanB's Avatar
I don't know if they made fewer of them or sold more of them but genuine GM LH hinges for our trucks are very hard to find.
Old 07-15-2013, 07:33 PM   #64
TazmanB
TazmanB's Avatar
Yes it was.
Old 07-15-2013, 07:44 PM   #65
TazmanB
TazmanB's Avatar
Look what I got!!!! And on the cheap!!! It has a little rust on the passenger side just inside the pinch weld and the drivers side rocker needs to be replaced. Other than that it is excellent
Old 07-16-2013, 06:18 AM   #66
BigDaddyV
BigDaddyV's Avatar
Grats bud, Im sure it will be sharp as hell when you get done. Nice find.
Old 07-17-2013, 08:36 AM   #67
TazmanB
TazmanB's Avatar
Thanks. I hope it looks as good when its done as I think it will.
Old 07-17-2013, 01:52 PM   #68
calvin78612
calvin78612's Avatar
Good job on the body work ! Definitely not my strong point.If you need a hand with the cab let me know.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 07-17-2013, 06:54 PM   #69
Jeremy69
Great build you have going! I have just started on a short bed myself. I had a question though. What kind of sealer are you using after you strip the paint?
Jeremy69 is offline   Reply With Quote
Old 07-17-2013, 10:07 PM   #70
TazmanB
TazmanB's Avatar
Old 07-17-2013, 10:08 PM   #71
TazmanB
TazmanB's Avatar
I am using AIC black epoxy primer that I get from Sherwin Williams
Old 07-17-2013, 10:10 PM   #72
Jeremy69
Old 07-17-2013, 10:16 PM   #73
Shaun1162
Shaun1162's Avatar
Looks like an awsome project! Congrats on finding a clean cab too!
- 2010 Silverado
- 1984 Chevy M1028 (K-30)
- 1969 Chevy C-30
- 1933 Ford Stock Car
Shaun1162 is offline   Reply With Quote
Old 07-17-2013, 10:21 PM   #74
TazmanB
TazmanB's Avatar
Jeremy69 there are several different sealers you can use. AIC is not the most expensive out there nor is it the cheapest. I have used it on several projects in the past and have had great results with it. Good luck on your project
Old 07-17-2013, 10:24 PM   #75
TazmanB
TazmanB's Avatar
Thanks Shaun. I stumbled across this one and could not pass it up for the price. Hopefully it will be going to the blaster on Monday which will save be a butt load of time sanding on it.
