Old 05-17-2016, 10:34 PM   #51
R_W
R_W's Avatar
Brake Upgrade Round 2
To get the larger hole centered correctly, I first traced the circle using the bracket as a template. Then I took a compass and drew a circle the same diameter as the hole, marking the center clearly. I cut out the paper and taped it to the firewall, centering it on the tracing. This gave me the center of the larger hole:
Then I drilled it with the appropriate sized hole saw.
______________________
"Daddy, that truck's not red"
Build Thread: TN 20 Build
R_W is offline   Reply With Quote
driver, project, tn 20
