09-17-2013, 08:18 PM | #51 | |
Vintage 4x4s
Re: 1971 K20- project just get driveable!!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
09-22-2013, 09:10 AM | #52 |
Could You keep me in Mind if Ya come across an EATON "Pumpkin" with the 4.10 or 3.73 Gear Set??? I KNOW Your lookin for a "Locking Set" but I could just use the "Open End" Set. Don't need a 'Posi Unit" or Locking set.I figure Somebody might offer one up to Ya. Let me know if Ya hear,I'm TRYING to get my 50 Chevy Truck ON the Highway,not just Lookin at the Highway.THANKS for ANY Help at all.
Jimmy. p.s. I KNOW the 3.73 set was an option on the 'Camper Special' 68-72.I'm Dreamin......
Jimmy Gatz |
09-24-2013, 12:11 AM | #53 |
Vintage 4x4s
Jimmy, assume you got my PM.
09-24-2013, 12:38 AM | #54 | |
Vintage 4x4s
Then the fun continued after I got them off, I found the shoes had delaminated and the drums are too worn to use as is or turn. I spent some time looking today and didn't find drums, since this is that one year only 2" wide shoe setup. If it were a 72, would have had some options. The pic below shows the wider 72 drums in the foreground. I then thought about just going the 14 bolt route, but just decided I'd rather have discs on the eaton, especially after I found some deals on the components. I found a set of adapter plates for $50, Eldorado calipers with park brake for $85 each, and rotors for 35 each, pads 35. So my piece together rear disk setup is less than $300 It is all being shipped now, so hopefully the info I read is accurate and it will all fit. I also ordered new parking brake cables and hub bearings. On a positive note, I got the wiring all done, engine finished connected, and she runs pretty good! Pulled out some of the massive dents in the box and I drove around the yard awhile in 1st (again, no brakes at all!) The power steering pump is really whining, I see the return line is pretty weathered, the air may be coming in there. Oh, I also got a set of 2.5 skyjacker front leafs, and 4 matching shocks. Its sitting low in the front right now on the stock springs, about 2 under the rear height, so can't wait to get the new springs on and balance it out.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 09-24-2013 at 12:44 AM. |
09-24-2013, 01:19 AM | #55 |
Vintage 4x4s
Wondering what I should do about the master cylinder given the change to discs in the rear?
09-24-2013, 10:09 PM | #56 |
Vintage 4x4s
So today I learned the brake adapter plates are shipping from Canada and won't be here for a week. I'm tempted to throw the rusty 72 eaton under it for now, then I could rebuild the original and install the discs at my leisure, and hopefully a no spin by then. Thinking maybe do the same thing with the front axle.
Searching for info on the master cyl and prop valve for the 4 wheel discs, there is no consensus. Some guys say both need to be changed, others say just the prop valve, others say no changes..........
09-24-2013, 10:22 PM | #57 |
Man i have been missing all the fun because this build isn't in the 4X4 section, consider me subscribed! BTW: I'm also doing an Eaton conversion along with other stuff except i have to work outside. :p
Come on over and take a gander at my truck when you have time, any tips and advice welcome.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
09-24-2013, 10:59 PM | #58 |
Carpe manana
Jud - my HO52 had no adjust hole for the brakes on the backing plate - if you are in there now consider adding a hole to access the star adjuster down the road. We plugged my holes with rubber stoppers.....looking good. Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
09-24-2013, 11:45 PM | #59 |
im not sure how it will fly on the 3/4 master, but on my jeep i have a 1 ton m/c and nothing was needed for the rear disk. i used the normal 3/4 ton front rotors and calipers. i plumbed an adjustable wilwood prop in the rear line, but later removed it because it was adjusted full open. the brakes work very well on that thing.
been driving my thrash fest truck for a week! you better get er done Jud! |
09-24-2013, 11:59 PM | #60 |
Vintage 4x4s
Pete, good idea that would have made life easier to get the shoes to release. I will be taking the plates off altogether though with the rear disc kit.
09-25-2013, 12:08 AM | #61 | |
Vintage 4x4s
So my goal was to have driveable in 60 days and I drove around the yard on Saturday, but no brakes, no hood, and no seat. Does that count as meeting my goal? I am getting a ton done on the truck, its just that everything needs work. Really underestimated how much it needed! It will be nice when done though!
09-25-2013, 12:20 AM | #62 | |
I know the feeling on how slow things move, i'm trying to detail everything as i go plus fighting the weather too.. Did ya put a milk crate in there for a seat?
10-09-2013, 10:44 PM | #63 | |
Vintage 4x4s
Engine starts really well now, can't wait to get the brakes on and hit the road. Here are some updated pics. Pulled the massive dents out of box. Still thinking I'll swap a better box on I have here but this can then be used on a trailer. Got the inspection cover cleaned and painted: Got the other axle spray bombed and springs ready to install. The rotors aren't too nice but I will replace them in the future. At least this axle has non frozen calipers, intact axle shafts, and lockouts. Fender nut welded in and hood hinges and hood mounted. Notice how low the truck is sitting on the front stock non heavy springs. Tires are 265/75/16 (31 inch).
10-09-2013, 11:09 PM | #64 |
6>8 Plugless........
Jud, great progress on this truck! You've saved one from the junk yards and crusher!!!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-10-2013, 12:29 AM | #65 |
Carpe manana
Nice Jud and you added bucket (5 gallon) seats. Sweet!
10-10-2013, 08:50 AM | #66 |
Proprietor of Dale's Corner
It loooks like different truck, Congrats on saving it. Engine running good?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
10-18-2013, 08:45 PM | #67 |
Vintage 4x4s
Engine is running good but won't know just how strong it is until I get the brakes done. I ditched the box, so I could fix the shock mount on the eaton and paint the rear of the frame/chassis. this truck chassis is really clean like a southwest frame, no rust pitting and still has some of the original undercoating on it. I think it was on the farm so long it really never saw salt.
Original undercoating: Only issue is the eaton shock mount hole is way too large! Even the hole close in the picture here is about 3/4"! So I fired up my new miller 252 Far one was so bad I cut it out and made a replacement triangle piece and welded in. All done:
10-19-2013, 11:25 PM | #68 |
Vintage 4x4s
Found a crack in front frame horn:
So I fixed it: Some minor bending at rear of frame: look to bottom of red block So I fixed it: Then used my HVLP paint sprayer, while dodging the rain showers and painted the areas of the frame I could get to. Took the front wheels off and did front of frame and outsides underneath cab as well. Front of frame fixed and painted. Core support will be replaced later. Big day, can you put some food in my dish now?!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 10-20-2013 at 09:48 AM. |
10-20-2013, 12:32 AM | #69 |
Did you wire brush the frame? what product did you use to paint it with ?
10-20-2013, 12:53 AM | #70 |
Second Chance Program
Subscribed! Cool looking truck!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
10-20-2013, 09:46 AM | #71 |
Vintage 4x4s
The rust was so minimal and hard, I just painted over it after a thorough 3000psi pressure washer blasting. Cleaning rust off with a wire brush is a waste of time in my opinion unless you have loose or flakey rust. We used to wire brush but saw no improvement in how long the paint lasted. I used Valspar oil based low glosss enamel. Nothing too fancy, I debated about even painting it since this is going to be a work truck/driver. After looking at in now, I am sure glad I did, looks way better and will be easier to clean off the chassis when it gets muddy.
10-20-2013, 10:24 AM | #72 |
Carpe manana
Lookin' good Jud - hope you beat the snow. Pete
10-20-2013, 11:08 AM | #73 |
Jud, it's looking real nice. Nice work on the frame repairs! Every 4x4 frame I've had has had similar problems as that one. Must be from common abuse.
10-20-2013, 11:53 AM | #74 |
Looking good, it has come a long way.
10-20-2013, 02:42 PM | #75 |
Vintage 4x4s
THanks Gentelmen!
On a side note, picked these up for $160 or so off ebay, seems like a pretty decent price? Some defects in chrome but you don't see these too often and the dials are like new! I will put them on the shelf and hopefully can find a decent Dana 60 front at some point. I keep thinking about that and a cummins in this truck- thanks to the Ryans here!! Hard to stay focused on the goal of just getting this truck driveable.....
