12-08-2013, 03:29 PM | #51 | |||
Re: Newbie with a simple 64 Stepper Build...
Thanx!
Glad you've heard they are good as well. all is good.. thanx for askin Quote:
Thanx.. cant wait to have it running Thanx.. Should be a fun ride.
If you ain't living life on the Edge.... Your taking up entirely to much space!!!! My 64 Stepper Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586792 |
12-19-2013, 08:27 PM | #52 |
That motor is sweet! Keep posting pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
12-29-2013, 09:58 AM | #53 |
Well I hope u all had a Merry Christmas. I'm down in Fl. With family for the Holidays. Between all the family stuff, my dad and I have been Working on his 57 9 passenger chevy wagon. He put in a new gas tank before I got down here so we're running all new fuel lines and buttoning everything up so we can take it for a ride. No pics its to tight in the garage. Well maybe I can get one of how tight it is in the garage. Lol
Hope u all have a ... Happy New Year!
01-13-2014, 12:04 AM | #54 |
Well the Holidays are over and I'm back home. I got some work done detailing and starting to assemble the motor. I don't know how you guys put text between the pics so i'll list them first here.. lol
1.& 2.some photos of the intake pieces before 3. Base painted texture black 4. top cap texture black and brushed aluminum insert 5. quick mock up
01-13-2014, 12:38 AM | #55 |
some more..
1. valve covers after cleaning and giving brushed look. 2. after painting blue and clearing and painting texture black 3. lower base final install. injector harness tucked and installed everything else just mocked into place 4. a more complete one 5. a look as if looking down into the engine bay. I'm making everything that would normally be chrome the brushed look. just trying something different for once. So far I'm liking the look. kind of a stock, kind of industrial look.
01-13-2014, 05:39 AM | #56 |
Nice job
Live and let live |
01-13-2014, 08:42 AM | #57 |
Looks great man. The second set of valve covers look much better on there than the cheap stamped chrome ones. The black accents really set it off.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
01-13-2014, 08:49 AM | #58 |
beautiful job on that motor
"El Jerry" '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
01-13-2014, 08:58 AM | #59 |
67-72 parts collector,…
Engine looks sweet!
01-14-2014, 02:00 AM | #60 |
60-66 Nut
That's looking awesome
I don't typically care much for those valve covers in their original form, but I'm really liking them with the black, brushed top and blue lettering and bowtie. I like what you did with the manifold also. This should be one sweet running engine.
01-14-2014, 10:11 AM | #61 |
Diggin' the motor...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
01-14-2014, 04:22 PM | #62 |
Post Whore
AWESOMENESS!!!! Great work! Dig it!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
01-19-2014, 10:51 PM | #63 | ||
Thanx!
Thanx Quote:
THanx man much appreciated.. Thank you.. Thanx for the all the complements guys... I did manage to get some other small work done on the truck today.. All new rear brake lines and hose. bled the system and got em working. also removed the front windshield and rear window. So happy that no rusty surprises showed up. Pretty solid. SO next is to get the interior stripped and ready for paint and then wiring. So much to do so little time..
02-12-2014, 12:33 AM | #64 |
Just a quick update..
Haven't got a lot done recently. I got my underbed tank. got it mocked up, waiting to see where I end up mounting my air tank first. If I mount the air tank behind the gas tank, i'll have to move the gas tank forward and shime it so the bolt heads for the air tank are accessible. Took my rear end cover off and spider gears out to see what axle spline I have. I got a 30 spline so that saved me alot of money on a Auburn LSD kit. should be here tomorrow. I also had alot of slop in the rear end and I wanted to see what I was getting into. Everything looked really good inside there except the spider gears were missing the washers or weren't shimed. so they were just sliding up and down about a 1/4 of an inch when you moved the yoke. but the ring and pinion have good lash and look new. Hopefully the new LSD install goes smooth and I can have it all buttoned up by the weekend. so the truck will have a nice new posi with 3:73 gears. I'll post pics of the new unit and how the install goes.
02-15-2014, 02:46 PM | #65 |
ALRIGHTY THEN!! The New Auburn LSD arrived Wed. night. Got the old carrier out. Diff all cleaned up. Everything look to be correct so I went ahead and had the shop down the block press the new carrier bearings on. I had to change the factory shims out to set the pre load and lash, and its money. Couldn't have gone smoother. So now I got a new LSD 3:73 rear end that I can trust to work well with this new motor.. Putting new axle seals and outer bearings in today. then that's 1 more thing off the list of to do's..
Pic description: 1.New Auburn LSD 2.New bearing and shims kit 3.Ring gear on 4.Clean and in good shape 5.New LSD installed
02-15-2014, 02:53 PM | #66 |
Just a quick trick tip.
The ring gear is lightly pressed on the carrier.. DO NOT USE A TORCH TO REMOVE.. They say a heat light or soak in hot water.. Huh? Soaking a greasy carrier in hot water sounds like a mess, and soaking the new carrier in water just sounds dumb. so I used a heat gun and gently moved it around the gear until I could see the gear oil starting to evaporate. and then used 1 bolt to tap up on the gear and it POPED ever so easily. same for the install. lined it all up and used the heat gun again and taped it with a piece of wood (very lightly, doesn't need much) as I heated it and it slid on ever so smoothly..
03-09-2014, 10:16 PM | #67 |
Some updates on the old girl... Got the fuel tank and air tank installed.
Had to cut out the rivets on the cross member and move it up an inch. The cross member is formed in a z shape and the top of the z was keeping me from moving it forward closer to the fuel tank, and the bottom of the z was not allowing the air tank to sit far enough forward. So I cut them off and moved the crossmember forward and welded it in which gave me enough room to mount the air tank. I made some brackets and welded them inside the frame so I could bolt the tank to them. with some frame shaving and grinding everything fits pretty good. Hopefully everything fits under the bed. I seem to be within a 1/8 of an inch from the rear of the bed fitting or not. wont know till I'm ready to fit the bed. Deal with that when It comes time.. Also got my rims and tires last weekend. Installed and i'm digging the look.. Simple Cragar smoothies with spinners.. Heres some pic's
03-10-2014, 03:24 AM | #68 |
Nice Motor Madratt~! Keep the pics coming and keep up the good work.
Have a good week
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
03-10-2014, 09:58 PM | #69 |
Lookin Good
03-11-2014, 01:04 AM | #70 |
60-66 Nut
Nice work but I think that air tank is going to interfere with the rear bed sill.
03-15-2014, 10:21 PM | #71 | |
Thanx. Not as custom as your stuff but it'll have to do. Hey Capt. its going to be close.. I cut out the cross member and moved it forward for clearance. I have 4" from the bed bolt to the inner bed sill and the back of the tank is exactly 4" If I have to i'll trim that inner bed sill out.
03-25-2014, 11:14 PM | #72 |
MADD rat digging your build! Just a quick question I'm fixing to also order a atk engine . I'm going with the 350hp vortec engine hp32. My question is did summit charge you sales tax ? I know if you go directly through atk they do charge sales tax just wondering if summit charged you the tax?
03-27-2014, 12:01 PM | #73 | |
03-27-2014, 12:20 PM | #74 |
I just need to bring my truck down and drop it off... your skill level is out in left field. Looking great man.
64 Step Side - The Mistress |
03-29-2014, 06:51 PM | #75 | |
So I got a little bit done in the last couple days.. Remounted the air solenoids, made a bracket to mount the air compressor, and then set the bed and front clip on to check all my clearances. Not bad only a little adjusting of the fuel tank and a little trimming of the rear valance and it will fit like a glove.. tires are super close to the fender lips so i'm going to trim them up just for good measure. All in all a real good test fit. and i'm really digging the stance. This is going to be a daily driver, and used as a truck to haul my motorcycles to events and pick up Cycles to work on for fun.. so it has to have a usable bed and not bottom out. Now for the Pics
