11-03-2013, 12:01 AM | #51 |
Re: goodmark repro bed
Putting a Dynacorn SWB (steel floor) together right now. Kind of a pain to get everything to line up (holes). Will put on the passenger bedside tomorrow. Will need to do some cutting an hammering to get the steel flap to slid in the tailgate area. I measured and there is 1/8 inch difference which is just enough to where it will nor slide in easily. The big problem is the steel floor by the tailgate area is not square (1/8 inch is all it takes to cause fitment issues). Wish my stock bed was not so rusted. The two stock bedsides had the lips where they bolt to the steel floor rusted so I went with a repro (and some dings in the sides). I will trade the old bedsides for some parts from my local Chevy truck store. He is a body man and will not have much trouble repairing them.
Vancouver Bob |
11-16-2013, 03:09 PM | #52 |
Got it together and it looks great. Really sucked to put it together (especially the wheel well tubs). Too much twisting and some reaming of bolt holes to get it all to fit together. Would go with a wood floor next time because you would be able to square up the bed and then drill the perimeter holes in the wood. The steel bed floor was off 1/4 inch where the tailgate and bedside meet on the right side. This caused some of the bolt holes on the perimeter to be off some. Wish my original bed was not so rusted.
Vancouver Bob |
11-16-2013, 03:27 PM | #53 | |
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
11-16-2013, 06:13 PM | #54 |
Here are photos of the completed cab. I had to get another inner fender (silver) because the original did not fit at all. Now to get it painted.
Vancouver Bob |
11-16-2013, 08:39 PM | #55 |
Looks more like a bed than a cab to me !!! "LOL"
Nice looking, what ever it is ???
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
11-16-2013, 08:45 PM | #56 |
BED! Too much knuckle and head banging putting this together
Vancouver Bob |
11-16-2013, 09:06 PM | #57 |
ok, I'll play along. We just fitted TriPlus bedsides (everything else is OE).
They aren't perfect by any means, but they are hefty. Here are some pics of things not right that we had to adjust. Driver's side: Front panel will not sit far up enough within the bedside to align. Needed cut. Also, there's a weld on the top/inside that needed hammered on also. Driver's side: Holes not aligning right. We drilled them out and used larger bolts. Passenger's side: Same thing. Tailgate alignment = ok Driver's front of bed slightly lower. I used rubber/tar like shimms that came with the wood kit to correct. Shimmed cross sill to frame. The driver's side top rail was bent too much over where it connects with the stake hole. This caused an unlevel look in the middle. To correct it, we busted the spot welds and allowed it to release. I doubt you'll get anything perfect. Yellow marks tiny dings etc... that will need attention. Other than that they are ok. Sorry for showing off my new bed wood floor Robert It was wood originally. We're almost finished with it. Need to drill the perimeter holes in the wood for the bedsides/tubs and paint.
project: "my happy mess" Last edited by litew8; 11-16-2013 at 09:15 PM. |
11-16-2013, 09:19 PM | #58 |
Very nice. Mine is a Dynacorn bed. Did not notice any dings on the outer bedside (or anywhere else for that matter). FYI - bolt heads on the front bed panel go on the outside of the bed (per the assembly manual).
Vancouver Bob |
11-16-2013, 09:26 PM | #59 |
Thanks! We are tearing it apart tomorrow night. Thanks for the correction.
project: "my happy mess" |
11-16-2013, 09:54 PM | #60 |
I used a Woodall floor and Mar-k head board with factory bedsides and every bolt fit perfect. very very happy with the parts
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
11-16-2013, 10:08 PM | #61 |
I had bought a repro Woodall fender, only to find it wasn't stamped right. No fixing this. Got my money back and replaced it with an OE donor.
12-14-2013, 01:09 PM | #62 |
Here are some photos of the painted bed. Really like the color combination. This bed looks sharp.
Vancouver Bob |
01-17-2014, 12:18 PM | #63 |
Well -- just to correct my comments from several months ago, I picked up my new bedsides from AMD yesterday. I got the bedsides, front panel (wood) and inner wheel tubs for $1139 picked up. All the OE beds I have found were steel floor, rusted around the normal areas and $1k minimum. If I went the OE route I would have changed out the steel floor, front panel, cross sills, etc. so I would have had $1k in two crusty bedsides needing blasted... and of course worked quite a bit.
AMD bedsides are nice fellas. I'd consider them for sure. I'll post up some pictures when I can.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
01-17-2014, 02:00 PM | #64 |
Good to hear Chad, hope to have mine in a few months
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
01-17-2014, 02:19 PM | #65 | |
01-17-2014, 02:37 PM | #66 |
I know a guy that owns a parts store, I got them through his store but my pricing is a little better if you know what I mean I have known him for 25+ yrs. I asked him if he'd want to sell more at that price and he said no. .. sigh. I talked to him back before Christmas and the pricing wasn't much better than their website. .. however; I talked to him a few weeks ago and apparently they had an overstock situation and he could get better pricing for them.. so I jumped on them.
AMD - Auto Metal Direct They are located in Cleveland GA as I understand it. Heavy guage stuff and the decision for me was the price. The whole bed kit from SoKy was $2k+. I bought a nice GM tailgate back before Christmas, it was taken off a low milage truck and put in storage. It hadn't seen the light of day for a lonnngg long time. Original paint, basically an NOS gate off maybe a 10-15k mile truck.. it has a few character scratches on it. I just need cross sills and the rear bed panel, of course hinges, tail light housings, etc. .. and I'll be all set. I wish I could get more bedsides I'd pass along the savings to you guys but it was a once in a lifetime deal.
01-17-2014, 09:18 PM | #67 |
Roto Reuter thats the name...
Good info. Subscribed.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
01-17-2014, 09:29 PM | #68 |
I restored my 70 with 90% repo parts..I had never been so frustrated. every F#*@ part did not fit or had some kind of issue.
1953 Chevy 3100 1964 Chevy Impala 1966 Chevy El Camino 1970 Chevy C10 Fleet Long 1972 Chevy C10 Step long 1985 Chevy K10 Fleet Short |
01-24-2014, 11:31 AM | #69 | |
01-24-2014, 08:07 PM | #70 |
Looks great (love the paint color). On the holes that do not align you may be able to use a long screw driver and "pull" them in line (if they are not too far off). If I had to do it over again I would compare the two panels and do some measurement to see if they are the same. If they were not then I would return them. The final result looks really good. I have attached some rear end photos.
Vancouver Bob |
06-13-2014, 08:42 PM | #71 |
Finally got my truck back from the body and paint shop. They did a great job. Unfortunately they took my door pillar VIN plate off when they painted it. Not real happy about that. At least they did not throw the plate out. Now I will need to rivet it back on.
Vancouver Bob |
06-13-2014, 10:38 PM | #72 |
VA72C10
looks fantastic! I'd require them to source and install the correct rosette rivets.
Looking for a 67-72 swb or blazer project in or around VA. |
06-14-2014, 12:20 AM | #73 |
Turned out real nice Robert.
06-14-2014, 10:11 PM | #74 |
I agree. Make them find correct rosettes. Love the color combo. Looks awesome.
11-03-2018, 11:08 AM | #75 |
An old thread, but still relevant and worth reviving, and I'm wondering (considering 4+ years old), are things still relatively the same?
It's been commented these parts are all sourced from the same place, but I don't know this if this is the case or not.(?) A list of 'brands/labels' (at least that I've seen): Woodall TriPlus KeyParts AMD Dynacorn (GoldenLeaf the same??) Goodmark With the above 'labels', It appears (only from what I've read on forums) folks have used Woodall, Triplus and AMD with acceptable/good results. Can anyone comment on other 'labels' that they've had acceptable/good results with? As well, can anyone comment on 'labels' they consider NOT acceptable? I'm simply trying to narrow to what brand/label to go with (and/or those to avoid). Next is price paid. I understand this will differ with vendor AND brand/label. But I'm just trying to get an idea on what the going rate is (with a focus on the acceptable panels) I am looking primarily at (shortbed) bedside panels and metal floor (since I plan to use my original panels for the rest). The best prices I've seen today are roughly $500 each for the bedsides and about $750 for the floor. A few more $$ will be saved with a discount/coupon and picking up in person. I want to confirm the label/brand for the prices I'm looking at since as we all know, the 'best' price could end up being for the worse parts. Thanks in advance for any information. Kevin |
