Old 10-15-2013, 08:14 PM   #51
lynnfield
The Waco Kid
lynnfield's Avatar
Re: First Steps LS Swap......
I have also been doing a lot of research on wire harnesses. I want the option to mount the ECM where I want so an aftermarket harness is the way to go. I think I am going to order one from speartech. I know its not the cheapest, but I have heard nothing but good things about this company and their products. I have checked out a few others, PSI conversions being one of them (definitely cheaper) and found both good and bad reviews about them. I think this is one of those instances where you get what you pay for.
One last thing, I have some ideas for getting the stock pedal to work with the composite one for the original look.
lynnfield is offline   Reply With Quote
Old 10-15-2013, 08:35 PM   #52
Blackpony
Blackpony's Avatar
I would highly suggest bp automotive for the wiring harness. Bill is a stand up guy that will Taylor the harness to fit your exact needs and vehicle. He offers a couple different levels for a base kit all the way to a better then oe harness with braided loom. You won't be disappointed!
Blackpony is offline   Reply With Quote
Old 10-19-2013, 06:13 PM   #53
lynnfield
The Waco Kid
lynnfield's Avatar
Motor is finally out! That was a pain trying to figure out all the plugs and not break anything........
Old 10-19-2013, 06:15 PM   #54
lynnfield
The Waco Kid
lynnfield's Avatar
I had to make my own lifting fixture. The old carburetor lifting plate doesn't quite work.
Old 10-19-2013, 06:23 PM   #55
lynnfield
The Waco Kid
lynnfield's Avatar
Blackpony, I called and talked with Bill. I may use him, he is a little cheaper. He also uses all the original tooling to build his harnesses (like Speartech does) and he was able to answer all my questions competently. Thanks for the tip. Greg
Old 10-19-2013, 08:11 PM   #56
solidaxel
solidaxel's Avatar
Have you looked into Howell ENGINE Development for a harness?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-20-2013, 02:05 AM   #57
Blackpony
Blackpony's Avatar
you will not be disappointed with his harness!!
Old 10-20-2013, 04:00 PM   #58
lynnfield
The Waco Kid
lynnfield's Avatar
solidaxel, I did, I believe they would be a good choice also. Their prices were in line with Speartech, it would just be personal preference choosing one over the other. Personally I liked that I could call and talk directly with John (Speartech), or Bill (BP Automotive). It was the same when I was shopping for the gas tank, I was able to talk directly to Dave Boyd (Boyd Welding). Thanks reading along, Greg
Old 10-26-2013, 11:17 PM   #59
lynnfield
The Waco Kid
lynnfield's Avatar
Here's what I came up with for the gas pedal. It was pretty easy, once I figured it all out.
Old 10-26-2013, 11:21 PM   #60
lynnfield
The Waco Kid
lynnfield's Avatar
First I trimmed the composite pedal down to the size of just the reinforcement backing
Old 10-26-2013, 11:30 PM   #61
lynnfield
The Waco Kid
lynnfield's Avatar
Here is where this changed a bit for me. I had originally planned to trim the bottom half of the pedal, form and attach a piece of angle to mount the 72' pedal to. What I figured out was that I had some metal bushings that fit directly into the cavity of the pedal. From there it was just trimming the pedal down far enough to allow the 72' pedal to fit over it. The majority of the main structure of the composite pedal is still there.
Old 10-26-2013, 11:32 PM   #62
lynnfield
The Waco Kid
lynnfield's Avatar
One more. I drilled the hole all the way thru and you can use a pin, or a nut and bolt to attach it.
Old 10-26-2013, 11:39 PM   #63
lynnfield
The Waco Kid
lynnfield's Avatar
Not to confuse anybody, but this was my original idea that I didn't use.
Old 10-26-2013, 11:42 PM   #64
lynnfield
The Waco Kid
lynnfield's Avatar
Side by side, before and after
Old 10-27-2013, 12:26 PM   #65
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
that looks great! I have the same pedal.
How will the pedal mount to the floor? Mine's temporary on wood blocks...and still looking for a final solution.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-27-2013, 10:19 PM   #66
lynnfield
The Waco Kid
lynnfield's Avatar
Kurt, I plan on using the bracket that the pedal mounts to from the donor truck. I hope to have those pics up in a few days. Greg
Old 10-27-2013, 10:20 PM   #67
lynnfield
The Waco Kid
lynnfield's Avatar
I have several of these bushings if anyone wants to do this and needs one. Greg
Old 10-29-2013, 03:05 AM   #68
lynnfield
The Waco Kid
lynnfield's Avatar
The local pick-n-pull had a sale going on today so I picked up a few things. The fans from the truck were too big, so I got these from a 96' camaro. I also found this ECM mount out of an S-10. Looks like an easy mount. Last, a filler neck with a 2" outlet to match my tank.
Old 10-29-2013, 03:11 AM   #69
lynnfield
The Waco Kid
lynnfield's Avatar
I started working on my pedal mount today. I cut this piece from the donor truck and plan on using the bracket that bolts to it. It's not mounted yet, but it looks like it will work nicely.
Old 10-29-2013, 03:17 AM   #70
lynnfield
The Waco Kid
lynnfield's Avatar
Looking a bit forward, I'm also planning to use the factory grommet and a 72' style clutch cover to run the wires for the tac module thru the fire wall.
Old 10-29-2013, 04:48 AM   #71
ls1nova71
ls1nova71's Avatar
I really like that gas pedal idea. Were you able to retain the spring where the 72 pedal mounts to the new one, so its spring loaded like it was.originally or is it hard mounted?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-29-2013, 07:06 PM   #72
lynnfield
The Waco Kid
lynnfield's Avatar
Ls1nova, it's a solid mount. I was aiming for that with my original idea tho. Greg
Old 11-01-2013, 11:23 PM   #73
lynnfield
The Waco Kid
lynnfield's Avatar
Ok, pedal is in and hard mounted. Here is what I did. First I cut this piece from the donor truck.
Old 11-01-2013, 11:29 PM   #74
lynnfield
The Waco Kid
lynnfield's Avatar
Then I trimmed it down to this. I sanded the edge down at an angle because the bottom of the pedal was a bit high when I mocked it up. It's not in the pic but, I also rounded the corner to match the bracket.
Old 11-01-2013, 11:35 PM   #75
lynnfield
The Waco Kid
lynnfield's Avatar
Cut away the padding and mounted the bracket. I think a piece of flat strap could be used to pick up the top two holes and mounted in a similar way with the bottom bolt going thru the floor. I just used this piece because it was there.
