01-03-2016, 06:56 PM | #51 |
Re: Aussie built 1980 c10
01-03-2016, 07:42 PM | #52 |
I went to bolt up the headers properly and noticed the flange was very uneven and wasn't consistent with the holes in the gasket. some sections were only sealing by 1/8" and others wouldn't have sealed at all. I wanted to deck the flange to make it have more sealing surface but the flange is welded on the inside, the area I am wanting to skim off! to overcome this problem I welded the outside then decked the flanges.
this is how it was originally welded up then it was no surprise to see that once I layed the gasket over the flange the exhaust ports were way too small which then called for a bit of time with the dremmel to do a bit of port matching. I then marked the gasket holes to the flange and ground out the holes then smoothed them off once I was happy with the finish the headers went to HPC in Leongatha for a ceramic coat |
01-03-2016, 08:03 PM | #53 |
01-03-2016, 10:17 PM | #54 |
here are my personalized valve covers. I designed a logo with my initials (JB) then added engine cubes beside it. first i got hold of a set of marine v8 valve covers which gives me plenty of clearance between valve cover and brake booster yet maintains clearance for the roller rockers. I gave them a light prime and a basecoat of VHT ford blue I know its a crazy choice but its the closest I could get in high temp to my colour scheme...
I went to a local sign writer with my design and he cut out a stencil out of spray and mask film. all i had to do then was lay down the stencil over the blue base and i sprayed the valve covers wrinkle black. onec dry I removed the masking film and this is the end result Last edited by Bainsy; 01-03-2016 at 10:34 PM. |
01-04-2016, 09:30 PM | #55 |
That came out nice!
01-05-2016, 12:29 AM | #56 |
dang that is SWEET
02-11-2016, 08:01 AM | #57 |
11-20-2016, 04:29 PM | #58 |
Love this thread!
11-24-2016, 06:32 AM | #59 |
For those interested iv continued my build thread here: http://www.c10australia.com.au/forum...ILT-NOT-BOUGHT
Tags |
c10 20s, c10 454, c10 australia, c10 big block, c10 boss 304 |
