Old 05-22-2013, 01:52 PM   #51
plainred65
plainred65's Avatar
Re: 1966 F100 Short/Fleen Full Stock Resto Build Thread
Amazing work, you never disappoint!
plainred65 is offline   Reply With Quote
Old 05-31-2013, 04:57 PM   #52
ColoradoK5
ColoradoK5's Avatar
WOW great resto!
ColoradoK5 is offline   Reply With Quote
Old 06-12-2013, 10:47 AM   #53
theastronaut
theastronaut's Avatar
Originally Posted by ColoradoK5 View Post
WOW great resto!
Thanks guys!!
We converted the oil bath on the '66 to a paper filter using a universal 9" round Mr Gasket air cleaner. The height is perfect to keep the outer lid in the right position. No need to fabricate or weld in upper/lower plates to seal the filter or hunt around for the right filter. The original fiber filter was falling apart so we didn't want any of it getting it in the engine. Also didn't want it backfiring and puking oil all over the detailed engine!
Uncrimped the inner flange and cut the "spokes" around the edges to remove the old filter material that was disintegrating.
I still need to remove the inner ring on the original lid for more filter clearance.
The new air filter base fits perfectly over the original base. I will drill ~1" holes around the perimeter of the original base for easier air intake.
Just enough of the stud sticks through for the wingnut.
Finished up the mods on the air cleaner- drilling holes in the base for better air flow and cutting out the inner ring of the lid to clear the new inner filter. Then blasted and primed it with DPLF epoxy.
The new fuel lines came in so they're installed with new stainless clamps.
theastronaut is offline   Reply With Quote
Old 06-12-2013, 12:34 PM   #54
hopped up
hopped up's Avatar
Very nice work!! Great attention to details that many will never even see
hopped up is offline   Reply With Quote
Old 06-12-2013, 03:12 PM   #55
theastronaut
Thanks hopped up!!
Just painted/detailed the tie rods.
Cleaned the boots with 3M adhesive remover to clean the mold release wax off, then applied Duragloss Rubber and Vinyl Dressing, before and after.
Old 06-13-2013, 04:36 PM   #56
theastronaut
Air filter lid was sprayed with epoxy, minor dings filled and blocked flat, shot with high build, then flat areas blocked with 180, then wetsanded with 600. I sprayed it with the same single stage urethane we've been using, but added 25% flattener instead of the usual 33%.
Old 06-13-2013, 04:59 PM   #57
CC69Rat
CC69Rat's Avatar
You sir are the man..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-14-2013, 03:25 PM   #58
theastronaut
Thanks Chad! I know you'll appreciate the next update... I wetsanded/buffed the air filter lid, didn't like the slightly dull finish.
Old 06-16-2013, 09:53 AM   #59
chevyrestoguy
chevyrestoguy's Avatar
Again.........Speechless.
Top notch work, John!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 06-16-2013, 02:15 PM   #60
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Killer work!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-17-2013, 02:13 PM   #61
theastronaut
Originally Posted by 72BlckButy View Post
Killer work!
Thanks dudes!!
Stuck the repop decal on the lid. Can't wait to get the carb back from being rebuilt/restored so we can install it and the filter back on the engine.
Old 06-24-2013, 04:16 PM   #62
theastronaut
The carb came back today and it looks great! Also picked up some NOS clamps for the heater hoses and water pump bypass.
Chucked the clamps in the bead blaster and lightly went over them to brighten them up a bit.
Old 06-24-2013, 04:55 PM   #63
theastronaut
Carb, spacer, and filter in place.
Old 06-25-2013, 11:53 AM   #64
aggie91
I'm just glad to be here!
aggie91's Avatar
WOW, I am amazed with your work.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-28-2013, 09:15 PM   #65
duallyjams
duallyjams's Avatar
He only has one speed PERFECTION
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 06-29-2013, 10:47 AM   #66
manimal
manimal's Avatar
That is AMAZING work!
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-01-2013, 04:04 PM   #67
theastronaut
Thanks dudes!!!
I forgot to post these the other day, so here they are.
We cut out the floor pans and started trimming the new ones to fit. The don't fit well and they're missing the upper outside edges so we'll have to make those and weld them on. The inner rockers are mostly good except for the very front area where the hinge pillar meets up and overlaps. Whoever designed the way the cab metal assembles was an idiot... and further cements the reasons why I'm a Chevy guy
Screwed in over the original pans to mark the trim lines.
Cutting the floors out.
Making a template for the seat risor area.
Right side inner kick panel rust. This area is a PAIN to work around, and the layers of sandwiched metal layers is impossible to fix without tearing out good metal around it.
Upper kick panel edge along the toe boards.
The floor flange that welds to the kick panel underneath the truck, this was missing completely on the new pans... :-roll
The cab mount plates are solid.
Lower kick panel edge from the outside.
Drilled the spot welds...
Making the new floor pan flange to weld to the kick panel.
The inner rocker rust.
Starting to drill the spot welds and separate the inner rocker from the other layered panels.
Old 07-01-2013, 04:10 PM   #68
theastronaut
Started back on the right side rust repair today, got everything cut out and a couple pieces ready to weld back in.
Started by drilling the spot welds. These weren't welded to anything though...
Separating the layers.
Inner rocker out, exposing whats left of the kick panel layer.
Inside half of the inner rocker.
Making a paper template to fix the rusted spot.
Template transfered to metal, and I rolled a bead along the spot what will be the edge once its bent.
Bending the edge in the metal brake.
Edge detail.
Front edge folded up straight like the original piece.
Both pieces bead blasted, marking the original for cutting.
Old 07-01-2013, 04:14 PM   #69
theastronaut
Marked the lower cowl for cutting.
More hidden rust.
Cutting out the kick panel.
Floors, inner rocker, and kick panel rust completely cut out.
Ready for sandblasting, priming, and fitting/welding the new panels.
Fabbed and fitted the rear floor panel.
Old 07-01-2013, 08:06 PM   #70
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Amazing work for sure... Keep up the good work your builds are always so informative..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-01-2013, 09:16 PM   #71
plainred65
plainred65's Avatar
Wow, I'm thinking there's not a truck too far gone for you to bring back. Those look like complicated pieces to make with all those multiple bends and angles. I would love to be able to make panels like that.
Old 07-02-2013, 09:55 AM   #72
aggie91
aggie91's Avatar
That is a ton of work and a bunch of rust. Your work is top notch. I wish you were closer, I could have you do my cab for me...Oh Well, guess I'll have to learn from your work and pictures here...
Karl
The LST Challenge:
Old 07-02-2013, 03:08 PM   #73
theastronaut
Thanks Frenchblue!!
Thanks plainred, but we have limited tools and I'm still learning. But compared to many, this amount of rust is mild... very mild! Take a look over on thesamba.com in the Barndoor Bus section and have a look at what those guys are saving... That basket of green patch panels are just a little bit of the patch panels going into this bus... 10k worth of patch panels isn't unheard of in the Barndoor bus world!!
Here's the build thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=471779
Thanks Karl, yall are doing a great job on your son's truck!!
Old 07-02-2013, 03:22 PM   #74
theastronaut
Made the passenger side kick panel today. Had a couple beads to roll in it and I had to form a curved 90* flange on one edge.
I started comparing the original inner kick panel on the driver side to the patch I made yesterday, and there were differences that I didn't catch. The passenger side was rusted away badly and the template I made from that didn't carry over the original shape well enough. So I made a new template from the driver side and made two new pieces, L&R.
This shows the curved top flange that I made straight on yesterday's piece.
Making the top flanges.
Rolled a bead on the edge.
Welding the flange to the new inner rocker patch.
Smoothing the welds with a 2" grinder, being careful not to lose the details of the rolled edge.
Sanded with the DA to smooth the grinding marks.
Panel for the other side.
Old 07-02-2013, 03:44 PM   #75
chevyrestoguy
.... Whoever designed the way the cab metal assembles was an idiot... and further cements the reasons why I'm a Chevy guy
I agree 1000%. If you compare a Chevy/GMC cab to a comparable year Ford, there's no comparison. Ford likes to single-wall in places that GM will double wall. The GM cabs are WAY stronger structurally. The make-up of the Ford cab is such that it was like it was built backwards. The overlays are completely backwards, like you unfortunately discovered. You wind up damaging good metal on top in order to fix the bad metal underneath because the wrong part is flanged and spot-welded in an area that's completely inaccessable.
I know most guys are brand loyal, done to the bone. I have had the "discussion" with the Ford guys about the comparison of the '60s Ford and Chevy trucks, and have laid out all the differences. EVERY aspect of the Chevy is better, from the suspension, the engine, the transmission, and the body structure. I will give Ford credit in one area, though. Whoever designed their door latches did a great job. You can go to any clapped out Ford in the wrecking yard, and the doors close and latch soooo nice.
Other than that, their trucks are not even close.
My build threads:
