Old 11-04-2013, 03:10 PM   #51
EJC78
No Life Like Low Life
EJC78's Avatar
Re: Carbon-10
My Boyd welding gas tank came in and I also got the rear brakes installed. I also had to do some winter cleaning and bring the Impala in for the winter.
Eric
1978 Chevy Scottsdale
1960 Impala ZZ4
1965 Buick Riviera GS
2011 GMC Sierra Denali
EJC78 is offline   Reply With Quote
Old 11-10-2013, 01:26 AM   #52
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Carbon-10
Love the build. Following. ..
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-12-2013, 02:46 PM   #53
EJC78
EJC78's Avatar
Re: Carbon-10
Eric
1960 Impala ZZ4
Old 11-12-2013, 02:56 PM   #54
EJC78
EJC78's Avatar
Re: Carbon-10
Got the new dropmember installed and did a little body work to back of cab my body guy was amazed how bad the back panel under the window was. He said it was real wavy and on the passenger side was flat at the corner and the rear cab molding had a huge gap so he had to cut and pull the metal near the the window now it will line up almost perfect. I had him do it this way just in case I decide to run moldings. Also got rid of windshield wipers now it will have to remain a California car lol
Eric
1960 Impala ZZ4
Old 11-12-2013, 03:00 PM   #55
EJC78
EJC78's Avatar
Re: Carbon-10
more:
Eric
1960 Impala ZZ4
Old 11-17-2013, 01:15 PM   #56
mooseknuckles
mooseknuckles's Avatar
Re: Carbon-10
nice work!
mooseknuckles is offline   Reply With Quote
Old 11-22-2013, 02:59 PM   #57
EJC78
EJC78's Avatar
Re: Carbon-10
Originally Posted by mooseknuckles View Post
nice work!
Thanks, been a fan of your build as well nice interior looks awesome
Eric
1960 Impala ZZ4
Old 12-02-2013, 01:46 PM   #58
EJC78
EJC78's Avatar
Re: Carbon-10
I was able to work on the truck this weekend, and go pump some lead down range too. I had to modify the bracket for my gas tank. We also fooled around with the dash board set up.
Eric
1960 Impala ZZ4
Old 12-15-2013, 05:45 PM   #59
EJC78
EJC78's Avatar
Re: Carbon-10
Got some new goodies....
Eric
1960 Impala ZZ4
Old 12-18-2013, 02:11 PM   #60
EJC78
EJC78's Avatar
Re: Carbon-10
Got tanks Mounted
Eric
1960 Impala ZZ4
Old 12-18-2013, 06:42 PM   #61
mooseknuckles
Re: Carbon-10
nice!
Old 12-19-2013, 05:57 PM   #62
EJC78
EJC78's Avatar
Re: Carbon-10
My rims came in and I couldn't be happier with them Thanks to Travis @ Pro Performance and Chris @ Boyd's
Eric
1960 Impala ZZ4
Old 12-19-2013, 06:02 PM   #63
EJC78
EJC78's Avatar
Re: Carbon-10
Has any one ran a bag spacer on a PB drop member? My frame when fully deflated touches the ground and while I know that's what it is intended to do but on bag failure this could be a huge problem if I ran a 2" spacer this would give me a 1"-1.5" clearance. from the ground. your thoughts??? btw I'm running Slam Specialties SS series
Eric
1960 Impala ZZ4
Old 12-19-2013, 06:31 PM   #64
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Carbon-10
Instead of a bag spacer, why not set up a bump stop that can be adjusted for what ever aired out stance you want? If a bag fails, you would ride on the bump stop safely.
Just another thought. That why at a show, you could adjust the stop to let you lay frame...
BTW, the wheels came out great! What are the specs for the wheels and tires?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-20-2013, 12:41 PM   #65
melks
melks's Avatar
Re: Carbon-10
lookin good man, can't wait to see the finished product
1984 Chevrolet C10
melks is offline   Reply With Quote
Old 12-21-2013, 08:02 PM   #66
BigMike608
BigMike608's Avatar
Re: Carbon-10
Love the wheels!
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 12-22-2013, 09:38 AM   #67
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Carbon-10
This would be my suggestion as well. .If you run taller plates it will affect your air pressure at ride height. By running adjustable stops your pressure will be as intended.
The wheels look great.
Articles-
"Refining Sierra"
Old 01-06-2014, 01:36 PM   #68
EJC78
EJC78's Avatar
Re: Carbon-10
Got some work done on the C-10 was able to route the emergency brake cable and also ran some of my hard lines. Got the transmission tunnel modified. and ordered my matching steering wheel.
Eric
1960 Impala ZZ4
Old 01-06-2014, 02:32 PM   #69
Ric83
Ric83's Avatar
Re: Carbon-10
Wow, everything looks great... and the body isn't even on yet! Looking forward to the progress. Keep up the great work.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 01-06-2014, 03:09 PM   #70
woodwright
Enjoying left field
woodwright's Avatar
Re: Carbon-10
Do you have a part number for the ebrake calipers?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 01-21-2014, 03:09 PM   #71
EJC78
EJC78's Avatar
Re: Carbon-10
Started running hardlines and plumbing tanks compressors and bag lines. Also got some NOS side trim headlight bezels and grille upper and lower tail gate upper and lower. Was lucky enough to find a guy who had it all will post pics when package is opened.
Eric
1960 Impala ZZ4
Old 01-22-2014, 03:22 PM   #72
EJC78
EJC78's Avatar
Re: Carbon-10
Rich is getting ready to primer the floor then fab the custom interior.
Eric
1960 Impala ZZ4
Old 01-23-2014, 01:19 PM   #73
EJC78
EJC78's Avatar
Re: Carbon-10
floor primered now to fab interior
Eric
1960 Impala ZZ4
Old 01-23-2014, 02:03 PM   #74
mooseknuckles
Re: Carbon-10
nice!
Old 01-23-2014, 08:41 PM   #75
stepside83
stepside83's Avatar
Re: Carbon-10
this thing is looking good cant wait to see more
stepside83 is offline   Reply With Quote
