09-04-2013, 08:15 AM | #51 |
Re: Always a project truck...............my driveway build
Great work here! Hey, there's a cat on here with a big chub for the sixer's with a detailed thread on them. Here it is, he's got a 250/Weber combo, could be a good resource. Keep it up!
http://67-72chevytrucks.com/vboard/s...d.php?t=571916
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
09-04-2013, 08:05 PM | #52 |
Keep rocking dude.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
09-05-2013, 04:04 AM | #53 |
Pretty impressive how clean you got everything using mostly just wire wheels, i thought you used some type of media blaster.
09-05-2013, 07:48 AM | #54 | |
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
09-05-2013, 07:52 AM | #55 |
most of the parts are media blasted; whatever fits in the blast cabinet on base is blasted for sure. The engine block, firewall, and cross-member are all done with fiber wheels and wire wheels. Frame is next; going to do it the same way, but will have to do it in stages so not entirely sure how that will turn out (fingers crossed)
09-05-2013, 08:24 AM | #56 |
Subscribed like the progress
Posted via Mobile Device |
09-06-2013, 07:12 PM | #57 |
got some goodies today! woot woot!
So I wanted to add power steering and air conditioning. Can't afford the A/C conversion right now so I'll only be adding power steering to the little inliner at this time. Using these brackets:
09-07-2013, 10:57 PM | #58 |
this gives you a better idea of what I have going on. My plan was/is
1. strip/paint engine block 2. strip/paint firewall 3. strip/paint section of front frame where the stock cross-member bolts too 4. strip/paint stock cross member 5. bolt painted cross-member to painted section of frame 6. tape off/cover freshly painted surfaces 7. repeat section by section until complete
09-08-2013, 02:40 PM | #59 |
Looking good dude. I like the mounts for the power steering. They look nice.
09-08-2013, 03:35 PM | #60 |
09-08-2013, 03:35 PM | #61 |
09-08-2013, 03:38 PM | #62 |
09-08-2013, 03:46 PM | #63 |
thanks brother!
09-08-2013, 07:22 PM | #64 |
09-12-2013, 12:47 PM | #65 |
Niiiiiiice!
09-12-2013, 01:06 PM | #66 |
Looking good man
2014 single cabF150- Daily. 35s, camper shell and lifted. 1979 Custom Deluxe- project |
09-12-2013, 01:45 PM | #67 |
That firewall looks great, Did you spray it or brush it?
09-12-2013, 02:03 PM | #68 |
Nice work!
Welcome to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=574370 |
09-12-2013, 03:01 PM | #69 |
thank you, used a foam brush
09-12-2013, 03:51 PM | #70 |
Well you Sir are one talented dude because that looks great for a foam brush job, i honestly couldn't tell if it was sprayed or not.
09-12-2013, 05:17 PM | #71 |
Agreed. Looks very clean. What color is the truck?
09-12-2013, 05:46 PM | #72 |
I especially like this!!! CROSSMEMBER! Looking good. Great job on the firewall. It looks awesome.
09-12-2013, 09:43 PM | #73 |
Looking sweet!
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
09-28-2013, 01:49 PM | #74 |
Thanks again, the finish is far from perfect but good enough for a daily runner!
Going to give the Weber 2 barrel (38DGES) a try: Also decided to run an upgraded front caliper (dual piston):
09-28-2013, 06:06 PM | #75 |
